Everything posted by subiemech85
wher and how to replace the input shaft.
input shaft is connected to torque converter which is bolted to flexplate shift selector rod is what u are asking about y did not want to work for ^
Wiring Diagrams
either red book for gen 2 or brown book for gen 3
Exhaust "Leak" With believable Pics (56K LOOKOUT!!)
they are 2.83 from subarugenuineparts local $tealer $aid 8
Problem with 1989 EA82T MPFI Turbo
this issue has been covered and would have been found by SEARCH http://www.ultimatesubaru.org/forum/showthread.php?t=48380&highlight=knock+sensor
Solved - Idle with AC on too high
there may be a vac. operated device that pulls a lever on the carb to increase engine speed
1982 GL Wagon timing belt or chain?
cam position
Ok, so I wana put the jump seats back .. still need storage ... ideas?
not subaru, but canvas topper : http://vwcaddyforum.com/showthread.php?t=7327 and there are more pics in brochures in the http://vwcaddyforum.com/forumdisplay.php?f=52 , especially the french brochures
Being offered 2 free Subies
if you're complaning about GAS mileage , think of FUEL economy of a small EFFICIENT DIESEL 16 or 20 mpg in rx vs. 45 mpg in vw pickup if you need more encouragement to get the subarus, just think that you could be the horse of
I read p. 1 then skipped to "reply" quit your bellyachin and remove the exhaust manifold, clean up the ports, install new studs, gaskets and nuts my rx currently has no studs in the heads :-p
'89 Justy trouble reading ECU codes
with both test mode and read memory connectors connected, idle speed should be set to 800 +/- 50 with test mode connectors connected, ignition timing should be set to 5 degrees +/- 2 degrees below 1000 rpm "NEXT TIME ASK TO SEE THE D-CKECK REFERENCE BOOKLET" I have one and have been using it for all info provided got ? ask!
Subaru Diesels?
the vw pickup is still made in south africa AFAIK and hauls, bigger box than a ranger http://vwcaddyforum.com/index.php? http://www.vwcaddyforum.com/pictures/caddyeng11.jpg
TPS benchtest ??
you can also get to them with needle nose vise grips
the connecors are between the hood release cable and the ecm towards the fender side of the clutch pedal the read memory connector has a LgW wire in pin 21 of the 22 pin harness the test mode connector has a GW wire in pin 22 of the 22 pin harness
so why don't it work??? Update page 4
ate your wires or it could be subaru's common ground system
Checked for codes, need to translte
MT, Cal and Canada SPFI
who makes the 5speed swap crosmemeberS
I'm confused! since when does the crossmembers need to be changed if going from ea81 d/r to ea82 d/r
Audible Coolant Sensor Alarm
subiemech85 replied to J98Hudson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou may be able to adapt a vw low coolant warning system, ex. '85 diesel and wire it in with the key dinger should be in new gen
Victory is mine!!! Can you guess the problem?
reminds me of the time the fuel shutoff solenoid wire came loose trying to accelerate, cuts out, push in clutch, put go pedal down engine catches, rev up let up on clutch, good to go and it was my diesel!
90 Loyale Code 11
SPFI or MPFI????? IF SPFI, wires # 19 power (output) 20 signal (reference) 21 signal (position) code 11 = crank angle sensor (No reference pulse) IF MPFI, wires # 7 (power) 8 (reference)
ea82t reroute turbo coolant lines?
seems like there are several posts that mention the coolant lines should be re-routed but that is it where should they be re-routed? here's my guess: turbo out to heater core in trubo in to heater core out BTW: pex t fittings work great as adapters, etx. I recently installed a fuel heater in the vw tapping into the heater core circuit
ea82 and ea81 drive shafts - are they the same
and I thought you were talking about the ea82 2 piece driveshaft front driveshaft varies rear dirveshaft constant is there going to be a trans swap?
High pitched whistle varies with rpm?
vac. leak BTDT: I had a BIG vac. leak, idle adjust screw came out your leak may be smaller or it could be an exhaust leak
EGR; replace, block, plug or leave alone?
use the gasket as a template for when you make the block off plate I used a piece of mower blade engine should be able to run without anything covering the hole gives it a different sound, low power, major vac. leak
Weird Thermostat Replacement Issue
which kind of glycol? ethylene or propylene don't drink drinkable I have had good luck with NAPA superstat thermostats and gaskets
auto tranny alternative
if none of those would work, you could go hydro or ecvt my favorite is a 5spd!
