April 6, 20188 yr So I came up with this idea since I have tons of spare stuff laying around and I don't feel like spending a small fortune on a lift kit. I'm going to try stacking the top hats for the front struts (I'm still working to see if that same idea might work for the rear) ill Remove the studs and use some grade 8 bolts That pull the top hats together. Also planning to double up the trailing arm spacers from my parts car for a slight body lift.Comments? Opinions? Suggestions? Edited April 6, 20188 yr by Jabbott126
April 7, 20188 yr would have to agree with all of the above... Not a good idea, not by any stretch of the imagination. If you want a lift, do it the right way - not hodge-podged together
April 9, 20188 yr small fortune on a lift kit for <$50 you can get front and rear spacers. Paranoid fabrications is one option. Edited April 9, 20188 yr by wtdash
April 9, 20188 yr What ever happend to the napkin lift diagram that was a great resorce for a cheap 2" lift
April 16, 20187 yr What ever happend to the napkin lift diagram that was a great resorce for a cheap 2" lift +1
