Everything posted by Durania
Power Steering Fluid: ATF Dexron
Durania replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood to hear you changed it back to atf. You're not the first one to make that mistake so don't feel bad.
trunk
Durania replied to woodi9er's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can't imagine replacing that cable to be fun. Be glad, my 05 STi doesn't even get a remote trunk release.
BOV on ea82
100% agree. They are also especially obnoxious. You have bigger fish to worry about on that motor than making duck noises.
Ea 81 slop
Remember the valve cover gaskets are cork and do not require a ton of torque. Just snug them up or you will be in a world of hurt. Fel-Pro is the best bet.
Lug Nut Size
Durania replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust for curiosity, what's the called for torque on the lug nuts?
is your car comfortable to drive? need replacement seat suggestion.
Durania replied to afterbang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCorrect. I had to retrofit the buckle from the Outback seat onto the wrx one. I expected it since I had the same seats in my old 2.5RS.
BRZ-STI well, is worth the lo-ooo-ong wait?
Durania replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI lost interest in this car years ago. It has been a load of media wishy washy hype for the last 6 years. I too, have no need in a coupe, even less need in a RWD.
2002 Legacy clicking noise, what is causing it?
Durania replied to Ionlyhave3suubs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJack up the side you want to check. Grab the tire at 12 and 6 o'clock. Check for in and out movement.
Durania replied to afterbang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have an 03 WRX seat in my 95 Outback. It does raise you up a good inch or two and have to raise the steering wheel. It was a great price to pay to get rid of that busted rump roast cloth seat that I did have.
pedal rubbers
Durania replied to turboguzzi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX36015GA111
Strong gas smell at startup
Durania replied to newsooby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe recall was actually just for the 02-03 WRX, not sure if the OBS/RS got the recall or not. A lot of 04 STi owners complained of the problem but the recall did not apply to them. The recalls calls for the removal of the intake manifold and replace the fuel lines.
pedal rubbers
Durania replied to turboguzzi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://opposedforces.com/parts/legacy/us_b11/type_24/manipulation/pedal_system_mt/
Durania replied to Ionlyhave3suubs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX02 Outback should have alloy wheels.
EA guy looking at used 1st gen Legacy wagon, what should I be looking for?
Durania replied to Dogbone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXQuoted for 100% truth. Those first gen Legacies are amazing. If it wasn't for a worn out 250k 4EAT, I would still have my 91.
1996 legacy 2.2 no power
Durania replied to boatrick1234's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKnock sensor would be a good place to start. Make sure when putting the new one on, don't overtorque the dickens out of it and clean the mating surface.
Power Steering Issues
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDidn't do it pulling out of the parking lot, let's hope it doesn't do it again. Thanks for the belt advice guys.
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't really call it a belt "squeal" but more along the lines of a chirp. I definitely did not hear it this morning when I started the car. Didn't feel any resistance either. True test will be this evening when I get off work where I park on a slight incline with the motor higher than the rest of the car.
Doe anyone know my Brat
Let's see some pictures of the brat.
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had my father in law turn the wheel before replacing the belt and I looked inside the reservoir for bubbles. All was well there. Replaced the belt this evening. I noticed that on the old belt, the tensioning bolt that runs through the one that allows the 12mm to bolt to the alternator was fully threaded. With the new one, it is now 1 1/4 inches lower from the top. I used a turkey baster to inspect the ATF fluid, besides being a tad dark, it was fine. I didn't hear the squeak from the power steering pump but I will double check in the morning when I warm it up for the drive in.
Is my 2001 Legacy 2.5 SOHC on Interference motor, or NOT?
Durania replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have never heard of an engine referred to as "Free-wheeling" so I used the googler. http://www.google.com/search?q=free+wheeling+engine&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a First result.
Durania replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInterference.
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPrevious owner told me he had the belts replaced a few months before I bought it last November. The belts look to be in good shape and free from cracking. They do say Made in Mexico on them so they may not be of the best quality. I do understand that my ps pump takes ATF, not conventional power steering fluid. I dipped my ratchet handle down in the reservoir yesterday and the fluid did look to be transparent like ps/brake fluid and not red. After it gets warmed up, it does just fine and not getting a whine like you normally hear when one is going out.
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk man. Beats spending $130 on a new pump.
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did notice that I had a squeak and I narrowed it down to the ps pump itself. It too went away when the car was up to temperature.
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thunk the belt is like a year and a half old. Will check for play when I get out.
