Everything posted by Durania
new clutch; pedal has a soft spring to it
Durania replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, call the dealer and get you a slave cylinder for your car, then bleed the system once installed. I think its like a $60-$80 part. Its best to have someone with you when bleeding the slave cylinder.
Durania replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year and model is the car for starts? Sounds to me like text book slave cylinder failure. (Of course that depends on your MY)
91 Subaru erratic idle
Durania replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKinda had to assume it was a legacy since it was said to be a 91, or a misplaced Loyale or XT6.
Durania replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a bad MAF cause some of the symptoms that you are mentioning. Any check engine lights?
All new gen subarus 5x100?
Durania replied to Devil240Z's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCorrect, these wheels are 5x114.3.
EA-81 oil pan drain plug part number?
You able to call any of these listed here? http://maps.google.com/maps?q=staunton%20virginia%20subaru&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&sa=N&hl=en&tab=wl
A low fuel light?!
Durania replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 1986 RHD Lifted, 1984 brat. Should I buy?
Buy the RHD one if you are buying it to beat on it in the woods, leave the rust free one alone.- EA-81 oil pan drain plug part number?
Call your dealer. I ordered one for my BRAT and it was like 3 or 4 dollars.- 1986 RHD Lifted, 1984 brat. Should I buy?
I remember seeing it on CL years ago in NC, dude wanted way too much for it then. Thats some pretty bad body rot so you really need to think long and hard about how long this thing will last you.- 2005 Forester will not start
Durania replied to Tim Hausler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCoolant temperature sensor does sound like a good place to start.- My 86 GL 4x4 wagon. Not many this green?
That body style wagon in the white spoke wheels looks gorgeous.- Brat fun roof / t-top drain?
Good point. Are you referring to the two tabs with grooves that slide into the roof?- I know, I know, I should just replace it
Durania replied to griffenrider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDude, it's a .50 cent part.- Brat fun roof / t-top drain?
The only issue I had with my brat leaking was the bottom of the windshield corners allowing water to pool up and run inside down the inside rocker cover and pool in the floor board.- Typical parts cost - phase II 2.5 HG job?
Durania replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPhase II's shouldnt be going through them that fast. From what I know, the I's were the ones that developed the internal leaks that blew a lot. The II's on the other hand, developed external leaks but once replaced were good to go. My Subaru mechanic told me that the problem is people put them on way too tight.- Time for Show and Tell
EJ33?- My "Show" Brat makes it to WCSS11 and back!
Looks great, I had an '83 Cosmic Blue BRAT myself.- My "Show" Brat makes it to WCSS11 and back!
Got any more pictures?- Got the Outback!!! (Pics page 2)
Durania replied to Subaru_dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you going to be swapping over the ooogah horn?- 5 Lug Swap...yes I looked
I support this decision. You say your wanting WRX wheels and brembos, STi brembos I assume. I fail to see the reason for wanting such a high performance braking system on a loyale. Have you checked the price of brembos, better yet pads for them? I would take the money you are about to drop for a 5 lug kit from Australia and put a good deposit down on the bugeye. You will already have the WRX wheels and dual piston front calipers so that way your already ahead.- Heated Seats
Durania replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSome good reads here: http://www.ultimatesubaru.org/forum/search.php?searchid=820284- Heated Seats
Durania replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI vaguely remember something as well. The post involved someone changing out the heating element. Of course I might be confused with a DIY on a electric water heater.- Typical parts cost - phase II 2.5 HG job?
Durania replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis. Can you confirm that it does have the SOHC 2.5 in it?- Time for Show and Tell
I like it. Make them Lebarons jealous. - 1986 RHD Lifted, 1984 brat. Should I buy?
