Everything posted by subiemech85
dirtiest suby job ever
my dirtiest job ever was midwest mud fest, midwest meet II second dirtiest job was washing it after a week of driving to let most of it fall off the "dirty job" is tackled with 200* water @ 3000 psi
Convering Clutch from Cable to Hydrolics
just one thought, WHAT ABOUT THE HILL HOLDER?????
Question about a 90 justy five speed
VW Scirocco/soob engine???
put in a 1.6 d or td visit vwdieselparts.com
Another request for diagnostic help EA82 Update 1-25-06
MAF senosr the engine would die when the intake pipe would come disconnected, and would not start it acted like it wanted to go, but couldn't , similar to running out of gas it might start when you disconnect the maf senosr, and should idle worse, BTDT
ECS light - trouble codes
Been There Done That canister on side opposite battery, round, black, has 3-4lines going to it you need to plug the small line, and leave the others open, IIRC IIRC = If I Recall Correctly
BTDT california emissions removed canister light rarely came on when light did come on, unplugged computer WHILE DRIVING !!!!!
oil pressure guage installation
for both ea81 and ea82, remove the 8mm square head plug the thread is 1/8-28 BSPT BRITISH STANDARD, not metric 1/8-27 is NPT NATIONAL, it will work for a while to put the 27 in the 28
Bypassing the WGDS ??
FWIW: '85 EA82T did NOT have a WGDS
Make sure your oil sending unit wire is secured...
it looks like just the trick to make the xt6 alt fit
Check Engine Light?????????
ecs = check engine led on = rich led off = lean red led = ea81 green led = ea82 for "U-CHECK" mode, do NOT connect connectors for "D-CHECK" mode, connect GREEN connectors if you are in "D-CHECK" mode, the ecs or check engine light will blink you MUST be in "D-CHECK" mode to set timing you Must be in "U-CHECK" mode to read present codes
cool! can I get a couple good pics of the alt. mount bracket?? I'm with the "panasonic"
New Heads, New gaskets, New NOISE!?!
my 1.6d does not sound like the hla problem add enough atf to bring the oil level to the top hole on the stick
take a look at this: http://www.vwcaddyforum.com/pictures/caddyeng11.jpg
Clutch Cable Lubrication
lubejob
transmition non turbo d/r VS. turbo d/r
FWIW my '85 d/r 3.9 wagon did run at the same speed and rpm as my '89 rx 3.7 d/r does. suberdave, I would trade you the '85 d/r 3.9 from the wagon that I put in the brat for your 3.7 d/r with diflock or I know of an '86 d/r 3.9 in a local j/y and yes, the gears are different between '85 and '86
Check Engine Light How To!!!!!
Y-pipe vs best design exhaust
" Is an EQUAL length Y-pipe possible" what a silly question :-p all you would have to do is use your imagination
Spare Parts for Road Trip
both coil and alternator popped into my head when I read the title also bring speaker wire, BFH, oil, oil filter, coolant, ca$h, luck
crap.. some help please...
you might be in luck because your ea81 has an automatic trans, which usually had the engine that did not require valve adjustments but to make the atf in the engine work, it will take more than a couple of minutes of idling try driving 1/2 hour at 4k then change oil to a good 15w40, castrol tection works good for me, and a purolator filter -- got rid of the tod for me
don't bother with flushing your oil system with mmo or whatever, it only applies to ea82 you need to adjust the valves, they are mechanical, do it in firing order, there have been several postings about this also a good time to replace the valve cover gaskets, I'm sure they are leaking
Heater control issues. How hot?
Gasket Sealer Q's...
for head gasket sealant use hylomar ... http://www.cardomain.com/ride/471729/8 and for some discussion ... http://vwdieselparts.com/forum/viewtopic.php?t=2960&sid=3377132eef16abd43c1e36d9ef51186b
Picked up my 15" pugs and some nasty lugs (watchout 56k)
take a BFH = long dledgehammer and beat on the tire of course, make sure all the nust are off
good source for valve cover grommets?
NAPA $ 6.49 for a set of 12! Item#: SGAVS13
