Loyale 2.7 Turbo Posted May 26, 2015 Share Posted May 26, 2015 And that is the last photograph that photographer ever photographed. Why? ... ... He was run over? Quote Link to comment Share on other sites More sharing options...
coxy Posted May 28, 2015 Share Posted May 28, 2015 Never heard of a telephoto lens, I have seen people cop rocks from rear wheel drive and All wheel drive rally cars sometimes breaking a lens and other times more painful like one who copped a rock in the Family Jewels (he went down like he was shot moaning in agony). Quote Link to comment Share on other sites More sharing options...
MrMark303 Posted June 7, 2015 Share Posted June 7, 2015 My car today Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 13, 2015 Share Posted June 13, 2015 My kind of Subaru Brat: It has the same "Radioactive Yellow" Colour as my "BumbleBeast" and also a Turbo EA82 / Dashboard swap ... this is a 1991 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 13, 2015 Share Posted June 13, 2015 Baby Blue Loyale 1 Quote Link to comment Share on other sites More sharing options...
-tombba- Posted June 14, 2015 Share Posted June 14, 2015 Some hard.work ahead for the poor old ea71 engine in this: https://goo.gl/photos/qPD1iP3aX2cjc75u5 Over 300 km trip ahead closer to my home so I can finally start doing something to this car. 1 Quote Link to comment Share on other sites More sharing options...
l75eya Posted June 16, 2015 Share Posted June 16, 2015 Drive safely! Try not to push the accelerator pedal *through* the floor! 1 Quote Link to comment Share on other sites More sharing options...
-tombba- Posted June 16, 2015 Share Posted June 16, 2015 Drive safely! Try not to push the accelerator pedal *through* the floor! Trip is done already. It came nicely all the way even it had almost 450kg weight in the trailer and some 150kg more in the trunk. Had to use fourth gear pretty much but otherwise no problems even in the steep hills. So safe and sound where it should be Quote Link to comment Share on other sites More sharing options...
comatosellama Posted June 23, 2015 Share Posted June 23, 2015 (edited) I thought the brat was looking good out in the field today. Edited June 23, 2015 by comatosellama Quote Link to comment Share on other sites More sharing options...
-tombba- Posted July 4, 2015 Share Posted July 4, 2015 Yes or No for this hood scoop (obviously it will be functional too) ? https://www.dropbox.com/s/jzp8k5h6oewsxua/2015-07-04%2014.33.56.jpg?dl=0 https://www.dropbox.com/s/7iesvnw351awwi9/2015-07-04%2014.33.45.jpg?dl=0 https://www.dropbox.com/s/40jlboapxnl1a9f/2015-07-04%2014.34.06.jpg?dl=0 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 4, 2015 Share Posted July 4, 2015 Yes or No for this hood scoop ... Yes! ... it looks nice. I made the one on my "BumbleBeast" with sheetmetal. Kind Regards. 1 Quote Link to comment Share on other sites More sharing options...
-tombba- Posted July 4, 2015 Share Posted July 4, 2015 Yes! ... it looks nice. I made the one on my "BumbleBeast" with sheetmetal. Kind Regards. Thanks for the opinion ! On it goes then. This one is made out of ABS and I payed under 15€ delivered. It seems to be sturdy enough to handle the stress it gets in there. I already modded it to have more opening in front so it can flow more air trough it. I will probably attach it with rivets (maybe rivet nuts) and with the supplied sticky tape in there already. I'll cut the hood under it to direct air to my intercooler before putting it on. It looked like this when it arrived: http://i.ebayimg.com/00/s/ODAwWDgwMA==/z/3bwAAOSwnDZT~v1D/$_57.JPG 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 4, 2015 Share Posted July 4, 2015 I call the one I made, the "interFooler" Please see ~► Here, for further details. ... This one is made out of ABS ... attach it with rivets (maybe rivet nuts) and with the supplied sticky tape in there already ... Rivets / Blind Rivets could break the ABS Plastic. I kindly suggest you to use screws with washers, instead. With nuts in the underside. Kind Regards. Quote Link to comment Share on other sites More sharing options...
-tombba- Posted July 4, 2015 Share Posted July 4, 2015 I call the one I made, the "interFooler" Please see ~► Here, for further details. Rivets / Blind Rivets could break the ABS Plastic. I kindly suggest you to use screws with washers, instead. With nuts in the underside. Kind Regards. Yes I was thinking of using rivet nut inserts that has thread in them on the bonnet and screws with washers to fix the scoop in its place. This way the scoop is easily removable and the bonnet has strong mounting points in it. This way there is no need to fight with bolts on downside of the hood. But I have a lot of time to think how I will fit it really. Quote Link to comment Share on other sites More sharing options...
tjani Posted July 5, 2015 Share Posted July 5, 2015 Yes or No for this hood scoop (obviously it will be functional too) ? Absolutely not. Quote Link to comment Share on other sites More sharing options...
-tombba- Posted July 5, 2015 Share Posted July 5, 2015 Absolutely not. Well why not then ? I've got a replacement hood for this so it won't ruin it forever. Quote Link to comment Share on other sites More sharing options...
tjani Posted July 6, 2015 Share Posted July 6, 2015 Well why not then ? I've got a replacement hood for this so it won't ruin it forever. It is ugly and you lose sleeper look. Put fimic or air to water intercooler. 1 Quote Link to comment Share on other sites More sharing options...
-tombba- Posted July 6, 2015 Share Posted July 6, 2015 It is ugly and you lose sleeper look. Put fimic or air to water intercooler. Too expensive at the moment. Already have TMIC from -00 GT impreza mounted in there. Also it will probably get FMIC later on and with that original hood back. Quote Link to comment Share on other sites More sharing options...
comatosellama Posted July 6, 2015 Share Posted July 6, 2015 Series 100 snorkel? I like the look! 1 Quote Link to comment Share on other sites More sharing options...
bratman18 Posted July 6, 2015 Share Posted July 6, 2015 Series 100 snorkel? I like the look! Yeah its made for a Pajero. Thanks! 2 Quote Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted July 9, 2015 Share Posted July 9, 2015 Just made 200,000 miles... but only 8500 on brand new CCR EA82T(: Quote Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted July 9, 2015 Share Posted July 9, 2015 New EA82T (: Quote Link to comment Share on other sites More sharing options...
Rust Posted July 10, 2015 Share Posted July 10, 2015 Quote Link to comment Share on other sites More sharing options...
l75eya Posted July 11, 2015 Share Posted July 11, 2015 Looks like the car that started this thread long ago. First post. Quote Link to comment Share on other sites More sharing options...
-tombba- Posted July 23, 2015 Share Posted July 23, 2015 I found something pretty horrible from the internet thingy today. (Scroll to bottom of the page): http://www.mstuning-sound.wz.cz/cars.html Quote Link to comment Share on other sites More sharing options...
