Wrx running gear swap, Australia.
With the rest of his heard.
Switched to top mount intercooler.
  • Replies 2.9k
  • Views 960k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
Posted Images
The coupe does look real proper, I would like it! Change the wheels perhaps (less spokes would be nice)
Perhaps I should stick the single headlight set up on my '83, looks good :)
Looks like a 6-lug trailer wheel to me
Thats kinda what I was thinking.
Cheers!
Don't replace your ea81 with an EJ', when you can supercharge it. :grin:
They top is a turbo, bottom is an SC.
Both completely awesome!
How did I miss that? :lol:
It would be so awesome to get one of those aircraft modified ea81s. :slobber:
I would take the supercharged one, it looks like it would fit in the engine compartment better.
The SC one would probably work better for a car anyway, probably has better torque curve.
With that gigantic turbo it would have AWFUL lag. Probably doesn't make power until around 4000. Which is perfect for an airplane, spool is irrelevant. You run it up and leave it there until you land. But on the street it would be like driving a honda :P
As I understand it with an aeroplane, this turbo setup would be used primarily on take off. Not in use much of the time otherwise.
Doug
how could you drive a 1980 subaru sambar legally in usa?
make it electric!
a company sold 'em already with electric conversion.
very few left alive, nowadays.
amazing¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡;)
Doug
No, actually. Air is thinner the high up you go.
Take an N/A engine. At lea level there's at atmospheric pressure of 1bar, or about 14.7 PSI. Go up to 10,000 feet and there's only around 10 PSI of pressure. That means less manifold pressure, that means less power output.
Turbocharged airplane engines have a unit called something like automatic density controller to keep the same manifold pressure at all altitudes.
So at lea level maybe the turbo is putting out 5lbs of boost, at 10,000 feet the turbo has to put out about 10lbs of boost to produce the same power.
So yes, it would help greatly taking off from a high altitude airport. But the point of the turbo is constant engine output at all altitudes.
The turbo does, in fact do work when flying.
The first gen wagon: Badass :headbang:
The third gen wagon: "Ey esse! How much HP does that bodykit add man?" :grin:
I really like the hood scoop, but the front air dam is ehhh... It doesn't fit the car...
I'm sorry, but the front end kinda looks like a mess. Too many sharp lines, and no blended well.
But it is a T-wagon!
Is that what happends when you mix Dr. Frankenstein with The Incredible Hulk? :eek:
