All Activity
This stream auto-updates
  1. Yesterday
  2. My money is on the bearings on the inside of the engine, at both crankshaft, and piston rods, are rusted up so that you would have to tear the crankcase completely apart and replace them. Then the steel piston rings are probably also rusted in place and did not help the cylinder walls any. Long story short, you are wasting your time with an engine that has water condensing inside the crankcase, due to the changes in weather, regardless of whether it was under a hood or not.
  3. Plugs pulled, no coolant, radiator and heater core connected. I disconnected the hose going to the thermostat housing, plugged the fitting and shoved an air wand into the hose. My regulator doesn't go down that low so I just took it slow listening to the radiator cap. I can hear bubbling from the intake. Putting my ear up to the intake manifold with the throttle open. I can hear it. I can only assume it's the intake manifold gaskets. This intake came from a running engine with clean oil. I did clean up the surfaces, no sand paper tricks or anything just a brass scraper and a light buff with a scotchbrite. EDIT: I am proud to announce I have won "Smoothest brain of the year" award. I forgot to put the gasket on that goes between the throttle body and the intake manifold. I'm going to throw that on and see if the bubbling noises go away.
  4. Anything between about 5ftlbs and snapping the bolts off will seal coolant. The exact torque amount and procedure will affect longevity of the seal around the cylinder bores. There is nothing you can do other than flat out forgetting to tighten them that will cause an immediate external coolant leak, or a major internal one. You could have a cracked block or a cracked head. I did a revival of a many-many-years-in-junkyard ea81 wagon that went great (well, great except the gas tank being plugged solid enough that even 120psi of air couldn't get the pickup open, and the carb being a solid blob, and... but I got it running!) until I added coolant, and it ran out as fast as I put it in... Or a problem with the intake surfaces. I'm mostly an EA81 wolfy, not an EA82 one, so I'm not familiar with the cam stuff. Put it together with no oil or coolant, no valve covers, no exhaust, leave the spark plugs out, etc - but do connect the radiator, and loop back the heater core lines. Re-use your last set of head gaskets, unless they're obviously damaged. Do the minimum amount of assembly needed to seal up the cooling system. Remove one of the little intake coolant lines, plug the end with a barb plug and clamp, then put a few feet of hose on the barb you took the hose off from, also with a clamp. Stick the end of that hose on an air fitting with a pressure regulator, fire up your air compressor, and turn the pressure up to 12psi. Listen closely everywhere. Do you hear air anywhere? Do you hear any hissing coming back out the intake? Out either exhaust port? From the spark plug holes? etc. If you turn the pressure up too much the radiator cap will start hissing - turn it down if you do.
  5. Last week
  6. Real estate has been a million an acre for a while; why LeBlancs sold out even with all the toxic chemicals from many decades of activity on the property. LaJoies will not sell exhaust parts claiming that they rot from the inside out. I agree that F and S is the area expert on Subarus, I've driven up to Waterbury for a specialist to install a water pump on a prior vehicle.
  7. Okay, I'm really in need of some advice here. I have no clue what I'm doing wrong but clearly I'm doing something wrong here. This is the second time I've had milkshake oil after replacing the head gaskets on first start up. This time it's both sides. Oil pressure was bouncing in 5 psi increment up and down but was at a healthy level. 0 coolant pressure. Here's the process I've been doing, someone please tell me where I'm screwing up. I'll start from the disassembled short block. 1: Clean the head bolts, threads, deck surface, and cylinder heads. Cams, cam carriers, rockers, and valve covers are cleaned. 2: Install the head gaskets on a clean and dry block. Head bolts are oiled and toweled dry, only a light sheen of oil on the threads. Oil is also applied under the bolt head and washer. The FSM torque pattern is followed and the 3-step 22ftlb-43ftlb-47ftlb process is done. 3: The OEM o-ring and sealant is applied to the cam carriers. Rockers are greased and installed. Cam carriers are installed. 14.5ftlb on the bolts. 4: Intake is installed with OEM gaskets. 16ftlb on the bolts. 5: Rest of the engine is assembled and hooked up. Turn the key, milkshake. Am I supposed to retorque before first startup, then do another retorque? That makes no sense to me. Maybe it's just leaking from the intake manifold? But I used OEM gaskets on clean and dry surfaces and torqued to spec. I'm off to clean this engine out again. I'm not giving up yet. :[
  8. Larry, it’s tough around here. Too many lawyers. Most places don’t let you walk around anymore. You guys enjoy what you have ! Tom, there’s always F&S. If it’s older than 20 years just talk with one of the guys in the Roxbury yard like Jeff. Not sure about Johnny’s in Thomaston, i think it’s changed hands but that was another good yard where he would let you walk around. Which place do you go to? LaJoie’s?
  9. Have to look for the cars that were hit hard. Then you know they were going down the road. Used Subaru, better than Aftermarket IMHO. Larry
  10. It's been off. Replacing the solenoid is a little difficult if you don't have a lift. I had snagged one off a junkyard Subaru, it worked for a little while then probably shorted out. It's just not worth trying junkyard parts unless they've been checked. I got an ignition coil off a junkyard vehicle a while ago and it was worse than useless.
  11. I was giving AI a chat, as much as I don't like to sometimes it dredges up useful information. AI kept telling me that the 3-step 22ftlb-43ftlb-47ftlb was an outdated torque procedure and that a service bulletin released 05/91 updated the procedure to a 2-step 22ftlb-51ftlb procedure. Bulletin titled 1.8 Engine Head Gasket Torque Change/Oil Leakage. No bulletin number I could find. Perhaps regarding pushrod engines? However, after a call to my local dealership. I got a service bulletin # 02-85-91 released 12/91 staying that the OHC EA82's had no change to their torque procedure but the Justy did. So the book procedure is the correct procedure. :]
  12. Oh yeah coolant definitely was where it shouldn't have been. Milkshake anyone? I have plenty. I was extremely thorough with the head bolt torque. I always had a diagram with torque order and torque values written down. I seriously doubt I followed the directions incorrectly. That's not an ego thing, I make a lot of mistakes. I really don't think it was one of them. When I grabbed my set of head gaskets I mentioned my situation to my engine rebuilder (knowledge older gentleman) and he was very confused. Only thing that made sense to him was a defective head gasket. I'd cleaned, chased, and oiled all the threads. Bolts were wire brushed and cleaned. I have no clue what happened. And it was only the driver side that leaked (also closer to the water pump... Coincidence?) the passenger side was completely fine. I spent all last night tearing the engine down, I've spent all today cleaning the heads, cam carriers, cams, oil pan, and head bolts. It's basically ready to go back together but I'm going to spend some time with a coffee and a notebook going through the FSM to make sure I don't jump the gun. It's all a learning process. :] P.S. I took a look at my head gaskets (OEM) and I noticed they're slightly bowed. They're not bent or creased and I can flex them flat with one finger. I'd take a photo but I don't want to take them out of the plastic until they're ready to go on and you can't easily tell they're bowed when they're in the plastic.
  13. https://www.ebay.com/itm/156158523728 333235 LH https://www.ebay.com/itm/126419603634 333234 RH
  14. These guys and maybe Emily too, they’ll know more and be more than myself but a few items mentioned I can’t help but comment on. Bolt holes should have been super cleaned and same for bolts. I seem to recall you did use a thread chaser. But it’s not going to get easier going forward. If your heart is going to let your wallet solve problems on an EA82 in 2025/2026 it’ll get pricey and limited with who will take on such work. I’d give it another try but only after each and every bolt and its hole are cleaned and inspected for fit. Also my opinion - you likely started it up when you shouldn’t have. And i would take the heads off and be sure coolant isn’t where it shouldn’t be. Take a breath, you’ll have it back in action. You have to assess that O ring fitment. I know sometimes they look off but consider the sqaush down. FujiBond or equiv. should cure of course. You’ll need to see what that happened. Maybe had a solvent wipe-down that seeped in? Oil pan, i would try to reuse it if it came off like i expect it would having not been roasted. If not then they should be available or use sealant. Lots of is have used sealant only. Or a light smear behind the cork gasket. You’re still at a good age so enjoy that exercise, learning, and building speed and proficiency. And should you find yourself defeated after your efforts - find yourself and EJ22 - last resort, i know. I’m of the same skull density cult. Cheers !
  15. My guess as to what happened are either of the two scenarios: 1: I installed the head gaskets by the book but the time between when I installed the head gaskets and when I actually started the engine was about 3 weeks. I work 6 days a week and I had to wait on parts I thought I had but I didn't. In that time the heads, head bolts, and gasket creeped at different rates. So when I started the engine, the heads weren't torqued to spec (because everything had relaxed before the retorque) and this caused it to leak. After removing the heads, I noticed a few of the bolts didn't make a "snap" when loosening. The gaskets weren't blown through anywhere. I measured the deck with a straight edge and a feeler gauge, within spec. The heads were resurfaced and tested and passed okay. 2nd: I used a non-oem cam carrier o-ring. This could have caused coolant to leak into the oil. But the engine was also burning coolant and a cylinder wasn't firing properly so I'm not sure what to believe happened. Could be a combo of the two. I have a spare set of OEM head gaskets and OEM o-rings so those will go in tomorrow. Actually today, it's getting late. Can I reuse the cork oil pan gasket after I drop the pan to clean it out? Or are they prone to stick to the block and split? I didn't use any sealant on it. Also the cam tower sealant was still wet in some parts. I used OEM sealant and the temps when I applied it was in the 70°F range so I'm not sure what happened there. This is really turning out to be a learning experience but I sure am getting more comfortable working on this thing. Only took me 3 hours to get it stripped down to the short block with the engine in the car. That's lightning fast for my pace. :]
  16. I've never heard of a new head gasket with resurfaced heads and clean deck leaking, unless you completely forgot to tighten the bolts. You may have gotten a defective gasket, your block may be badly warped, you may have a cracked head or block, your leak may be coming from somewhere else and only looking like the head gasket, or you may have forgotten a step...
  17. Well I got it to run. Dizzy was a tooth off. But now I have a coolant leak I have to track down. The cars been sitting a few weeks between when the head gaskets went on and the first start so maybe the head gaskets need a retorque? EDIT: yes it 100% is a head gasket. Now the question is do I take off the head (only 1 side is leaking, driver side) to inspect the head gasket and replace it? Damn this really sucks.
  18. I got ahold of a canister from an ‘83 today, and will try the your hookup layout, thank you! It feels like several symptoms are explained by the lack of charcoal canister. Full disclosure, I had eliminated the canister five years ago when the 2.2 was installed to my 83 wagon. Because that swap had worked well, I just forgot about that until I saw the canister I picked up today. Which reminds me of having seen it in the original donor car.
  19. After doing some thinking, a few things of note. This is a carbed EA82 that I've converted to SPFI. I know the cams between the two are different but I've always heard they're interchangeable, just the engine may prefer different ignition timing than a factory SPFI setup. Is it best to connect the test connectors to put the ECU into "learn" mode as I'm trying to start the engine for the first time? I'm really thinking it's just a timing issue since as I've mentioned it doesn't run off ether.
  20. Uhaul charges MILEAGE if it is anything beyond just a few miles local. Something to consider, it will get spendy real fast.
  21. Still have a fairly good quantity of Eighties "box" or EA-82 parts, most left now, are smaller items, that will ship easily enough. Most of the larger items, to include parts wagon, have been disposed of, or sold off, due to difficulty in finding homes for them, and the LOGISTICS. You can always browse my ads, I do keep them current, and can do package deals on remaining items.
  22. Timing belts were put on by the book. Driver side, rotate 180, passenger side. Check at 0 BDC if the pulley markings are facing "outwards" and dizzy is set to #1. It is. Plug wires are in the proper firing order to the proper cylinders. Belts were torqued with a homemade version of the factory tool and a beam torque wrench. Granted the belts were used for about 2-3k miles so I had to tighten to 18ftlb rather than 2ftlb if the belts were new. But I followed the chart in the FSM. If I had to guess it to be anything it'd either be a timing issue or a compression issue, somehow, but I'm more inclined to believe the former rather than the latter. Could also be bad gas, but it doesn't run off ether which is why I think it's a timing/spark issue. Even though I have spark. I seriously doubt a coil or dizzy issue. :]
  23. I had a “problem” with my first and last EA82 rebuild - turns out we missed the bit where you fit one cam belt then rotate the crank one revolution and fit the second cam belt. When the crank is lined up one cam will be at 12 o’clock and the other will be at 6 o’clock. This is the key to EA82 timing belt alignment - don’t miss that crank rotation between fitting belts!
  24. If you have fuel and you have spark, that means you might have a timing problem, either ignition or valve, or a compression problem. Check both timing belts are installed correctly. Check for top dead center compression stroke on #1 (feel for compression in the spark plug hole, then probe it to find the top of the stroke) and verify the rotor in the dist is pointing at your #1 spark plug wire at that time. Check compression, which will also find valve problems, like being adjusted too tight, not seating, etc.
  25. Prepare your thinking caps. I've recently done a full rebuild (minus bottom end) of an SPFI EA82 and full reconditioning of the engine bay. The engine and manifold are a bit of a Frankenstein but both the engine ran, and all of the electronics (dizzy, throttle body, ECU, maf sensor, etc) came from a running engine. Air: I just redid the head gaskets (that's why I'm trying to start this thing up and clearly failing) the heads were fully reconditioned (valves and seats ground, new valve seals, new guides, new lifters, head resurfaced). Deck was meticulously cleaned. All new seals on the throttle body. All new hoses everywhere of the proper metric sizes. It definitely has compression. Fuel: Pump is noisy but it ran the engine previously. Injector is firing and spray pattern from what I can tell looks okay. I did have an issue of coolant leaking from the throttle body into the intake but I removed the plugs and cranked it over for a few seconds a couple of times to hopefully blow all that into the exhaust or out the spark plug holes. Coolant leak looks to be resolved (looking past the throttle plate with WOT and injector disconnect while cranking). Fuel has been sitting for about 10 months with a stabilizer added while I've been gathering parts and meticulously working on this thing by the book. But even when I spray ether into the intake, it doesn't fire. It sounds more promising with the ether. I let it air out with spark plugs removed, disconnected the injector and tried to run it off ether. It sounded like it really wanted to kick over (*faint* whomp-whomp-whomp-whomp). TPS is set up properly and tests okay. Spark: It has spark on all 4 plugs, proper gaps, tested body & engine grounds for resistance (0.3-0.4 ohm from the ground to the battery). No codes from ECU. Dizzy is properly phased with the cams, it should be in a good enough range to at least kick over, maybe not run perfectly but it's in the proper range to run. I'm at a bit of a loss here, anything stand out to anyone or any thoughts or opinions? I have an FSM and I can go through everything in the troubleshooting diagram. I'm just confused, I have all the ingredients for fire but success evades me currently. Thanks :]
  1. Load more activity
