When to shift out of 4x
17 replies to this topic
#1 MaroonDuneDoom
MaroonDuneDoom
    Stick It To The Man!!!
  • 604 posts
  • Casper,Wy
Posted 02 November 2003 - 02:56 PM
what is the best speed to shift out of 4hi w/3.9 gearing?
it seems it has been having trouble w/shifting out. but i found that it usualy shifts better at certain speeds. any input?
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,215 posts
  • Portland
Posted 02 November 2003 - 03:00 PM
You should push in the clutch, and shift - there is no speed limitation for 4-hi, but you shouldn't shift while turning. 4-lo is a different story - your not supposed to go over 35 or 40 MPH in 4-lo. People have done it, but the manual says not to.
#3 MaroonDuneDoom
MaroonDuneDoom
  • 604 posts
  • Casper,Wy
Posted 02 November 2003 - 03:08 PM
it's really stiff shifting out. how do i fix?can I?
#4 Snowman
Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 02 November 2003 - 03:29 PM
Usually the reason for difficulty in shifting out is caused by slight amounts of binding from turning. If it won't shift out, then either break the wheels loose to relieve that tension or try backing up or turning one direction, then straightening out and trying again, then turn the other direction and straighten out and try again and so on.
As for the speed thing, yeah it doesn't matter how fast you are going. I have gone in and out of 4wd at 75 mph and it feels the same as doing it at 10. I usually stop going into low range just to make it easier on things, but it works fine to shift out of low range while moving.
#5 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 02 November 2003 - 05:49 PM
You also need to make sure the whels are straight forward.
#6 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 02 November 2003 - 07:33 PM
Tires will also contribute to that problem. If you tires are not the same diameter on all four corners that too can cause binding. Best to keep the same brand on all four corners along with the same condition. Whch means using tires with less tread than the others.
#7 PHATBRAT
PHATBRAT
    Subaru Lover
  • 2,628 posts
  • Berwick, PA
Posted 02 November 2003 - 10:50 PM
You gotta be going straight. I usually wind out first then before hitting second I shift out of 4wd then shift to second. Works great cause I am going straight and the rpm's are up and I already have the clutch in. Never had a problem like this.
#8 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 02 November 2003 - 11:13 PM
we take the RX up to 75 in lo-range. about 5000 rpm.
i like to shift between hi and lo in 3rd gear. 4th gear lo is about tha same as 3rd hi.
in a drag race type situation. start out in lo. shift 1,2,3 lo. when 3rd lo tops out, shif into hi and carry 3rd out, then 4,5 hi. it acts like a 6 speed, 3rd gear is the best for shifting up out of lo.
to shift down into lo, say for example in 3rd gear hi, push in the clutch and shift into 4th lo.
#9 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,192 posts
  • WA
Posted 03 November 2003 - 12:08 AM
By the time you got done with all that shifting, I would be a 1/4mi ahead of you:headbang:
Rob
#10 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 03 November 2003 - 12:28 AM
give me a turbo and lets take it off road!
#11 Guest_taprackready_*
  • Guests
Posted 03 November 2003 - 08:56 AM
Also remember to check the air pressure in your tires. Low pressure in any one of the tires front or back will make that tire feel like its a smaller diameter and cause binding in the drivetrain.
Bill
#12 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 03 November 2003 - 10:53 AM
every 4x anything will have this prob, tires always wear different and stuff wears out in the tranny. try goosing it and letting off the throttle, and when the drivetrain unloads pop it into 2wd. do this without the clutch, and it should work good. or if you are in 4x you should have some slick stuff under your tires, witch will make it easier too. why would you use 4x on dry pavement?
#13 mtsmiths
mtsmiths
    Subaru Master
  • 1,659 posts
  • Kailua-Kona, Hawaii
Posted 03 November 2003 - 11:19 AM
on or out of 4-Hi. It just slides noislessly, at ANY speed, well, at least up to 70, that's the fastest I've gone in 4WD.
Done that in a total of well over 100,000 miles counting both of our GL-10s, and never had a problem. Nothin' straightens out an inadvertant slide like snapping into 4-Hi!
#14 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,363 posts
  • Seattle
Posted 03 November 2003 - 11:26 AM
Wondering the same... wtf would you be driving around on dry pavement in 4X for?
Also.
What the Hell are you guys doing driving around at 75 in 4X for?
Save the 4X for when it's necessary.
#15 mtsmiths
mtsmiths
    Subaru Master
  • 1,659 posts
Posted 03 November 2003 - 12:03 PM
Drive 70 on the interstate .... or DIE!
#16 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 03 November 2003 - 12:10 PM
This one I can vouch for .. Driven through wyoming in the winter.. snow and slush and sh!t all over the hiway.. people still doing 80mph.. definitely 4wd conditions.. but if you drive to slow, the local idiots will run you off the road
#17 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,363 posts
  • Seattle
Posted 03 November 2003 - 12:59 PM
hehe, I'll buy that.
I didn't see the "in the snow" part.
#18 electryc_monk
electryc_monk
    Air-ride Airehead
  • 1,581 posts
  • Denton, Tx
Posted 03 November 2003 - 02:49 PM
from my ole 86 D/R car... MAX speed in 4LO is 55 recommended.
I can't see using LOW at speeds higher then that anyways... but hey .. that's just me.
as for the binding... yeah from time to time i have to do the "reverse" thing to get it to pop out of 4WD into 2WD.
sometimes if reverse doesn't wanna cooperate then I just drive it straight for about a city block and then easily push down on the lever and it seems to want to pop outta 4WD into 2WD ...this usually is in 2nd gear too for my expereince -anyways.
of course I also agreewith the idea of replacing the gearlube from the tranny and diff. sub-box before it gets any closer to winter as in a different thread was suggested.
I use the Castrol GTX 80-95? weight lube.
