Durania
Everything posted by Durania
  1. I really think the bearing has went bad in it. I stop getting the resistance once up to operating temp.
  2. Junkyards around here are kind of lacking on the newer stuff. May throw a WTB ad up on Nasioc.
  3. May just have to pick one up from Advance. Will a reman unit come with the pulley on it?
  4. I have a strong resistance when turning out and into parking spots. I had my wife turn the wheel while I watched the pump. The pulley would intermittently stop for a split second. Figured that a bearing was failing in it. I have no loss of fluid from what I can tell and smell since it uses ATF.
  5. I believe yours is a group size 35. You can get some great deals at Advance Auto by using in store pickup after buying online and using coupon codes. http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/subcategory_Batteries_13556_13559_10151_10051_-1___ http://www.retailmenot.com/view/advanceautoparts.com
  6. The pump is going out on my STi and friend has a wrecked 05 LGT that has a working ps pump. Will it work?
  7. I thought some auto parts stores could check them in house.
  8. I agree 100%. Bugeye wrx's are dirt cheap. You will also never get a good return on your swap when it comes time to sell it.
  9. You will have to change to a turbo crossmember. I can tell you that much. Tons of info available here: http://www.rs25.com/forums/
  10. 93-01 but you need to get it from the same body style that you have. Sedan for Sedan, Coupe for Coupe etc. I am unsure if wagon will work on sedan though.
  11. I used diluted simple green combined with a finger nail brush like you would get in the dishwashing soap aisle. I cleaned my STi and outback in about 20 minutes each.
  12. Common problem http://www.ultimatesubaru.org/forum/showthread.php?t=126415
  13. I still have a nasty stain in my driveway from where mine leaked out when I get home one day. I would run it through the car wash before tackling just to knock off the dirt and debris.
  14. Here is my thread from a few months ago. I got an entire kit from Annapolis Subaru and that was worth it's weight in gold. http://www.ultimatesubaru.org/forum/showthread.php?t=124285
  15. 99 Forester 5MT. Not mine, friend just sent me this picture.
  16. It's pretty easy. Remove spare tire, located on the driver's side of the bell housing.
  17. I had a WRX headunit in my 95 Outback. It's plug and play.
  18. 05 STi that will soon be for sale 95 Outback (Now has JDM tails)
  19. I just finished swapping all of the springs out on my STi last month for the factory ones. Not in any hurry to do that again. Would love to find a set of Forester take offs for her.
