Everything posted by mattocs
I've got quite a bit of rust and holes on my drivers side rocker panel on my 1995 Legacy L. I know there are no direct replacements for it so I was trying to think of some ideas to repair it so it will pass a Pennsylvania state inspection. I was thinking about getting a piece of sheet metal as long as the panel and riveting it about a half inch below the doors and folding it under and finding something to rivet it on to. Then, fill it with expanding foam, Bondo if needed, and paint. Suggestions? Other ideas?
Leaking Coolant
mattocs replied to Bluga's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Both times my Subarus leaked coolant it was the water pump, and it dripped off of and covered the oil pan. -
Ah, ok. I'm sure it was mentioned being a stick and I missed it. I know when torque bind happens on a manual it suddenly happens and there is no fix for it. I've heard people suggest shaving tires down to match. I personally have never known anyone who's had that done. But if the rears are in good shape, try and find the same tire and have them adjusted to match. I wouldn't drive very far with the mismatched tires.
I've always bought four new tires on all my Subarus. The tires are supposed to be within 1/4" circumference of each other. If you can find two tires that match the rear ones that you say are good, you could find a shop that might be able shave them down to match. If its an automatic there is a fuse holder in the engine compartment on the passanger side firewall. Pop a 20A fuse in to put it in FWD. The danger of not having matching tires is torque bind. Its very common as the transmissions age. I'm sure someone else will chime in with more information. Good luck!
