9
i understand how to make the blocks, my guess is they are designed to move the top of the struts to the outside of the car. what is the reason for doing this? i'm new to lifts.
towing an ae82 4wd wagon help
johnceggleston replied to captainkf's topic in Old Gen.: 80's GL/DL/XT/Loyales...
can i tow a 86 5 speed d/r in fwd and neutral with the front wheels on a dolly?? with out any damage? it seems like i should be able to, but i need to be sure. thanks, john -
i couldn't find dual port manifold exhaust gaskets at advance auto so i had to go to the dealer. same for the doughnut after the cats. (96 y pipe, 97 cats & mid pipe). but i would have used them if i could have found them. single port gaskets and the one between the cats, in front of the cats should be available.
when i first experienced this, i learned that dirty fluid / trans could cause it. when i took the extention housing apart, i assumed it was dirty gummed up duty c valve body or passage way. and maybe is sometimes. but it can also be gummed up sticky clutch plates and grooves worn into the hubs that the plates get hung up on. the way this thing works seems bassackward to me. bad or disconnected the duty c causes binding, but does that send more fluid pressure to the clutch plates or less, more i think. there is no pressure when the car is off, and the rear output shaft is not engaged then, but i can never keep it straight.
the top hose is on the passenger side of the rad and connects to the engine. burping on a hill, nose up will not hurt. but filling and idling the engine with the rad cap off untill it reaches full operating temp, temp guage reads normal and t-stat opens, will also work. once warmed up, if there is an air bubble, it should burp and the level of coolant will drop, fill rad the rest of the way and put on the cap. fill the over flow.
so i got back into it last week and found i only torqued 5 of the 6 water pump bolts, duh!!! i went ahead and pulled it to check the gasket, it looked fine. but since i had bought a new one i decided to replace it any way. i didn't want to have to do it again. i'll save it for another time, maybe. so i put it back together, and as i was starting to install the radiator, i remembered i didn't pull the pin on the tensioner. so back into it i go, yet again. by the way, how tight on the a/c and alt belts? i'm getting pretty good at this now. another 6 or 7 tries and i may get it right. thanks for tall the help.
i'm looking at a '89 gl/dl? fwd auto trans w/ fuel injection and a rebuilt ea82, new bearings, rings, reworked heads and a new fuel pump. the guy only drove it about 500 - 1000 miles after the rebuild when it started having fuel problems and was stalling. that's when he replaced the fuel pump. then he gave up and it's been sitting for over a year? could it be a fuel pressure regulator, do they even have them? i'm strickly new gen so i don't know any thing. suggestions? ideas? thanks john
dumb first timing belt mistakes torqued only 5 of the 6 water pump bolts. it leaked and i had to re- do everything, ugh. (side note: 3/8" sockets were too big for 2 of the bolts , i needed a 1/4" drive socket.) dumb second time mistakes when re-doing it because of the leaking water pump, i started to re-install the radiator, everything else was done, and remembered the tensioner. i didn't tighten the mounting bolts or pull the pin on the tensioner. the pulley and the belt have to be on before you do either of these, and then you are thinking covers so it's easy to forget, apparently. but at least i remembered. i think i better keep my day job.
the sending units are infamous for being inaccurate. my sons 95 legacy sat for a year before we replaced the trans. when we first started it, the guage didn't work at all, now it shows empty and only needs 12 gals. try running a bottle of techron fuel treatment through your next tank of gas, it may help. usually the low fuel light will still be accurate, about 2 gals left. if you figure out your gas mileage and reset your trip odometer you'll know how close to empty you really are. and hopefully the low fuel warning light will come on. if you search for techron here you'll find plenty of threads to read.
laptop
johnceggleston replied to mike97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
but then he'd have to get a cat and a monocle. -
as a scared rookie, i removed and replaced one plug at a time. disconnect one wire, remove the plug, install the new one and then the new wire. this way if i had a problem i still had the other 3 in good working order, and if i had to drive it to the shop i could. but you won't have to. you can also just do the wires first, one at a time, and see how it drives, just for grins. but then you'll have to wait for the engine cool off to proceed. good luck, even if you have to buy a ratchet extention, you'll save big doing it yourself.
