October 1, 20205 yr So I have an EA81 engine that won't start suddenly. It barely has 60k original miles. It has been used daily for the last 5 months with no problem but before that it sat for 5 years. I have checked: Spark cables are sending their signal as verified by timing light. Battery is good Starter is cranking No catching at all - no sputtering - nothing but cranking over So I am thinking maybe the fuel filter is clogged? Problem is that I do not know what it looks like in this vehicle. I took some photos. Does one of these photos show the fuel filter? Any other suggestions as to what to try? Thanks Picture 1 Picture 2 Edited October 1, 20205 yr by spamanon
October 1, 20205 yr Pull the inlet line to the filter and stick it in a bottle. The try to turn the car over for a second. There should be fuel in the bottle. The filter is on the firewall next to the wiper motor. Edited October 1, 20205 yr by Ionstorm66
October 1, 20205 yr Author Thanks, lonstorm66, but as I mentioned I am not sure where the fuel filter even is. Did you look at the images I took?
October 1, 20205 yr 4 minutes ago, spamanon said: Thanks, lonstorm66, but as I mentioned I am not sure where the fuel filter even is. Did you look at the images I took? Yes neither image shows the fuel filter. Its up on the firewall by the wiper motor.
October 1, 20205 yr Author Thanks again, but mine doesn't look like that. Here, I took 3 more pictures. 3 more pictures
October 1, 20205 yr Author Perhaps this model does not have a fuel filter, since it looks nothing like the one posted by lonstorm66? Can anyone else suggest what to try next? I'd like to get this thing running again. Thanks!
October 1, 20205 yr 1 hour ago, spamanon said: Perhaps this model does not have a fuel filter, since it looks nothing like the one posted by lonstorm66? Can anyone else suggest what to try next? I'd like to get this thing running again. Thanks! I would think nearly ALL cars that old have a fuel filter of some kind. I know mine do. The '80s is just when the emissions stuff got going, and I can guarantee it HAD a fuel filter at one time if it doesn't now. It's not like modern cars that supposedly have "lifetime" filters. Did you look back by the gas tank? Look at IonStorm66's picture, and look for a filter like that around the gas tank. I have a book on hand that says that "'80-'81 models (except Brat): The filter is in the left rear corner of the engine compartment." If it's not there, it was removed, so you can follow the fuel line to see if a previous owner stuck it somewhere else. Edited October 1, 20205 yr by subaru1988
October 1, 20205 yr 31 minutes ago, subaru1988 said: Double post, sorry. Edited October 1, 20205 yr by subaru1988
October 1, 20205 yr Author 2 minutes ago, subaru1988 said: O.k., will do. Hopefully there is one back there!
October 1, 20205 yr while cranking, feed-in some starting fluid, unlit propane or maybe brake cleaner into the intake, if it fires, you have a fueling problem. If not, likely electrical.
October 2, 20205 yr 8 hours ago, 1 Lucky Texan said: while cranking, feed-in some starting fluid, unlit propane or maybe brake cleaner into the intake, if it fires, you have a fueling problem. If not, likely electrical. I would start with this approach. Spray a little starting fluid or carb cleaner in the top of the carb, or pour a little gas in there and see if it will start and run for a few seconds. If so then its a fuel problem. If it doesn't, check the ignition system next, which it sounds like you done partially with the timing light. However, if you have a weak spark issue it may trigger the timing light but not be strong enough for the vehicle to run.
October 2, 20205 yr 11 hours ago, 1 Lucky Texan said: Compression , compression, compression Kettering ignition - points can close up the gap as rubbing block wears down against the lobes on dizzy shaft Or can also ash up , have the fingernail thick gap but not work as intended. A points file to dress up contacts if ashing is the case On the fuel filter location - is the fuel pump up front near left bonnet hinge? Edited October 2, 20205 yr by Step-a-toe
October 2, 20205 yr 20 hours ago, spamanon said: So I have an EA81 engine that won't start suddenly. It barely has 60k original miles. It has been used daily for the last 5 months with no problem but before that it sat for 5 years. I have checked: Spark cables are sending their signal as verified by timing light. Battery is good Starter is cranking No catching at all - no sputtering - nothing but cranking over So I am thinking maybe the fuel filter is clogged? Problem is that I do not know what it looks like in this vehicle. I took some photos. Does one of these photos show the fuel filter? Any other suggestions as to what to try? Thanks Picture 1 Picture 2 The filter is underneath near the pump,but,you are barking up the wrong tree w/that anyway. Super rare for a bad filter to prevent idling on a carbed car,but,test(blow thru) and replace it regardless. Much more likely to be a plugged idle jet,emulsion tube,bad idle stop solenoid or non functional choke. Can you see fuel in the carb sight glass? Does the accelerator pump squirt? As stated,a flashing timing light does not = good spark.Test spark by making it jump a gap. Pull the spark plugs to verify they are not fouled.If they have any fuel smell at all. dry them w/a torch or kitchen stove. It should start even if the idle jet is blocked if you prime it w/a few squirts from the accl. pump and vary the throttle position while cranking Much safer to reinstall the airfilter before cranking
October 2, 20205 yr Is this a DL , with the elder external voltage regulator ? I know some of the early 80’s still carried the old style forward but as I know it typically the low end of the product line. If that’s the case I would investigate the alternator and voltage regulator which power the pump. By saying yours doesn’t have the fuel filter where shown in the picture , that may indicate this is a DL or STD (fleet type).
October 2, 20205 yr Author 3 hours ago, moosens said: Is this a DL , with the elder external voltage regulator ? I know some of the early 80’s still carried the old style forward but as I know it typically the low end of the product line. If that’s the case I would investigate the alternator and voltage regulator which power the pump. By saying yours doesn’t have the fuel filter where shown in the picture , that may indicate this is a DL or STD (fleet type). I think it is a DL, but I am not sure. It is front wheel drive and a hatchback. The stamp on the engine indicates it is EA81.
October 2, 20205 yr 2 hours ago, spamanon said: Where is the carb site glass? Hitachi have a porthole shaped window on one side or end of the float chamber of the carby so if clean you can physically see the level the fuel is at at the time Should see a dot etched in the centre marking desired level, running or not
October 2, 20205 yr Author Ok, I looked under the car and traced the fuel lines - still no fuel filter. I am guessing this car has none at this point. I found the view port on the carb. The car is on a slope away from the window but if I rock the vehicle my wife says she sees fluid sloshing in there. Here is a video looking down the carb while the wife pumps the accelerator. Nothing seems to happen. I.e., I see no fuel squirting anywhere. Here is a video of the side view of the carb. I see fuel leaking out. A clue to why it won't start?? Thanks!
October 2, 20205 yr It does not need to spray fuel from pump circuit in order to start but this will be a problem to drive safely, normally Leaking is a problem, but usually not starting issue. If you can get it started it may not leak or flood. That porthole meant to be viewed level. Looked under dizzy cap for points. At points? Edited October 2, 20205 yr by Step-a-toe
October 2, 20205 yr Author 13 minutes ago, Step-a-toe said: It does not need to spray fuel from pump circuit in order to start but this will be a problem to drive safely, normally Leaking is a problem, but usually not starting issue. If you can get it started it may not leak or flood. That porthole meant to be viewed level. Looked under dizzy cap for points. At points? Points seem to be fine. No gunk or debris. Things look kinda shiny.
October 3, 20205 yr spray carb cleaner down the throat for 1-2 seconds. hold pedal about 1/4. crank. If it tries to fire, [and once you are used to this trick, you can get it to run for a few seconds, if everything except fuel is ok] you have a fuel problem.
October 3, 20205 yr 4 hours ago, spamanon said: Points seem to be fine. No gunk or debris. Things look kinda shiny. Holding this thought, ashing is just of contact points surface so you can see a gap, no debris just no electric conduct. At least no pitting of the points. I learnt ashing in my 68 Ford, started for me to get to work, go for lunch by the lake, but not to start until old old school mechanic boss swiped some emery paper between them and she fired right up Edited October 3, 20205 yr by Step-a-toe
October 3, 20205 yr How about a video of your engine bay ? Maybe we can locate the filter. Can you please read my previous post here and verify ?
October 3, 20205 yr Author Ok, so update time. I checked, and there is a DL on the back of the car, so it is a DL I sprayed Valvoline carb and throttle cleaner in there and still not catching, at all - nothing but cranking. I took out 2 of the plugs and they look like this. Obviously there is some nasty stuff going on there. I checked to see if the plugs were sparking by setting them on the block, connected to the spark cable and turning the engine over. I saw no clear spark. I filmed the engine compartment and it looks like this. If you spot a fuel filter, please let me know. I forgot to add that after I did the spark plug test, when I picked up the plug that was tested and still connected to the cable it shocked me. Not sure if this is relevant. Thanks Edited October 3, 20205 yr by spamanon
October 3, 20205 yr The plugs are complete garbage.Of course it will not run. The filter is near the pump underneath.You did not look hard enough. Your car does not have points, Edited October 3, 20205 yr by naru2
