john in KY
7
Everything posted by john in KY
GL AWD rear CV axle removal problem
john in KY replied to RacingFlyer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Been my experience that removing that beveled washer really helps in axle removal. -
I have a good 4EAT I saved from an 89 XT6 I recently parted. John
http://louisville.craigslist.org/pts/1051023076.html Don't know if the seller still has it but if so, within a day's drive.
Brat Dog nailed the problem. Somehow you pulled a plug loose or pulled a wire loose from a plug. Bunch of wires behind the kick panel also.
I have an XT6 ignition sw/key if you decide to go that route.
Still believe it is the control unit or just maybe the control unit has lost its main power supply. The control unit circuit I have to believe has to have a fuse somewhere in the circuit. May want to explore that. I have an extra control unit from an XT6, Have no idea if it is the same used in your model.
Has to be at the pump. When a strut is inflated, the air line between the strut and its solenoid is also pressurized. When the solenoid opens and the pump is not running, the pressurized air can only flow back to the pump where it is dumped. I'm assuming here both front struts went flat. Can't believe both struts or both front solenoids failed simultaneously. My guess is the problem is that control unit under the carpet.
All 4 solenoids open with a 12 volt signal. If you have 12 volts then the solenoid is bad or the ground. No 12 volts then think the control unit may be bad. Including a photo of the control unit for an XT6. Located under the carpet between the front seat and door. Probably in the same location for your car. May be worth the trouble to insure it is grounded. Have seen a few where the ground was corroded causing all sorts of problems. Hard to believe an air leak is the problem. System isn't all that complicated. When a strut is low, a signal is sent to the control unit. Control unit sends a signal to that solenoid which opens and air from the tank flows to the low strut. Tank pressure gets too low then another signal is sent to the compressor and it restores pressure.
Fuel delivery issues, loud fuel pump EA82T
john in KY replied to derburger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pull the fuel line at the pump that feeds the pump. Every time I have done this fuel flows freely. If you don't get a flow then there is a problem with the line between the pump and tank. Don't think replacing the FPR will do anything. -
Why not just replace the engine with another ER27?
XT6 inner FR Arm Bushing- & SuperPro?
john in KY replied to Marck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The XT and XT6 inner bushing are different. You could enlarge the bolt hole in the engine cradle but the other problem is the ball joint. Also different. -
High temp low pressure. WTF?
john in KY replied to wentz912's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Time for a new radiator. -
If turboed than 3.70. The FWD turbos came with a 3.54.
EA82T Cooling System Fun
I may have a new 2-row XT radiator. Bought it awhile back because I was told it was for the XT6. Once I opened the box and measured the inlet and outlet, I knew it was for the XT. Never fooled with it after that. Pm me if you want a photo/price. John -
All kinds of Oil Problems
john in KY replied to Keiji22's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Could be wrong here but seem to recall the valve cover bolts are "stepped". If so, they can't be overtorqued. -
1988 GL10 Factory Service Manual?
john in KY replied to 88 EA82T's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Had this problem once after doing a tune up. A miss only at idle. Eventually discovered I had cracked a small vacuum line on the manifold when I guess I was replacing the plug wires. Check the lines over on the passenger side.
91 Loyale 48Kmiles and a few ?'s from newbie
john in KY replied to dtrentr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd pop in a new radiator along with the hoses. Could save you a lot of future problems. -
EA82T woes, need help
john in KY replied to Subeast-EA81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Red turbo/downpipe to me indicates excessive fuel burning in the exhaust system. Any idea where the timing is set? -
New fuel filter installed backwards?
