All Activity
- Past hour
el_freddo started following Doh! Chipped a Shoe
Doh! Chipped a Shoe
el_freddo replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Personally I’d run it as it’s a small area - and you’re aware of it. That said, I’m no brake expert and others may disagree. - Today
I've been redoing all my wheel bearings, seals, and brakes. While pulling a late one (tonight, literally minutes ago) as I was putting on my new drum I chipped a shoe. I didn't have the auto adjuster fully backed out, only 2 or 3 teeth until it was fully backed out and the shoe must not have been sitting perfectly concentric with the drum. Either way, it's about the size of a grain of rice. Should I replace my mistake or let it go? This is my first time fully redoing drum brakes. Don't worry, I cleaned up the excess brake lube. That stuff's like anti seize. One drop can paint a house.
Something happened to the engine
oczuk32 replied to oczuk32's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks, I'm in California I could just imagine shipping cost. The radiator shop I found has good reputation on repairing fuel tanks. From low budget to high end customize fuel tanks. And I'm going for the low budget repair. -
Things are moving well but could be doing better making space faster. Another call out to the masses. If you can make it by Milford CT you’d do well. Other guys have driven over 11 1/2 hours to get here in the past. This is IT. We are ending our involvement with that stage and devoting all efforts to 1972-77 stage one. Lots of 1977 stage two through 1979 parts and Gen One Brat.
Brand new Subaru owner, 2016 Subaru Impreza
moosens replied to streible's topic in Meet n' Greet. Your USMB Welcome Center
Welcome. All I can say is my friend has a 2017 same as yours and he loves it. Took a deer strike with bad damage and they made it like new. He and I are long time Subaru owners going back decades. We’ve have them all, pretty much. And of the current later models we don’t see ourselves jumping into a Legacy. -
moosens replied to oczuk32's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just a suggestion for the tank if you take it serious and want it around for maybe the next generation or so. Moyer in PA does an awesome job. If I could post pics easily I’d show you. They blast is rust free inside and out, do repairs if necessary, and treat it with their own patented formula which is NOT epoxy and good for all fuels. Tank looks ready for another 50 years. Good luck with it. -
Updates... Was able to get it started again. Yes it's the old varnish gasoline that created that slick coating on the cylinder. Reason I know is cause I drain the 4 gallons of gasoline and filter it back to my Suzuki Samurai to burn it off. The next day I went to start my Suzuki. I got the same slick no start issue. Took some starting fluid to crank the engine on. Crazy that fuel would cause that. Gave me reason to take a trip to the mountains to completely burn off the fuel. The Subaru fuel tank has come out and discover a huge layer of sludge and rust. Drop it off at a radiator shop and see if it could be saved.Updates… I managed to get it started again. Turns out the old varnished gasoline was creating a slick coating on the cylinder. I figured it out after draining 4 gallons and filtering it into my Suzuki Samurai to burn off. The next day, when I tried starting the Suzuki, I ran into the same slick no-start issue. A little starting fluid finally got the engine to crank. Crazy that the fuel I added just days prior could varnish so quickly! At least it gave me an excuse to take a mountain trip to burn it off completely. As for the Subaru, I pulled the fuel tank and found a thick layer of sludge and rust, so I dropped it off at a radiator shop to see if it can be saved. Bushytails you were smack on on the that issue. -
I ended up with a brand new 00-04 Outback H6 power steering rack, part number 34110AE20A. Curious to know if I would run into any issues installing this into my 4-cyl 2003 Outback, as I found a bit of steering fluid pooled up in my rack bellow when I went to swap an end link out. If I could just throw this rack in and align the thing, that would be awesome. Thanks for any/all help!
- Yesterday
1986 GL Wagon - Potential Revival
SuspiciousPizza replied to PrinterTechnician's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What I've learned refurbishing my 3rd gen wagon (89 GL). Parts: Hoard them. Buy yourself an ultrasonic cleaner because there's gonna be a lot of greasy used parts you'll need to clean if you intend to run this car for any period of time. Engine: EA82's are simple to teardown. However, aluminum threads don't like to be abused. Be careful with exhaust flanges and intake manifold bolts. They tend to strip or corrode in some form or another. Pistons, connecting rods, valve springs, valves, valve retainers, oil pumps, OEM water pumps, cylinder heads without deep cracks, oil pickups, and more can be difficult to find. Luckily you're in the right place to find them but still. There's a reason EA82's have gone the way of the dodo. Buying a good parts engine (if you can find one) isn't a bad idea. Suspension: Front struts and good quality front strut mounts are difficult to find. The chinesium parts that makes up 80% of the parts market for these cars usually aren't worth giving the time of day. Look at DRW Bushings for suspension bushings. I've been very impressed with the bushings and the owner's communication, I'd highly recommend. Springs can be hard to find, there are overload springs out there. Wheels & Bearings: 4x140 is going to be your biggest hurdle. Looks like you've got a set of shallow wagon wheels (I'm jealous). It's just difficult to find known good wheels, new 4x140 wheels are quite obscure. Bearings aren't too bad if you have a bearing puller. Honestly the seals can put up more of a fight than the bearings. Remember to replace your axle nut spring washers. Axles: If they're not rusty and crusty, clean them and reboot them. Buy neoprene boots, I recommend EMPI. I use Yamalube ACC-MOLDM-GS-05. Use what you like but it's good grease. You may find out, if you haven't already, that if you do need to replace an axle, it's difficult to buy "the right one". There are multiple different axles (4 or 5, I can't remember) that are used depending on the cars drivetrain and fuel delivery system. Stay away from most cheap axles. Sometimes remans are okay but your best bet is used OEM that have been cleaned and rebooted. Get familiar with the identification bands on the axle shafts near the outer boot and your axle spline count. Outer axle joints cannot be disassembled, to clean wipe the grease off and pour a cleaning solvent into the joint. Pour out the sludge and wipe away the rest. Let the solvent off gas and repack with grease. Interior: Speedometer cables and throttle cables can be difficult to find. Yes there are cheap parts put there, but those are always a crap shoot. The foam on the HVAC blend doors has probably severely degraded and that will cause issues with actually feeling the full effect of your HVAC system. I'd recommend replacing the foam. Once you've torn the dash off, its easy to do again. Getting it back together can be a pain with the HVAC controls (4 vacuum hoses and a cable). Plastic trim pieces are NLA and will have to be a junkyard, craigslist, or eBay find. If you decide to manual swap the car, get a pedal box from a later GL or a Loyale. Older pedal boxes are prone to cracking. Glass: Junkyard. Literature: Get a copy of a parts manual and I'd also recommend a hardcopy of the factory service manual set. Yes you can find them mostly online but having a hardcopy is very helpful. Good luck :] -
moosens replied to PrinterTechnician's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Lots of thoughts on going forward. But in general for now to just rehabilitate the carb’d EA82 that’ll be a bit of a project. Not so bad really but these days we see most folks immediately ditch the old power plant and sometimes as needed the drivetrain too. You have the last of the carb’d engines. In 1987 it’s a split year. You’ll find DL wagons and sedans with the carb until a certain production date. Then they’re SPFI. You can swap blocks and blank off the EGR ports in the exhaust should you want to try making it SPFI. Been ages for me since I’ve had that era but we had so many between parts cars and drivers. Pretty much all my stash is gone from that era. I never had any real trouble with the Hitachi in general from the 70s through the last of them. But those last run carbs have more emission crap and can in my opinion be more finicky. Less manageable. But they’re carbs so it’s always a little bit of luck and black magic. lol EA82 engine parts - the timing belts are hard to find or at least the drivers side which is the one that typically craps out. Oil pump. Reseal kits, you can imagine what it’s like now. There is zero support with very little exception. Carl Porter has some NOS from that era. He might see this here or find him on FB with the usual old school Subaru groups. West coast dealers you might get lucky. This era unfortunately comes with the New Subaru World Order when they made lots of threats to the new wave of dealers to scrap outgoing inventory and damage panels, components, etc so nobody could dumpster dive. So the spares left or much harder to come by than the 70s. It’s a sad story but at least parts lived on. History story: when the Subaru finally caught on here the kind folks at SOA headquarters decided that no longer would their cars be dealt out of mom n pop corner garages and such but they’d have to have a large parcel and big $ to invest. So many mom n pop dealerships closed up and we NOT allowed to sell their parts to the new dealers or back to SOA. Seversl large lots of NOS came to the public. I’m still selling off some of mine. But come the 80s it’s corporate control. Hope you enjoyed the read and enjoy that wagon. Took my young family on many vacations and romps in those. Another several paragraphs of stories there at least. Cheers! -
They replaced the slave. If they give me the old one, I might investigate rebuilding it and keep it with the other spares I have for the car. With fresh fluid and a bleed, maybe the master will be ok, if not, it's the onley thing left so, I might tackle it myself but really guys, maintenance and repair work is getting to be a challenge for me nowadays.
- Last week
bushytails replied to PrinterTechnician's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's a lot cleaner than any you see here! Good choice for a project. Stuck thermostat also can cause overheating and foaming, but head gasket isn't too bad of a project. The stock carbs aren't terrible, and often can be fixed with just a cleaning, being careful not to tear gaskets. Brake booster and master cylinder are usually reliable; no need to replace them unless you have issues. Try ebay or junkyards for better headlights. -
Good morning to everyone on this beautiful Sunday, I'm posting here because this is the first time I've ever purchased a Subaru in my life. I completed the purchase of 2016 Subaru Impreza on Friday, after my 2019 Mitsubishi Mirage G4 ES was totaled on 8/20. I wasn't in the vehicle. It was parked and I was already in bed when I heard the crash, so I went outside only to discover that my car was sitting in the street, plowed into a Mercedes-Benz. I came across the Subaru after two weeks of search and used Cars.com. It came from Emerson, NJ and I drove it home this weekend. I rented a car, one-way rental, and drove the Subaru almost 400 miles over the weekend, back home. I admit, I'm taken with this car. 91K miles, one owner, no accidents, no rust, immaculate interior, except for the boot around the emergency brake that has to be replaced since it's ripped, mostly due to age, but what a car! Jade Green, 2.0L engine, 5 speed manual transmission. It had been sitting on the lot since July 18th because no one wants a car with a manual transmission anymore, but I did, so here we are. Thanks for entry into the forum, Steve
PrinterTechnician started following 1986 GL Wagon - Potential Revival
Hello. I apologize if this is the wrong place to post this. I recently acquired this 1986 Subaru GL Wagon AWD/3spd auto. I made an account here a few years back while helping a friend with his '87 Brat. If I'd never worked on that Brat I wouldn't have given this $500 listing the time of day. The car is relatively clean for sitting in field in Odessa, TX exposed for a decade. Some rust under the cowl visible from the engine bay from debris sitting in it. Then some from a failed brake booster or master cylinder that was leaking. I'm technically the second owner since the guy I bought it from didn't register it, tried getting it to run off the fuel tank, failed, and gave up on it. Today I got around to setting up a Home Depot bucket fuel pump setup and ran it straight to the carb. I changed the oil and filter because the filter looked ancient, topped the radiator and reservoir off with some distilled water, and charged up the battery. I was surprised when the car eventually was able to run on it's own at about 1200-1500rpm. The carb was dripping fuel so I didn't want to run it long. The temp gauge climbed up a bit past halfway, so I quickly set some bricks around the tires to test the transmission without rolling away. I was able to roll forward and backward so I called that a success and shut it down. I noticed a burp in the coolant reservoir and some bubbles inside for about a minute after shutoff. I'll do a combustion leak test on it to verify. I'm going to list some major items that will need to be addressed before it even goes on a test drive. Engine - Verify if this engine needs head gaskets. Then go through cooling system and timing belt. Carburetor - Weber swap or try and work on this stock Hitachi Complete braking system refresh - Including the booster, master cylinder, and rubber lines. Transmission Drain/Fill and filter. Some less major items that will need to be addressed. Headlights housings are rusted through and don't work (I guess from filling up with water?) I'd probably try and find some sealed beam DL headlights and grille. CV Axles - All 4 CV boots are leaking and they'll probably fail pretty quickly. Suspension looks original. Door locks don't work and the passenger rear door is stuck shut. Rear hatch struts. left turn signal works with hazards but not stalk. No spare tire. But I have all the hardware that retained it. I think the battle going forward is going to be parts availability. I'm spoiled from working on Toyotas. I remember struggling to even find shocks for my friend's '87 Brat. The automatic transmission is also a downside if it ends up having issues. I've found a number of great write-ups on this forum and some other websites so I have that on my side. Here are some pictures and videos to go with my random assortment of thoughts.
circuitsubie joined the community
berbecs joined the community
Belated follow up: I did the battery disconnect thing several times with no effect. I did the key on/engine off and cycle the throttle 3 times slowly with no effect. I took off the cover to check the TPS. I removed ~1/8 slack from both throttle cables. I disconnected the TPS and checked the system voltage and ground connections. I did not check the TPS action since I didn't have time to take off the air box to access it's pins. I noticed when I had the TPS disconnected and ignition on that here was a continuous low buzzing sound going on some where in the engine compartment. I disconnected the battery again, pressed the brake, turned the ignition on and off. After hooking it all back up I found that it had greatly improved. It's like a new car taking off or trying to accelerate into traffic. Not sure exactly what did it, but the only real new thing I did was disconnect the TPS for a while and take the slack out of the cables. I would have thought the cable slack would only cause some initial dead action at the beginning of throttle application. Cruise control engagement is also much quicker and I don't have to hold the throttle set for a few seconds waiting for it to pick up the slack anymore. Hope this helps someone else.
1986 GL10 Turbo Distributor and Turbo help
el_freddo replied to itb482's topic in Old Gen.: 80's GL/DL/XT/Loyales...
@itb482 - what’s your dizzy doing or not doing that requires it to be replaced? My first thought was to have the cam belts checked to make sure they’re not broken. If the LHS belt is broken your dizzy and cam won’t spin when cranking. I doubt you’ll find a turbo any better than the one you have now. You might be able to adapt a new one from a turbo ATV, they’re probably about the right size. Cheers Bennie -
SuspiciousPizza replied to itb482's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a parts guy, we're going to get in contact this weekend (he's busy out of town at the moment) to see when we can meet. I need to get over there asap to pick up an engine while mine out of my GL is being rebuilt (6 months at this point). I know he's got a turbo car, no clue on his prices. If you PM me a list of parts (stuff you'd want for the future?), I'll ask. I know he's got a turbo car sitting there. I also have a turbo cylinder head I'm not going to use since mine is N/A. I just got it for a really good price. If you're interested PM me and lmk. :] P.S. https://turbochargersdirect.com/turbochargers-direct-remanufactured-oem-turbo-for-subaru-gl-xt-rx-and-loyale-1-8l-tur-106018-tdr/?srsltid=AfmBOoqOzF6v587m_TyQszG6yslhtNdmZ1ZJRiWPfLog9jMkZBbPHLPI
