The Beast I Drive Posted May 13, 2010 Share Posted May 13, 2010 (edited) Well, Ive been tinkering around with this idea for a while now, but I put it off because I wanted to do all I could with the independent rear suspension my 87 GL wagon came with. Well, with a welded rear, 8" of lift in the back, and 31" tires, it likes to eat those glass stubs these old rigs have. Also, flex is severely limited by the short travel of the shocks and the angles at which the axles can safely run. So its time for the IRS to go. For those of you who dont know my rig, here it is as of today: A couple weeks ago I got a hot deal on a rear axle from an Isuzu Rodeo, like a 97 or something. Disc Brakes, 4.10 gears, and beefy looking construction, I think this will do quite well. looks to be about the right width too. I just need to change the brake lines to work with the Subaru setup, cut off the spring under perches, and weld on some brackets for my 4-link and rear coilovers. Then Today, These beauties came..... These are Heim joints I bought from Speedway Motors, they are used on competition rock crawlers and high-HP racing applications. They are ************ing huge, and flex to some mad extreme angle. I bought 4 right hands, and 4 left hands so I can have alignment adjustment in the rear. Just an idea of how big these are, here's one next to a joint I bought for the Turd wagon. The small joint has a 3/4" shank and hole. Yeah, overkill, but it's my style So now I just need to get some LH and RH 1" jam nuts, about 30' of 1.25" .120 DOM tubing, some long travel rear coilovers, and I can get the axle mounted to the car. Then I will need to modify the Isuzu driveline, build my 4.11 AWD D/R trans, and re-build the front half of my lift to incorporate a new front suspension using modified VW Superbeetle struts and new custom lower control arms, and more lift. I will also be building a sort of sub frame to connect the front lift to the rear mounting points on the body, for the 4 link to bolt to. The Superbeetle struts will give me an extra 2-4" of suspension travel in the front, IIRC. Also will be dropping in a Hi-Po EA81 that I am getting in trade for a Hatch (I hope ) With all this, The Beast should be *almost* as capable as a stock/slightly lifted 1990's Toyota pick up with IFS. I might have a gear shop make me a custom set of 3:1 Low range gears, and modify the body of the trans to acomodate these, but not any time soon More updates as parts are acquired! -Bill Edited May 13, 2010 by The Beast I Drive Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 13, 2010 Share Posted May 13, 2010 I am excited to see this. I think solid rear axle without a divorced Tcase is an awesome idea. We've been discussion doing that with my buddy's brat..... Quote Link to comment Share on other sites More sharing options...
The Dude Abides Posted May 13, 2010 Share Posted May 13, 2010 Easly one of my favoret lifted subys. Sorry to see it go the way of the solid axel but just makes it stronger. Good luck. Quote Link to comment Share on other sites More sharing options...
T'subaru Posted May 13, 2010 Share Posted May 13, 2010 gonna be an awesome rig Bill! Quote Link to comment Share on other sites More sharing options...
mcbrat Posted May 13, 2010 Share Posted May 13, 2010 be sure to put a good skid plate on, or do a remote oil sender set-up..... Quote Link to comment Share on other sites More sharing options...
Turbone Posted May 13, 2010 Share Posted May 13, 2010 I am excited to see this. I think solid rear axle without a divorced Tcase is an awesome idea. We've been discussion doing that with my buddy's brat..... I might have missed it, but I dont think theres any mention of a divorced t-case. Which he really really needs to do if he's going to all the trouble of a solid rear. Bill, your money would be better spent with a divorced t-case. You have the lift to do it and you know how well my hatch crawls. Plus its cheaper to upgrade the t-case than the tranny. Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted May 13, 2010 Author Share Posted May 13, 2010 (edited) I really considered the T-case Rob, but Im interested in trying this out first, and if I dont like it, it wont be hard at all to add the T-case, all the rear work will be done already. To be honest, with no glas stubs to break I wont have to watch the gas as much, and with the more powerful engine and an XT6 clutch and flywheel, and the 4.11 gears it will be a HUGE improvement over what it is now. Ive wheeled this rig a lot, and it does really good with what it has, so this will only make it better... Even if its not a leap, its still a step forward... Oh and this is what I have for a skid plate and exhaust right now, and it's taken some serious abuse on some nasty rocks and still going strong, I might fab up something that looks a little better though, this one was just a quick hack job. -Bill Edited May 13, 2010 by The Beast I Drive Quote Link to comment Share on other sites More sharing options...
mcbrat Posted May 13, 2010 Share Posted May 13, 2010 I had a GEn1 full skid plate modifiet to fit, but since it bolted in at the bottom of the core support on the shorter front end EA81, it wasn't quite sturdy enough. it protected the exhaust and oil pan great, but flexed "just enough" to snap my oil sending unit 2 times.... then I did this... Quote Link to comment Share on other sites More sharing options...
bigo1966 Posted May 13, 2010 Share Posted May 13, 2010 How much longer are the super b struts than the stock ea82 struts? Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 13, 2010 Share Posted May 13, 2010 I might have missed it, but I dont think theres any mention of a divorced t-case. yea, that's why I said "without a tcase" it's a great way to beef up the system, and open up options, without completely re-engineering the front end. I've got everything to convert an RX box to 4.111, and I have a 4.10 toyota axle here. My buddy's brat is so rusty, it needs a LOT of new steel welded into the back anyway.....some leaf spring/shock mounts, and fuel cell.... Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted May 13, 2010 Author Share Posted May 13, 2010 Upon doing some research, it turns out the Isuzu Rodeo axle is a Dana 44 1.31" diameter 30-spline axle shafts, and lockers from several manufacturers are readily available! -Bill Quote Link to comment Share on other sites More sharing options...
Turbone Posted May 14, 2010 Share Posted May 14, 2010 I think thats the same rear end that Qman had in his monster Brat, which also had a ARB airlocker installed. Quote Link to comment Share on other sites More sharing options...
Qman Posted May 14, 2010 Share Posted May 14, 2010 Mine has disc brakes and 4.56 gears with a drop out center section. It now resides under my Toyota. Quote Link to comment Share on other sites More sharing options...
jayare12 Posted May 14, 2010 Share Posted May 14, 2010 Bad@$$ Make sure to post lots of picks Quote Link to comment Share on other sites More sharing options...
SoobieDoo Posted May 15, 2010 Share Posted May 15, 2010 Right on, Bill..."The Beast" can't be true to it's name with stock drivetrain!!! How much longer are the super b struts than the stock ea82 struts? I'm also interested in this mod, if you feel like going into detail. I'd like my axles to rub, if they could. Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted May 15, 2010 Author Share Posted May 15, 2010 I will post details on the Superbeetle struts when I get around to that part, but there is a couple threads with some info on them here somewhere, I ran across one inadvertently just a few days ago, but cannot remember where or how I came to find it... -Bill Quote Link to comment Share on other sites More sharing options...
baccaruda Posted May 15, 2010 Share Posted May 15, 2010 I will post details on the Superbeetle struts when I get around to that part, but there is a couple threads with some info on them here somewhere, I ran across one inadvertently just a few days ago, but cannot remember where or how I came to find it... -Bill Probably one of Brian's. Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted May 15, 2010 Author Share Posted May 15, 2010 Probably one of Brian's. Actually, it wasnt... I can't recall who it was by ATM, but I am certain the one I came across was not Brian's. However, had it not been for Brian, I would never have had the initiative to try it I saw him mod a pair in person at his house one of the times I visited... I have a part number around here somewhere... -Bill Quote Link to comment Share on other sites More sharing options...
monstaru Posted May 15, 2010 Share Posted May 15, 2010 you should just trade me out of mine.....they have brand new cartridges in them and just need finish welding.....make you a good deal:grin:cheers, brian Quote Link to comment Share on other sites More sharing options...
The Beast I Drive Posted May 15, 2010 Author Share Posted May 15, 2010 you should just trade me out of mine.....they have brand new cartridges in them and just need finish welding.....make you a good deal:grin:cheers, brian Im interested... Im sure some kind of arrangement can be arranged -Bill Quote Link to comment Share on other sites More sharing options...
chopsubie Posted May 16, 2010 Share Posted May 16, 2010 So now I just need to get some LH and RH 1" jam nuts, about 30' of 1.25" .120 DOM tubing, some long travel rear coilovers, and I can get the axle mounted to the car. Then I will need to modify the Isuzu driveline, build my 4.11 AWD D/R trans, and re-build the front half of my lift to incorporate a new front suspension using modified VW Superbeetle struts and new custom lower control arms, and more lift. I will also be building a sort of sub frame to connect the front lift to the rear mounting points on the body, for the 4 link to bolt to. The Superbeetle struts will give me an extra 2-4" of suspension travel in the front, IIRC. Also will be dropping in a Hi-Po EA81 that I am getting in trade for a Hatch (I hope ) -Bill "" build my 4.11 AWD D/R trans''' Will this be in a 4 speed or 5 speed D/R? I would like to know what model car(s) would have the 4.11 pinion shaft that you will need. I have several 4 speed d/r trans parts from different cars but all have 3.9 ratio. If there is a different trans out there that has a pinion shaft with a 4.11 that will work in the manual 4 or 5 speed D/R gearboxes, I would love to hear more! Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 16, 2010 Share Posted May 16, 2010 "" build my 4.11 AWD D/R trans'''Will this be in a 4 speed or 5 speed D/R? I would like to know what model car(s) would have the 4.11 pinion shaft that you will need. I have several 4 speed d/r trans parts from different cars but all have 3.9 ratio. If there is a different trans out there that has a pinion shaft with a 4.11 that will work in the manual 4 or 5 speed D/R gearboxes, I would love to hear more! here in the US. you need a Full-time 4WD D/R 5MT from a Subaru RX, Which is usually a 3.7. And then put a 4.111 front pinion shaft and center diff from a newer gen subaru in it. Quote Link to comment Share on other sites More sharing options...
monstaru Posted June 7, 2010 Share Posted June 7, 2010 TTIWWOP:-\i wish i was young and single and could buy sexy joints at the drop of a hat......you dirty bastard, how did i miss that before....... Quote Link to comment Share on other sites More sharing options...
ryot1 Posted August 17, 2013 Share Posted August 17, 2013 hows it comin i cant wait to see this Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 17, 2013 Share Posted August 17, 2013 hows it comin i cant wait to see this he stopped workin on it 3 years ago. Not sure what state it's currently in. Quote Link to comment Share on other sites More sharing options...
