Everything posted by DaveT
- Leone wagon ea82 head problem
- 1989 GL-10 Oil Pressure Sender Thread Size
Ignition timing adjustment issues
Timing marks are on the flywheel. Could the timing belt be off 1 tooth? Are the bearings in the distributor good? A bad connection or ground could be interfering with something. The fsm has pretty detailed checks for all of the sensors. You also should check them from the ecu connector end, not just the sensor alone.
91 to 83 Transmission Compatibility
Yes, governor stuck could be also. Had one get sticky in my 86, a long long time ago.
One of my 3ATs lost 3rd and reverse. All it was was a small tube that fell out of the valve body to the band piston. So it could be something simple / stupid.
Remedies for substandard replacement auto parts
DaveT replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe other thing about lifetime warrantees is that they count on you selling the car before it breaks.
'93 Loyale oil leak, coolant loss and gurgling noise. Head gasket?
I think it is supposed to be flush on the outer surface, not pressed all the way in. I'm not where I can double check right now. I know the camshaft seal are not pressed in past flush.
I know they fit mix match 86 through 93, if they have ea82 engines. I am not sure about 83s. The flywheel is different between at and manual. There may be a difference in driveshaft length, in which case you would have to swap that also.
O-rings
Try industrial suppliers - MSCdirect.com McMastercarr.com I have bought both packets of 100 and assortments from them. They also have different grades & materials. Ordinary o rings are very affordable, small ones, 100 only cost a few $. IIRC, most normal car size ones, they don't sell individual, but the price for whatever quantity [varies with the size] is not crazy, and you have lots of spares.
axle compatibility
What part broke? Maybe part of the EA82 ones are the same, and the length is just the long shaft?
Looking for advice... 87 Subaru RX EA82T bloen
By the age and miles, it would be no surprise that either an intake or head gasket developed a slow leak. Leading to running over normal temperature while low on coolant. This damages the headgaskets. Can be minor, and nursed along for months, or bad making it un runable. Or anything in between. Either way, once the process has begun, it only gets worse. If one side is that blown, the other can't be good. It will also be leaking oil like mad anyway, simply due to age. If it was never run extremely hot, do a full reseal, and it should be good for at least another 100K, assuming you keep the cooling system at 100%.
Dl's anybody?
There are lots of old threads on here about experimenting and trying to get more power out of EA82s. Lots of money, and or lots of time for small gains. Some of them have all the details as to why.
- '84 GL Wagon throttle delay (39K original miles)
Unplugged Wires Under Hood? Driver side?
Thete is a whole procedure to follow using those connectors. One for read memory, another for clear memory.
I happen to have a printout of various engine HP vs models right here... EA82 SPFI = 90HP @ 5600RPM EA82T = 115HP @ 5200RPM EJ-18 = 110HP @ 5600RPM EJ22 90-93 = 130HP @ 5600RPM EJ22 95-96 = 135HP @ 5400RPM
ea82 not starting slight back fire and code 42
EA82 SPFI is the same for all years it was made, so nothing to worry about there. The fuel injector should click and spray a noticeable burst of fuel while cranking. Use an ohm meter, check for about 2 ohms between it's 2 wires. Also check for open circuit between 1 of the wires and the throttle body. I have also tested them to verify opening by applying 12V from the battery across the 2 wires - unhooked from the ECU of course. There should be fuel pressure held for hours after a cranking, so this will spray fuel if it is working. Do not make or break the connections near the throttle body, make and break the last connection near the battery! Don't hold it on for a long time, just a few taps is all you need to see it functioning.
ea82 oil pan removal
The recording isn't high fidelity, but it does sound like lifter tick, at least rythm wise. Rod knock has a lower frequency component to the sound. If it is mostly constant. it may be 1 stick lifter. When it's the oil pump seals, it tends to vary more. As in come and go, and more or fewer lifters ticking.
There are a lot of threads about the timing belts, and links to youtube videos. I'd check that next.
Did it ever run? Check that the distributor rotor turn when you crank it.
95 subaru legacy starts 50% and clicks w/o starting 50%
DaveT replied to Grumble7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe fuse is nesisary. If somehow that wire ever shorted to ground, you have an instant flash fire. I almost burned down my first Subaru years ago due to fuse not in the proper location, ie. Close to the power feed source.
