Everything posted by subiemech85
Little things with the RX, a few questions
subiemech85 replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I hope my little wonderful diagram works :-p leave the turbo duty solenoid connected electrically, otherwise it throws a code, but you do not need any lines connected to it. Just run a line from turbo outlet to wastegate. run line from intake manifold to a T with one line going to the boost sensor for the dash, it's small and round, and the other to the canister from the canister one line goes to the hvac, and the other goes to the 4wd / dif lock -
or if the covers "happen to break" don't bother putting them back on!
ECS light on...runs terribly!
subiemech85 replied to Allouez's topic in Old Gen.: 80's GL/DL/XT/Loyales...
unplug the COMPUTER!!!!! -
15-17 in hg @ 1,000 rpm cold
split boots are crap check your mounts engine / trans
I've got "Cold Gravy" in my block!
subiemech85 replied to 211's topic in Old Gen.: 80's GL/DL/XT/Loyales...
tsp, sodium bicarbonate, bonami all together -
what works? I heard the wagon wheel centercaps fit, but have had no luck wheels as seen here: http://www.ultimatesubaru.org/forum/showthread.php?p=382812#post382812
where is it? what does it look like? the fsm makes no sense on the issue '89 rx loves to give me intermittent ECS light and 22 also has a bad habit of being grumpy when I try to lug it driving about 20 mph, floor it, usually in 3+ it goes "blah" and feel jerks 3 times then makes good boost about 2k rpm it's so annoying it disagrees with me when i try to drive it like a diesel, (keep the rpm low, and floor it after every gear change)
Anyone runnin' the 15" Pug flat spokes?
subiemech85 replied to EYE_WHY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
185/65 r 15 http://www.tirerack.com/tires/tires.jsp?tireMake=Winterforce&tireModel=M%2BS&vehicleSearch=false&partnum=865SR5WFORCE&fromCompare1=yes&place=6 they work good, no issues of clearance when unloaded, and speedometer is accurate they do just fine on the snowmobile trails with the 3" of light powdery snow another 3" is coming, so more haven't had any issues forward or reverse up and down hills in the d/r RX -
Old Subaru's Are EVIL!
subiemech85 replied to cutie-ru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a mystery leak, found it one day! check the hose that runs from engine to firewall that is closest to clutch lever mine had been rubbed just enough to make a s l o w leak -
what is the correct oil for the lsd, and what works good? are additives required? no search results, 3 letter words
loyale heater-defroster repair
subiemech85 replied to fst4rsc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the port closest to the firewall goes to the inkake manifold the port closest to the engine goes to the HVAC and 4wd or difflock BTDT -
Questions about snow driving/snow tires
subiemech85 replied to pinksoda3's topic in Old Gen.: 80's GL/DL/XT/Loyales...
STAY OFF THE BOOST! don't leave the jugs of water in the car -
yesterday I called board 911, McBrat, and told him the board exceeded its bandwith limit, and he said, well, atleast it's the end of the month!
Stock Fog Lights. . .HELP!
subiemech85 replied to KNIGHTRIDER's topic in Old Gen.: 80's GL/DL/XT/Loyales...
3. the GROUND is behind the grill, open the hood, remove 2 screws pull forward and up by where the hood cable would be, there is a black tube with 2 black wires, with a ring terminal that has a bolt in it that connects to the metal, this is the GROUND btdt -
Loyale, clock on the dash
subiemech85 replied to mudduck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
at least it keeps time, unlike the ea81's is there some hidden function?? -
let's start with the easy stuff. 1. the FUSE! 2. the SWITCH! do you hear a click when key on lights on, turn on switch? 3. the GROUND! it's behind the grill got pics of lights?? -
for easy access pull down the glovebox, just pull in the sides and push down I've found that the most convenient place for my uniden pc68ltw is standinng up on the floor leaning against the console. I had a conversation with a dirver, and both ends sounded like talking on a telephone also had swr meter set about 1.5 with 2 watts and a little wil on the rear gate of the rx drove 1,000+ miles with it on, no "regular" radio :drool: -
you should have 12v from one side for all connectors one set usually has 12v on both sides, mine's black
Idling problems...EA82T, '87 RX
subiemech85 replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
but it sure is fun telling stories of I have more rust than you, and it still goes even with all it's problems -
maf to turbo tube broke, repair or replace?
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I got creative and made my own! it only cost $ 10 for materials 3"x2" reducing bushing 1-1/2" pvc coupling 2" flexible elbow also added the pcv filters and hooked up the yellow line for wastegate -
"Don't forget manifold metal gaskets" buy the ones from NAPA with the metal sealing rings
Kinda sounds like.....
subiemech85 replied to HooptyGL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bubbles in the heater system
