ER27 durability + performance build
Hey guys, I'm in the process of tearing down 1 of 2 ER27 engines.  Here is my original post asking about ER27 info...
I plan on getting the heads worked (3-angle, pocket port, & milled). The cams will be sent to Delta for a 260 dur "torque" grind.
I want to do a leakdown test, but this engine is missing the balancer & bolt. Does anyone have a spare bolt or know the specs on it? I tried using an EJ22 bolt, but it's too small (diameter wise). I would take it from my other engine, but it's in California. This one is at my house in Connecticut.
Thanks.
Edited by tjet
  • Replies 54
  • Views 9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • idosubaru
    idosubaru
    Crank case ventilation  A hose connects from there to a metal tree which has 4 additional hoses connecting to the: 1. intake (see the ports on the picture of the bottom of an XT6 intake hose
  • This comes up in the images search that carfreak posted. This is very common discussion with performance EJ block selection, as all 3 forms are available No easy answer to that without som
  • Now It's starting to move into the performance side  Both cams & followers getting shipped out for 264 duration torque grind...
Posted Images
So I did a leakdown test. All were reading close to this, except #5 cyl
#5...
All other cyls show cross hatch
Edited by tjet
I can’t tell what the photos of cyl 5 show?
You probably know this but that engine has a warranty heat marker on it. It looks like it’s on the block so that block maybe has already been worked on before?
Yeah i saw that. What is it for? Does the dealer put it on?
It looks rusty in the #5 plug hole. I will pull the head in a few days & get some pics.
here's that tag
Edited by tjet
Wreckers have used these discreetly on used engines they supply in case of any warranty claims.
Engine rebuilders also.
Got a stash of these somewhere. The centre of the washer is like solder, if not solder. At certain temps it melts and falls out leaving tell tale sign the engine has been cooked. I failed to measure temp as it melted when I warmed one up on the furnace
So where was the leakdown leaking? Could you hear it in intake, exhaust or crankcase?
Edited by Steptoe
10 hours ago, Steptoe said:
..So where was the leakdown leaking? Could you hear it in intake, exhaust or crankcase?
Seemed like the air was escaping thru the crankcase. I have the oil pan off, so it's not like I'm getting a stream of air from the oil fill.
I will pull the head to investigate further.
It's weird that the tag thing was glued right over the bad cylinder. Maybe just a coincidence. If I had to make a guess, the head gasket had a leak, which allows water to fill the cylinder while it was in storage.
Edited by tjet
So it appears that the engine leaked water into the #5 cylinder during storage :( this rusted the lower section of the cyl wall.
The good news is that this engine has 5 head bolts per cylinder and a closed deck. How cool is that? :). I think an EZ30 only uses 4 head bolts per cylinder.
Edited by tjet
The head shows the same evidence
Head gasket looks ok, too. The part # is 899235, and it was made by Nike :lol:
It looks like the max bore limit is .020", So the factory bore is 3.620" + 020 = 3.640" ...Woohoo. I hope it will clean up.
Edited by tjet
Made by Nike! I love it. That’s actually the Fuji heavy industries logo, they’re the parent company or something that owns Subaru I believe.
The EA82 was closed deck too. It didn’t do much for the cooling system, and any strength gained wasn’t worth it really.
Pretty cool looking engine though.
Are the exhaust ports singles or Siamese and a single?
Cheers
Bennie
I wonder if they are factory installed gaskets (like if the heads were never removed)
2 cylinder share 1 exhaust, and 1 is separate.
2 hours ago, Steptoe said:
 I thought that was a boomerang !
Maybe one that didn’t come back? :P
Cheers
Bennie
Did a 3 angle valve job, cleaned up the ports on the intake/exhaust, and milled down the heads a bit on my ER in high school. The power was nice! Lost a few upper RPM in the rev range but I can’t say at all that the engine didn’t wake up lol
Didnt last very long though.  I used the wrong silicone for the cam carriers/housings (I just didn’t know. I was a kid) and it broke down into chunks and clogged up the oil pickup.
You speak the truth. One of the reasons the EA/ER engines have such a terrible cooling system. I've seen a couple big closed-deck EJ22t cars that required so much more cooling capacity than it seemed similar semi-closed blocks required.
What does closed deck vs open deck mean?  I haven't seen this terminology used before.
How much more cooling capacity does it need? This is a swap project, and I can install a large radiator and an oil cooler if needed.
What sealant do you need to use?
blockdesign-jpg.379865
No easy answer to that without some serious thermodynamics engineering. And being that yours isn't going in a Subaru, airflow will be all different from most of the documentation. But the EA/ER engines have very weak cooling systems, heat will probably be your biggest challenge, depending how hard you try to push it. Err on the side of caution with radiator capacity, oil cooler (at least oil/coolant exchanger, oil/air can be hard to prevent overcooling) would likely be a good idea. A radiator that struggles to keep a 90hp EA82 cool can keep a 130hp EJ cool without any fans.
Don't run a lower temp thermostat, though. Aluminum engines don't like being run cold, either. But if you've got adequate cooling capacity, you shouldn't go over "fully open" temp on the stat.
Interesting.   Thank you.   I have some stuff to read and watch....
Thanks for the info. I will make cooling a priority on the swap. The radiators on these old VW vans are very big - almost overkill. I added an old cooler with it's own fan a couple of years ago. I also removed the AC condenser in front of the radiator.
Edited by tjet
Permatex blue
Quick question: On this ER27, I've noticed various ports and nipples on the intake manifold, engine case, and valve covers. These are for water, vacuum, oil and breather.
 I would like to know what I can eliminate on this engine.
