Sign in to follow this
mkoch
Replacing axle shafts, front, EA81, what else should I do ?
1984 4WD GL,
I need to replace the axle shafts, front.
200,000 miles, seems like a good idea to replace the front wheel bearings and seals while I am at it.
What else should I do on this job?
Share this post
Link to post
While the front end is totally pulled apart I'd suggest inspecting / replacing the following:
- swaybar bushes (go with nolathane)
- front struts (shock absorbers)
- disc pads
- disc rotors
Share this post
Link to post
Tie rod ends and inspect/replace rack ends too.
Then a wheel alignment.
Or just do the shaft and ball joints, do an alignment and leave it be.
I would replace bearings unless they looked like the grease was dry or they're making noises when driving.
Cheers
Bennie
Share this post
Link to post
Create an account
Register a new account
Sign in
