Everything posted by subiemech85
Best exhaust system for a EA81 Brat
subiemech85 replied to FlyB0y's topic in Old Gen.: 80's GL/DL/XT/Loyales...
BTDT: used the complete exhaust system that I had on my ea82 '85 wagon it was 2" from the y to the tailpipe, with a glasspack in the stock rear position -
XT6 sighting? - new Herbie movie
subiemech85 replied to thealleyboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it was a blue? xt6, said just to rear of door? ,, saw it and posted saturday -
http://www.subaru.co.jp/square/selection/28/03.html thought you may be interested
i need 1985 ea81 air injection diagram
subiemech85 replied to the sucker king's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think this does it http://digitalcarversguild.com/products/veloute/veloutegrooves/can.jpg and the improvement works, BTDT -
Midwest 3 "Parts" Thread...
subiemech85 replied to mcbrat's topic in Meet n' Greet. Your USMB Welcome Center
a bunch of misc., it's been a while since I've taken inventory -
a redline a day keeps the mechanic away
subiemech85 replied to avatar382's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I buried the tach in my brat today!!!!!!!!!!!!!!! and the tach stops at 8k it idled to warm up 2.5 hours before I did that -
anyone have pics of BLACK subarus?
subiemech85 replied to erik litchy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a couple pages of my ea82 85 wagon in factory black on my cardomain.com page subiemech85 -
beyond redline!!!!!!!!!!! 6.5K is where the ea81 sounds the best with ea82 carb, intake maniflod, and complete exhaust with glasspack at the end I held it there for a while of course, I let it warm up to normal operating temp first, I ain't stupid a redline a day keeps the gremlins at bay anyone else redline the ea82 in 1st rwd lo goin up a muddy "road"?? -
That's it! Now I have to get rid of the stupid VW and swap in one of those! !! spare girll and 3 extra passing lamps 85 a2 1.6 na jetta
Advantage of EA82 manifold on EA81 engine?
subiemech85 replied to Bratenstein's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I made a post a while ago giving a detailed list of things that need to be done for the maniflold to fit. search ford pinto -
1. don't go blaming ford for the international powerstroke 2. zamboni uses a vw propane engine, similar platform as the 1.6 diesel, and may offer a pathyway for finding a transmission 3. the turbo diesel is different in that it has a turbo, and piston cooling jets, and a fuel pump with an aneroid, and higher NOP nozzles 4. the 1.8 gas and the 1.6 diesel share the same stroke 5. engine code ME 52 hp @ 4800 71 ftlbs @ 2500 6. engine code MF 68 hp @ 4500 98 ftlbs @ 2500 turbo 7. the 1.9 can be made to run on a mechanical fuel system 8. the vw toureag makes about 580 ftlbs TORQUE!! 9. how can I squeeze more power out of the 1.6 na diesel? 10. the 85 jetta 1.6 is my DD
this diff clearance owns all
subiemech85 replied to subaru_styles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it SHOULD be a tallboy it's pop pepsi is mean to me, coke is smooth -
Rebuilding motor mounts with urethane
subiemech85 replied to Marck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did 2 the driver side mount I burned off ALL of the old rubber, cleaned up the metal, drilled many 1/8" holes, and filled it in the other one I just added to let set for a week, and install still no problems -
karinvail, I sent you a pm
bent nail
it's better than a bra on the front and hang'n nuts on the back
EA82 custom air cleaner pics here!
subiemech85 replied to incognito's topic in Old Gen.: 80's GL/DL/XT/Loyales...
took off the stock "snorkle" used a piece of old air filter screen on the inlet -
Another Subaru spotted in another movie!
subiemech85 replied to elcaminokurt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ghost Dad with Bil Cosby about 20 minutes in, at the "taxi" scene looks to be a gen 2 told mom, !!THAT'S A SUBARU!! -
I have a set of brown, ok condition I have a set of blue, some faded I have a set of NOS blue, including origional packaging materials,
make sure the vac. advance unit works on the replacement BEFORE you install it!!!!! install it at tdc #1 you can find tdc #1 by pulling iut #1 sparkplug and sticking your finger in the hole so you can feel air pressure, then make sure the pointer is at 0* now pull out the dist. the rotor should be pointed between #1 and #3!!!!! then slide in the replacement, and set timing with advance line disconnected and plugged after timing is set, hook up advance line to manifold, and the timing should be 20*+, now increase rpm and see if advance decreases
went to my favorite jy to see what they have, spending quality time to "clear my mind", and I found a NEAR MINT CONDITION GL '86 EA82 MPFI 4WD AUTOMATIC 100% COMPLETE WITH WHITE WHEELS AND BLUE CENTERCAPS, WITH BLUE INTERIOR AND BLUE PAINT I also found a '88 justy 5spd 4x4, 86 xt, 90 wagon, sr, a TURBO EA82 "FLATTENED", AND a couple other ea82 and a bunch of VW
I'm curious.. JY rates?
subiemech85 replied to RavenTBK's topic in Old Gen.: 80's GL/DL/XT/Loyales...
$40 for each ea82 gl headlight and front corner light $20 ea81 2wd front axle $75 ea82 dr trans "pocket parts"
