Red Sedan Build , solid rear axle
been lookin at the car and lookin at different options, pros and cons heres a list............................................................................2nd tranfer case Lower gears,weaker front diff studs because Im using a rear Diff Higher center of gravity as the engine and transaxle would be in stock height more weight with 2nd transfercase and frame to mount it,also second crossmember for engine support and 3 drive shafts instead of 1
keep stock transaxle................. lower center gravity , better clearence mid car, less of a aproach angle , less weight, less parts, less engineering, only one driveshaft to have made not 2
  • Replies 249
  • Views 54.1k
  • Created
  • Last Reply
Top Posters In This Topic
got the car moved today, its now back it the corner all so started some major cleanup found the back wall of the shop, its been 10 years since I saw that area, moved the new to me bandsaw in place , moved the wood stove out next for a steel rack on the back wall
you have stayed "easy" for the last few cars..:lol:come on scott..:grin:cheers, brian
If I may make a suggestion:
Lower the T case an inch or so.The input drive shaft looks to be at a bit to steep of an angle for reliable power delivery.From what ive heard a 5-10* angle on the drive shaft is about all thats practical before it starts binding up.10* of free standing angle is a bit extreme for U joints.It may work but it would probally wear out really fast.
On the other hand,the U joint is just spinning with no up or down travel so it might work...Again I don't know how long U joints will last.
if you just go solid in the rear without a t-case (keep stock transaxle) as front wheel drivers, unless you lock it, you are still going to be limited to doing the same things a regular lifted soob with a welded rear does...
I originally thought I'd keep the stock fuel tank, but it's have to sit so high to do so, you lose your low center of gravity advantage...
When Chris designed mine, it was basically, set the ride height and then engineer the stuff around it so it will work at that height... another guy in my club has a jeep with 35's under it, not sure how much lift, but I'me a good 12" shorter than he is (top of vehicle). a lot of that is inherent in the design of the soob body, but it helps... I can still duck under trees pretty well....
EASY you dont remember that silver car that saved your ( Dodge) 2-1/2 years ago??, that thing wasnt "easy" has a 2nd tranny and transfercase , 9" lift and modified body, come on Brian Ill challenge you to a build off and we will meet up this summer and compete our 2 soobies side by side and see what happens , I realy like my ole white car just want somthin a little better that will not break :banana::):eek::banana:
BUILD OFF!!
BUILD OFF!!
(chanting)
:popcorn:
oh, i'm not really into competition......and you have more space and resource than i do.I know you are a competent builder scott.and really, if you think about it...that car would be easy to build again,because you have already done it once:)and i said for th elast few cars,(yours or not)
i was just responding to "giving up eaayy?":lol:
cheers, brian
oh, and by the way, as long as it is FRIENDLY competition...i'll think about it.:banana:
OK decided which direction to go, I didnt really like the Nissan case its so tall and would need a framework to mount up , so I went out and picked up a Toyota 86 4runner 4x4 tranny with transfercase , checked it out tonight
Heres the Subaru clutch disc next to the Toyota one, the Toyota one has a bigger hole with more splines , subarus on the right, also the subby preasure plate has a larger throwout bearing and "hole" 4272650681_d20f50e5f0_o.jpg
subbie center bearing slipped onto the Toyota pilot same size...4272650679_651c1c284b_o.jpg
Edited by Scott in Bellingham
heres the EJ tranny4272650645_0ff640d85f_o.jpgwill need to cut the front off the tranny machine it down , cut the Toyota Bell housing in half Machine it down and weld the 2 halves together
very cool idea! can't wait to see the result of this!
maybe throw some 4.7:1 gears in that tcase while it's out.
So are you planning on using the Toyota clutch disc with the subaru flywheel and pressure plate? Also, will you be doing the welding on the bellhousing? I've heard from the TIG guys in my class that cast aluminum is a real pain to weld.
yes and yes
Cool updates! Its coming along quite nicely.
C'mon 4.7:1 gearing!!
-TJD
yes and yes
awesome. Are you going to be using TIG or a MIG with a spool gun?
How about the possibility of using the bellhousing portion of an EJ automatic?
I got one its deeper then the toyota, and positions the starter back farther, maybe would work with a automatic starter not sure
  • 2 weeks later...
We need more subaru models, eh!?!
What kind of struts would you use with that setup? I assume they would be the only factor limiting flex. :banana:
thats crap.......how are you even going to fit in the model?cheers, brian
