88rxsedan
Everything posted by 88rxsedan
  1. yes, thats why mine breathes hot air from under the hood.. safety from hydrolock
  2. i taped up the holes but i guess stuff got in.. sorry about that.. but yes, gas will work just fine.. hows it working for you?
  3. that is awesome, but im afraid id suck up water..
  4. OK, just about any car with HOSE FEED injectors. easily identified by the hose on the top running to the rail.. also, dont worry about how it mounts donw, you can use the orings and retainers from subaru.injectors to get = 84-86 300zx turbo injectors they are 370 cc.. keep in mind your going to need to lower your fuel pressure or get an AFC so you dont flood your car to death
  5. i put the xt6 clutch flywheel crap in my rx, still dosent hold worth ****
  6. planning some deep water excursions i see
  7. so the ricer kits from a civic fit in the back... hmmm....
  8. so lets say i wanted some mean cams for the RX.. what would i get?
  9. would you like to share with everyone what happend?
  10. actually in my book yes.. but somepeople just say screw it and pump her up.. bad idea
  11. did you at least pull a vacumn on it?
  12. get some guages, pressures are way different though i would imagine using 65-70 percent of the required amound of r12 in ounces..
  13. explain the process please. im interested
  14. hes not out of whack, it acutally wouldnt be that bad..hell, look at the xt's handling in comparison to the 82's... hmmm,...
  15. my xt would randomly light the ecs light and run like total **** (sputter, no power, bogging) .. It just went away, never found a cure.. but i would imagine a MAIN sensor is out somewhere, mainly, i would blame that damn flapper..
  16. im fairly sure "high" boost could be reached, hell.. it can hold 12 easy with no intercooler
  17. you would understand the potential IF you had a turbocharged one... i dont understand why everyone thinks of theese lil cars as "dogs" with my VERY minimal mods, i can tell you that my car is not weak, at all.. ive owned several non turbo scoobs, and yes - they are dogs.. not the case with the turbo version .. you shouldnt hate on your own kind, thats like cannibilism..
  18. you sir have absolutely ZERO faith in theese little motors.. im just gonna forget you own one
  19. opinions are like arseholes, everybody has one - some stink.. mmm kay? sure, anyone could swap for an EJ series.. but why not work with what you have? its not a waste of time to me.. ive got a damn block in half in my kitchen, you wont think its a waste when im done
  20. then it jumps up to a number that you cant even begin to imagine.. its still usable.... have you seen the video?
  21. every motor has a limit, but IF steps are taken properly, and all is done right, you can generate ALOT of HP, from any motor.. hell, theres a 1 liter bike making over 500hp to the tire with a lil boost.. i think its possible, and i wouldnt doubt it if someone actally did it.. its definately possible
  22. THANK YOU your my new subaru freind
  23. 7500 by accident once.. just cruisin 3.5-4k racin 6300 or so
