Everything posted by Durania
09 Forester thoughts???
Durania replied to chef_tim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo temperature gauge?
Question about Mass Air Flow sensor
Durania replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 This is how I tested mine when I pulled the check engine codes. Sounds exactly like your describing.
Tach gradually stopped working, comes to life with fan
- Another Heating Issue (Flushed!)
Just went to town and back, this is exactly what it is doing. When flushing the core this weekend, do I need to use some kind of chemical solution or will just a pressure nozzle on a garden hose be sufficient?- Tach gradually stopped working, comes to life with fan
- Signs that the Head Gasket is going????
Did you check and see if there are coolant droplets on the dipstick when checking oil?- Another Heating Issue (Flushed!)
The only leak that I get is from the overflow line off the side of the radiator. I checked for oil coolant and am not burning coolant either as motor still runs strong. Frank that sounds like a good idea as sometimes I have heat coming out of vents but when put in the "heat" position it blows cool air. Hopefully this weekend, cooling system will be douched and things will show some different results. What does this valve look like?- Imprezzzzzzzzzzzza
Durania replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEven I know that. I have seen your hockey message next to your avatar for six months.- Another Heating Issue (Flushed!)
Test will be re-administered in a day or so and will compare new readings from the ones today.- FWD 5 Speed to AWD Automatic????
1. Welcome to USMB. 2. Greetings from 70 miles to your west.- Another Heating Issue (Flushed!)
I took some temperature readings with a laser tool today. All units are in the Fahrenheit scale. Taking after 15 minutes of idling with radiator cap off. Outside Temp. 55° Center of radiator-92° Inside of radiator-99° Bottom of radiator-140° Lower Radiator house-136° Water pump-170° Upper radiator hose-135° Thermostat housing where it meets intake manifold-170° 1 & 3 Cylinder head-220° 2 & 4 Cylinder head-193° Heater hose to heater core-169° Heater hose return-116° Air temp coming out of vents-79°- Another Heating Issue (Flushed!)
I have been dealing with heating issues all week. Got to thinking about how the car will have a little heat and then a minute or so later will blow cool air, worse when in the "heat" position. Got to thinking that maybe the OEM thermostat is stuck half open and not letting enough coolant circulate back through the system. I ordered another one today and should be here Friday. Thinking will give heater core a good flushing next time I get a chance, with a good nozzle. Buddy has a laser temperature reader and will check things tomorrow when up to "normal" operating temperatures. Opinions?- Imprezzzzzzzzzzzza
Durania replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere we go again. I personally love the 5 doors, drove the WRX and liked it too. I personally think the sedans look cheap, but still would own one.- Dipstick discrepancy?
Are you taking into account the filters capacity?- ea-81 headlight malfunction
Swing by and pick you one up from the parts store. Have fun though, every EA81's headlights I have had to replace have rusty brackets and take forever to get them out.- 86BRATMAN Meets Durania717 (Big Pics)
It is has the optional Fred Flinstone ABS braking system installed. I would still like to know where in the world the jump seats and the tail gate is to the bloody thing, probably 3 towns over in somebody's barn.- 86BRATMAN Meets Durania717 (Big Pics)
It had been sitting under a bunch of trees loaded down with logs since 1993. Only had 65K on it.- 2008 Rally Mexico
Downloaded Rally Mexico the other night, I should be watching it Friday night.- 86BRATMAN Meets Durania717 (Big Pics)
I too am still exhausted and you drove all day. Too bad it was so muddy, I think things would have been better. I still plan on blowing the thing up as soon as we get your motor out.- 86BRATMAN Meets Durania717 (Big Pics)
Connie, he wore the next best thing to that shirt. The "My anger management class pisses me off" one. I have a pic but I don't think it is USMB approved.- 86BRATMAN Meets Durania717 (Big Pics)
Shannon and his wife Ashley came down for my last day of spring break today and turned into an all day Subaru filled tinker fest. Got quite a bit accomplished. Adjusted the Brat's valves, he brought me a battery hold down hook, chrome gas cap, and a bearing assembly for my Legacy. He is buying the hatchback and the motor out of white Brat. He pulled the dash out of my Brat in about 10 minutes, and the heater core in about 5. Learned a lot and was finally glad to meet him in person instead of on the phone all the time. Here is the pics.- Shifter Knob threads
That sure is a pretty shifter knob though. Thanks for looking though.- Shifter Knob threads
Cool, I always wanted one of them but in a 4 speed for my Brat.- New Subaru owner(90 Legacy)-need help!
Durania replied to jsellers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had the same issue but mine was the cause of a bad mass air flow sensor. You might want to give that a good looking at.- Shifter Knob threads
Cool fact of the day right there. Thanks Jerry. - Another Heating Issue (Flushed!)
