* * * * * 6 votes
7269 replies to this topic
#5901 rrgrr
rrgrr
    Subaru Fanatic!
  • 437 posts
  • Bloomington
Posted 03 May 2014 - 07:33 AM
My friend (whom I talked into buying an 86 wagon) started having carb issues, so I helped him rebuild the Hitachi. It still wasn't acting right -and still needed the choke fixed, So... I gave him the Hitachi I rebuilt just before my Weber swap -we just transplanted the top of my carb onto his real quick, and it's much better!
#5902 81EA81
81EA81
    Eat, Live, Breath Subaru
  • 386 posts
  • Spokane,WA
Posted 03 May 2014 - 09:53 PM
I finally got to mounting up the A-bar to my driveway queen. Thanks CaptianHook!
#5903 Tsuru
Tsuru
    USMB is life!
  • 169 posts
  • Darby, Montana
Posted 03 May 2014 - 11:15 PM
I was feeling poorly at letting my 77 wagon sit in the driveway while I try and sort or source a functional powerplant for her.
So I got her a pet.
1988 GL10 Turbo Wagon. (this one is 4x4 and-gasp-RUNS!!)
so now my 1977 is no longer alone in the driveway!
1977 and 1988...now all I need is a 1966 and a 1999 and a 2000 and a 2010 and a 2020 - wait, getting ahead of myself...
Maybe I will stick with what I have, and be grateful that I am equipped with twin Subarus! (Subaru? Subarai?)
Whatever...
I gots two and am happy that they are no longer alone!
(it's good to have friends, no?)
Laughingly,
Timothy
Edited for to add photos
Attached File  IMG_2028.gif   670.22K   27 downloads
Attached File  IMG_2029.JPG   124.5K   33 downloads
Attached File  IMG_2030.JPG   111.25K   26 downloads
(apologies, forgot that "without pictures, it's just a story".)
Edited by Tsuru, 05 May 2014 - 11:45 PM.
#5904 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 04 May 2014 - 01:12 AM
...1988 GL10 Turbo Wagon. (this one is 4x4 and-gasp-RUNS!!)...
Nice! ... But where are the Photos:D
#5905 SnatchedHatch
SnatchedHatch
  • 286 posts
  • Munster, IN USA
Posted 04 May 2014 - 04:15 PM
What did I do to my hatch?
Well I had my muffler shop touch up their work and remove a bottom heat guard on a cat to put an end to an incessant rattle.
Oh.. and I sold her! More below, but I'll see you all again soon enough.
If you ever need one of these on a trailer, 3 guys can do it :drunk:
:headbang: Got a parts bike out of it too, and sold that the next day! All in all a great week, albeit sorry to see my Subie go :(
Edited by SnatchedHatch, 04 May 2014 - 04:22 PM.
#5906 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 455 posts
  • Akron, OH
Posted 05 May 2014 - 12:20 AM
Well, scored today. Got a low mileage PT4WD trans/shifter/solenoids, driveshaft, rear subframe, axles, diff, front axles and spindles/LCA/strut rods, AND a turbo cradle from 300. And its clean. And the rear frame has the sway bar.
Loyale's getting 4wd soon. :banana:
#5907 wagonist
wagonist
    User Awaiting Email Confirmation
  • 987 posts
  • Sydney, Australia
Posted 05 May 2014 - 07:31 AM
Did you get the centre bearing brackets that are welded into the trans tunnel? It's the only bodyshell difference between 4wd & fwd models.
cos FWD models are missing this part. Just get the mcut out of a wreck, clean them up, bolt up to the tailshaft so you can position them & get them welded in (just make sure you have the carpet lifted first, cos you don't want that catching on fire...)
#5908 jono
jono
    Reader and writer
  • 1,690 posts
  • Southern Hemisphere - AUS
Posted 05 May 2014 - 04:50 PM
does the EA82 centre bearing support just fit also  as easily in an EA81 trans tunnel - any idea ?
Something else I thought about but didn't - recover interior lights, coolant overflow bottle bracket and centre bearing support :(
#5909 SmashedGlass
SmashedGlass
  • 669 posts
  • From CO, stuck in FL
Posted 05 May 2014 - 04:54 PM
Project "Super Black" continues......finished buttoning up the dash and gauge cluster, and started two-toning the seats (for that super-groovy 70's muscle car theme). Went mostly without a hitch, the only real drama involving the Duplicolor being on the upper steering column cover. For some reason, even protecting it with a cloth while messing with the cluster, it started to peel off in little sheets, unlike any other surface in the car. It could be a slightly different kind of plastic (there are several and many different kinds I've discovered so far) which just doesn't take color at all, or I didn't prep it well enough.
Finished off the afternoon by slotting the drivers seat and consoles into the Sube.
Haven't even started on the door panels, they'll be going two-tone also just to keep a theme. Seats are still probably going to end up with some leopard-print covers on them.
*EDIT: annnnnnnnnnnnnd.........the cluster surround has to come back out. Have to rotate the LED bulbs for the 'Hazard' and 'Fan 1-2-3-4', they aren't lighting up. Drat. Let's hope Murphy doesn't strike and something gets messed up pulling it back off.
Edited by SmashedGlass, 05 May 2014 - 09:47 PM.
#5910 Discombobulated
Discombobulated
    Advanced Member
  • PipPipPip
  • 79 posts
  • Thornton, CO
Posted 08 May 2014 - 01:59 PM
What kind of LEDs did you get??
And yesterday I took my seat covers off to figure out that someone must have been drinking the blackest coffee known to man and spilling every cup possible:(.
Carpet spot cleaner I have kinda worked but sucked all the spills out and made it worse!!!!! Then I went to the wet towel with a steam iron and it worked amazing, still need to give it another session but it looks way better...yay
Oh and after the seat cover removal I found out I have a little lumbar support lever:) bonus!!!! Also took my drivers seat out to figure out why it felt so worn, I think the springs are just done so I took some huge zip ties and ran them through the springs so the spring wouldn't extend and viola feels like new...yay:)
Anyhoo have a good day guys!!!
Disco.
Edited by Discombobulated, 08 May 2014 - 02:02 PM.
#5911 Scooner
Scooner
    I like subarus.
  • 792 posts
  • Cheyenne, Wyoming
Posted 08 May 2014 - 06:06 PM
Hey Dis, i bought one of those Bissel Autol ProHeat cleaners off amazon for $100 and that thing made my seats look brand new! Took every stain and discoloration out, whats cool about it as well is it heats the water/cleaner solution up. Nice job on your seats though i never though of the iron trick!
#5912 MR_Loyale
MR_Loyale
    22 Years of Ownership. 94-16
  • 1,520 posts
  • Seattle
Posted 08 May 2014 - 06:38 PM
Yesterday I prepped the patient for surgery with an exterior wash. Then i assembled the engine hoist I had sitting in two boxes for almost a year. It was lat by the time I got started on this, but this afternoon it concluded with this:
I am on the hunt for the elusive oil leak. It has been hitting my exhaust and making a cloud of smoke and leaving the engine bay looking filthy:
#5913 SmashedGlass
SmashedGlass
  • 669 posts
Posted 09 May 2014 - 06:54 AM
Disco.
Got mine off FleaBay. T10 5SMD for the main illumination and turn signals, T5 inverted tip for all of the idiot lights and other lighting, and two T5 3SMD for the main illumination in the two side clusters (HVAC controls and Hazards; these are the two I need to flip around).
I'm going to eventually rent a carpet cleaner with upholstery attachments from a local store to do my seats and door fabrics.
#5914 Loyale 2.7 Turbo
Loyale 2.7 Turbo
  • 7,528 posts
  • Roatán, Honduras.
Posted 09 May 2014 - 07:49 AM
On the LED Retrofitting to the instrument cluster Subject,
this Writeup might be Helpful:
~► http://www.ultimates...val-procedures/
Kind Regards.
#5915 jj421
jj421
    USMB is life!
  • 600 posts
  • Auburn, WA
Posted 09 May 2014 - 04:02 PM
Haven't done much. Just saving up for front axles and rear brakes. Oh, I did do my subframe drop. Did a 1" drop, and wow, it made a difference. Axles aren't as stressed, front wheels don't have as much camber, less understeer (more oversteer), and better acceleration (front end doesn't lift up as much). Had to remove the clutch fan shroud, but that was it. The steering u-joint on the '86 DL manual steering rack was long enough.
But that's about it. In the meantime, I'll just continue pulling trucks out of the ditch. B)
#5916 rrgrr
rrgrr
    Subaru Fanatic!
  • 437 posts
  • Bloomington
Posted 09 May 2014 - 04:26 PM
^^Great pic!^^ :)
Cleaned and crowned her(spare), got the old KC fogs on, the shiny shaggy seat covers went on clearance, so I can stop worrying so much about my pretty nice seats ;)
'DSC03140.jpgpimpin' it :P
#5917 LucasP
LucasP
    New User
  • PipPipPip
  • 72 posts
  • Eugene
Posted 09 May 2014 - 04:58 PM
I cut all exhaust components off my 87 sedan today.  I am tired of the rattles and I needed to install my new converter and muffler.  Because of how busy I am with school the old girl is going to the shop for new exhaust.  I'm sad that I'm not doing it myself but so happy to be having new pipe from the motor out.
#5918 MR_Loyale
MR_Loyale
  • 1,520 posts
  • Seattle
Posted 09 May 2014 - 06:19 PM
More teardown on the engine.
First to go those stupid timing belt covers. Leaves me with some bits for the rubbish:
I actually had fun removing those because I got a new toy just for removing them quickly:
The good news is I see that the cam seals I installed in 2006 are still good and tight.
Edited by MR_Loyale, 09 May 2014 - 06:26 PM.
#5919 mcmillonbe
mcmillonbe
    Advanced Member
  • PipPipPip
  • 51 posts
  • Cottonwood Heights, Utah
Posted 09 May 2014 - 11:21 PM
Continuing working on the rust removal on the Brat for the past several weeks.  Rockers on both sides were shot, the wheel arch on the passenger side was mostly bondo and rust, and several other areas.  Cut out the rust in drivers side wheel arch, welded in some new metal and then did long strand bondo followed by some light body filler.  Also welded in the passenger wheel arch to the best of my ablility, not perfect, but better than the big rust holes.
The rockers are still being cut up to fit and should should turn out okay over the next few days.  I am determined to get this old ride painted before the last paint class on June 3rd. I would post pictures but not really in the mood to read comments about my welding skills.  I have learned a lot over the last couple of months, mostly that I will never take on a rusty project again.  The amount of time to get it perfect is beyond my capability, but at least this Brat will be good for many more years rather than ending up at the junkyard because of the cancer.  To those of you that are good at body work, damn! I always thought body work would be easy, but I have been seriously humbled by this experience.
#5920 MR_Loyale
MR_Loyale
  • 1,520 posts
  • Seattle
Posted 10 May 2014 - 01:21 AM
Fun with UV dye checking for oil leaks:
#5921 Subaruist
Subaruist
    Subaru Fanatic!
  • Banned
  • 376 posts
  • Medford, Oregon
Posted 10 May 2014 - 06:35 PM
Today, repaired exhaust for the 3rd time, nopefully the last time until I am able to replace the whole exhaust system.
UPS LOST both of my 8 1/2 foot stainless whip antennas, and was not even going to notify me with thier wonderful "tracking" - what's the point of having package tracking if they deliberately refuse to notify you if your package is missing ?!?!? Life is becoming 'Idiocracy' before my eyes.
Notified the place I bought them from two days ago, still have not received any reply, sent another message today.
Still debating on how exactly to mount them. I favor the 'Insect' antenna look, bit not much room for mounting large/heavy antennas or antanna ball mounts on the cab/top with a T-Top...
#5922 l75eya
l75eya
    Almost has it all figured out
  • 2,371 posts
  • Hoboken, NJ
Posted 10 May 2014 - 09:09 PM
Gave that ea82 a weber. ea82's love webers.
also, re-routed PVC lines, got rid of a BUNCH of stuff.
New spark plugs. Timing advanced. Car is happy.
Edited by l75eya, 10 May 2014 - 09:11 PM.
#5923 wagonist
wagonist
  • 987 posts
  • Sydney, Australia
Posted 13 May 2014 - 01:51 AM
Never tried :P
I'd suggest getting them out of an EA81 model. They're probably different enough between the bodyshells.
Though probably nothing that a big hammer, angle grinder & welder wouldn't fix :P
#5924 TheYeti
TheYeti
    Carp in Denim!
  • 505 posts
  • Arvada
Posted 13 May 2014 - 08:43 AM
Nothing exciting, but it always feels good to get things back to working order.
Replaced/ fixed the window crank handle that I broke while trying to install sound deadening on the front driver's door.
Drilled out and replaced a bolt that snapped off while removing the rear seat bottom.
Thanks for the help Shawn.
j.
#5925 TheWanderer
TheWanderer
    USMB is life!
  • 131 posts
  • Nebraska
Posted 13 May 2014 - 09:18 AM
Not much is done for me lately.  Installed the new tail lights last Thursday, made a huge difference.  As far as what I get to do today, I have to go to the different body shops around town and get estimates on what its going to take to fix the giant dent in the drivers quarter panel that my co worker put there last night and didnt tell me about (until after I filed a police report for a hit and run and they showed up at her door).  Dent goes about 3.5" deep at its worst and creased the top of the panel right below the seam/rounded edge near the hatch.  may have knocked my hatch alignment out too, its sitting about 1/8-3/16" below the panels when closed.  I estimate about $600-$800 worth of damage, mostly labor and paint/blending.  Its creased right at the tail light as well.  But at least she didnt hit the new light I just installed :rolleyes:
