subiemech85
Everything posted by subiemech85
  1. you may be better off putting in a ea71 turbo engine
  2. 80k engine 180k everything else '89 rx
  3. 25+ psi on regular gas, just remove waste gate line no fuel cut experienced no idea how long it will last that way
  4. what makes a fat case ea71 a fat case ea71? and is there an easy way to distinguish one from a regular ea71???
  5. but there is still the issue of top starter vs. side starter and the ea82 series 5spd d/r would work, including the '85 models, different gear ratios a decent LOW is all I want
  6. works good now with pics! @ http://www.cardomain.com/ride/2328831 Easy weber air box swap.doc
  7. I decided it was time for the "regular" rectangle air filter to go away, and wanted something that would be easy to swap. It works good and you can read the write-up
  8. I thought of posting that myself it was chief wigam making the comment, and the other white cop directing traffic
  9. if it's ecvt, it could be the brushes
  10. good close-up pics! http://www.ultimatesubaru.org/forum/showthread.php?t=44427&page=2&highlight=details totally functional, no factory hood cable crap, cable broke
  11. blame the gauge! isn't it supposed to be inches of mercury :cool: stock turbo system with wastegate line removed will easily do 25+ psi on regular gas
  12. but the one for a ea71 will if you need one, it's yours
  13. should have NOT happened if properly maintained
  14. it's like an appendix, keep it until it goes bad, then get rid of it!
  15. has anyone actually done the air box mod? if not, must invent
  16. ... good bye, so long, farewell ... or bolt on a steel plate approximately the shape of {> or play kill the subie, make it jump over speedbumps, curbs, hit pot holes, and most important - make it fly
  17. you can also bend down the locking tabs I have one with the return oil line that is so tight it takes a wrench to turn
  18. ah, that ain't nuthin ever look at a vw rabbit with rusty strut towers, or holes in similar area you can fit your fist? and they still get repaired and the seat rails always rust out
  19. supposedbly the do exist I have a timing window plug for one do you have any parts or pictures for them?
  20. there was a ?grey ea71 3-door discussed about 2 months ago here! http://www.ultimatesubaru.org/forum/showthread.php?t=50229&highlight=ea71+coupe
  21. located in front of master cylinder blue, round, hose connected to front removed the 2 nuts, split case, separated filter with lid from housing just looking for the element
  22. how about speed signal from W terminal on alternator? would like to have water, oil, air intake, fuel, exhaust temp, oil, air intake, fuel pressure, engine rpm, lambda, voltage, with units selectable for c/f and bar/psi it's a diesel
