Everything posted by mattocs
Headlight wiring \ driving lamps
I was wondering if I could rig up some driving lamps I just bought to come on only when my high beams are on. So my question is, the plug that powers the normal headlight bulbs, are one of those wires only powered when the high beams are on, and I can splice into it for the power of my driving lamps? Does this make sence? Any better way to do it?
Modifications for Import to Canada - 95 Legacy
mattocs replied to loachapoka's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSuperglue the light switch to the on position. When the car goes off, the lights go off...so you leave them on all the time. I am sure there is a way to bust open the little switch and wire them to be on always.
financing, Used vs. Rebuilt engines
mattocs replied to choly51505's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCCR engines seem to be very popular. Some people on the board have used them...maybe they'll chime in about them. From what I have heard they provide great products. If you don't want to spend that much, go to a junkyard and look for a cheap EJ22 to put in it.
Frosted Headlights: 96 Outback
mattocs replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the same problem, but mine is on the inside of the plastic.
need to find a replacement heater core!!!
mattocs replied to offroadsubaruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom what I can tell doing a bit of research, any 1990 - 1994 from a Legacy will work for you.
02 Leg/Out brake job...need expert input
mattocs replied to jgang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOEM pads for my 96 Outback are really good. Long lasting, quite, and low dusting. I am sure there are other good pads out there. I can go through a set of rotors and cheap pads in 10,000 miles...and the factory ones are much better than that.
Need a salvage yard
mattocs replied to ptrbilt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, they don't have any WRX...just some mid-90s Legacy, Outback, and Imprezas.
i can dream .... 600 HP in an outback .. drool
mattocs replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy goal is to get a new daily driver and replace the ej22 in my Outback with an eg33. I hope I can get the money together to do it.
Oil leak behind glove box
mattocs replied to seb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy oil loses its golden yellow color real quick when its in the engine. Are you always adding a lot of oil?
Best deal on new 2.2 TB pulleys
mattocs replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1stsubaruparts.com seems to have the best prices on OEM stuff. Did you check Auto Zone, Pepboys, or Advance Auto Parts?
"Dragon 2006!"
This road sounds like the ones I take to and from work every day :-P Sounds fun, wish I could make it.
Ever see one of these?
Egad. And I thought the wood on PT Cruisers and Jeep Cherokees was awful.
What happens when the timing belt in a 2.5 snaps
mattocs replied to zyewdall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXget a engine for like $500 at a junkyard or something and it'd be a sweet deal.
another recall page--1983 up
mattocs replied to tunered's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood find. Thanks a lot.
Waterpump leaking (questions)
mattocs replied to mattocs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, thanks. The soonest the dealer could get me in was the 29th of this month.
So my waterpump is leaking some coolant. It might have been doing this for a long time, because it seems every few months i've been putting some coolant in the reserve tank...but I havn't added any since January. I park in gravel whereever I go (work, my house, my parents, etc) so i'd really have no way to know it was leaking. Anyways, I was on my way to work, it started to overheat (got to about 3/4 on the temp. gauge) I added water and it didn't happen again. I got home, looked around, and its leaking from the waterpump area. I made an apointment at the dealer for new timing belt, waterpump, seals, etc. My questions are: -How much leaks out from the waterpump? Enough to stop driving the car competley? I took it for a drive and it didn't overheat when I keep coolant in the reserve tank. -As long as I have coolant with me in the car and pull over at the first sign that its getting to warm, could I drive it? -Would the coolant leaking get on the timing belt and cause it any problems? Thanks for any input. I would only need to drive it to work a few times when my wife needs her car. Thanks again. PS. 1996 Outback, EJ22
knock sensor
mattocs replied to astro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe knock sensor on my 2.2l was $20 or so at Autozone or Advance Auto Parts. Takes about a minute to do as long as you spray down the bolt holding it down with some WD40 or something.
Easy Spark Plug Change?
mattocs replied to mdryan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt took about 20 minutes to do in my EJ22. Pull out the washer fluid tank and get a 6 inch extention and it is as easy as can be
winter beater gets some goodies .
mattocs replied to machine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah...I am always looking for a brushguard or safari bar for my Outback that I can attatch some lights to. I'd really like to put some lights on the front bar of my roof rack.
mattocs replied to machine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just want two driving lamps...i was thinking about attatching them the grill, but am afraid they'd shake and move a lot.
mattocs replied to machine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow did you mount them? Are they stable?
Okay, I'm bummed
mattocs replied to GLCraig's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the sedan come with a manual?
car shopping, convince me on an Impreza
mattocs replied to jandree22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I were you'd i'd probably go for the Civic and get a used Subaru for the snow and whatnot...but thats just me. I am sure someone will tell you the pros and cons of each. Good luck.
Saabaru
mattocs replied to Aja1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought the Sabbaru was cheaper than a WRX?
USMB newbie
mattocs replied to hanson489's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a small Subaru dealer near me. I don't know if i'd buy a car from them (small selection) but they are really nice and the parts and service dept. do a good job and they don't charge a whole lot.
