What's wrong with this picture?
  • Replies 51
  • Views 6.4k
  • Created
  • Last Reply
Top Posters In This Topic
Odometer reading seems strange, but the picture isn't sharp enough to be sure.
it isn't either of the cars listed in your profile?
It is deffinately an 02-05 WRX auto trans but other than that I give up.
Did an oil change on this at work today. See if anyone notices what's wrong:
Did you bring the car into the office, literally? I see files :cool:
The low blinker fluid light is on?
Aside from the car running, may be in gear, fuzzy picture, and looks like its about to drive into somones office .........
nipper
The top right of the steering wheel looks like maybe it is cut through? I don't see any inspection or registration stickers (maybe not needed where you are?). What's that bright spot between the fuel and temp gauges?
is it me, or is there a negitive sign in front of the trip thinger :confused:
and all the gear selection lights are on?
Oil change on a car with only 1539mi?
thats the trip odometer :lol:
Looks like its just the speedometer needle below the last needle point.
The steering wheel badge is upside down !!! You have one of those OWOW wheels right ?
Aren't the tach's on wrx's in the meddle of the cluster?
yes that's an RS or TS or OBS
There a ghost in the background........
I know, I know... you accidentally drained the AT fluid and have now overfilled the oil. Additionally, you drove 200 miles home for lunch and cooked the transmission.
Your only option is to make an appointment with Pep Boys to replace the transmission and reset the rocker switch on the steering column to the ON position so they can replace the battery while you wait.
Obvious... Loose nut behind wheel :lol:
I see a asymetrical gap on the right side of the air bag too.
1) The f-stop on your camera is incorrectly set so you've provided us with a "Nessie/Bigfoot" picture that is so blurry that it could be anything
2) Your Check Engine light is on and the engine is idling. I had to magnify your picture a bit. The image is fuzzy and the "check engine" light looks a little too far to the left but that's my best guess.
3) You 02ishWRX is in a real office and the engine is idling. I hope you have CO detector in the building...
4) I have some clear pics of a 2002 WRX instrument panel for comparison but do not know how to upload/attach pictures on this board. Everything on the instrument panel and steering wheel checks out for a 02ish WRX.
5) You're driving me nuts. Please let us know what the answer is. I actually went out to my car to take pictures :banghead:
i say if he deosnt tell us we force him to drive a 1984 ford escort with an automatic
nippe
