Durania
Everything posted by Durania
  1. I'll take my t-tops over the bed covers anyday.
  2. The GMB one was all that was in stock that day at autozone. I added it up and it was cheaper to fix Brat with that water pump than it would have been to fill the Legacy back up with gas. I have drove it about 50 miles since installed and it has yet to get above the notch on the heat hand. If the GMB one had said "Made in Mexico" on it, and not Japan. Things might have been a little bit different about me getting that one from the autozone.
  3. I considered the other day going up to the Harbor Freight and buying a shop press. For the price that I have paid for a machine shop to press bearings into a hub, I could have bought my own press and done it myself and not have to rely on someone during the week to do it.
  4. 20 years later and it's still giving back to you.
  5. I hope you know how hard it is for me to look at them pictures. Hope you got more than that?
  6. The one I pulled off is an exact match for the one I put on. GMB made in Japan. I pulled alternator to give myself some room. Subaru could have picked better bolts than those to hold the water pump on. Looked like they would do a better job at holding a table together but, if it works. Used black RTV and waited an hour. Took it to town with highway and city driving, it didn't get above the notch and had great heat, even though it was 66 degrees. Thanks for the helps guys. Next week something else will break.
  7. It has never sat there is why I was posting. It has always been at that little notch.
  8. He's 100% right. You will be surprised at all the things that can be solved by getting a new alternator.
  9. I am kinda worried about that power steering unit. The fluid those things take is liquid gold. $500 is about all I would give. Truly depends on what it looks like underneath. Connie's didn't look nowhere near as bad as this one and she started parting hers' out.
  10. No I sure wouldn't. :-p
  11. I kinda like that shifter knob you got there, would look good in my blue brat.
  12. I am not having any leaking yet. But the motor is getting hot, I am having just a tad less heat. I found a water pump on 1stSubaru parts for $53.24, if Subaru doesn't have a gasket tomorrow, I will be ordering it. This was me going about 45-50 MPH:
  13. I checked the one in my hatchback and it feels about the same. Whats the link to a genuine Subaru parts site that would have it and the gasket in?
  14. I have already emailed CCR about getting a MWE axle, I got the number to another guy to call at a later date.
  15. Don't beat around the bush with alternators. Its an easy fix, don't drive around with the alternator about to go out, you'll be paying for a tow ride home.
  16. I am going to call the dealer early Monday morning and hope they have a gasket in stock. The pump on this thing has been replaced before, I can see all the extra sealant material around the edges, I look forward to getting all the stuff off. I will probably snag the water pump off my hatchback and use it, I had no issues from it. I have been looking at the FSM and it looks to be 5 bolts, looks to be 12mm. The hoses are fine and look to have been replaced before. I use this picture a lot and it shows where the threads look to be coated in this blue junk.
  17. I have had a lot of goofy issues that were caused by bad alternators. Replace it and go from there.
  18. On the bottom one, I believe it to be the brass looking fitting to the 5 o'clock position relative to Japan. Thanks to PoorManzImpreza for the pic.
  19. I did some research on here and found that if a water pump shaft is loose, then it is usually a sign that it is going bad. I flushed the crap out of cooling two weeks ago and things have been fine. Driving around town yesterday I noticed that my temp gauge was just a tad high and my heat temperature was feeling low coming out of the vents. Today, I took it up the road today and got things up to operating temperatures and came back home. Popped the hood and felt the front of the rounded part of the water pump and I could feel play in it, not much, but could tell. Is it time to replace?
  20. Nipper is right. Subaru alternators are easy to change and can be done with just a regular ratchet set. That many miles, it should be about time for it to go anyway.
  21. Gary, off the top of your head, what is the current going rate for Subaru axles?
  22. What do you mean, click into place?
