Everything posted by subiemech85
Electrical Weirdness
BTFT: disconnected the wire for the brake fluid level sensor
i wonder is there a subi with back wiper , not wagon....?!
wesley willis " as does my hatch. it's quite useless, unless you want your rear window wiped, of course. " what else would it do, slice cheese? "nope, the only Soobies with rear wipers were most of the wagons (all EA82 wagons) and the EA82 coupes" didn't the dl skip this option? 4-door sedan has rear wiper, '85 fsm book 2, section 6-2 p. 49-50 adjustment, etc :-p
why can't i find my radiator ground wire?
ea81 series has a radiator ground wire from radiator to radiator support ea82 series does not have a radiator ground, but it is good to run one from thermostat housing to back side of radiator look for a hidden locking clip
ea81... HELP GRRRRRRRRRR
coil already listed in origional post
BTDT: fix = swap distributor
Oil Leak
"any info would help" back at you! front crank seal?
EA82 Radio Questions
clarion no idea remove plastic side panels
another airplane page covering ea71! +
http://www.aviajournal.interami.com/sections/journal/arh/magazine/20012eng/st3.shtml worth a read, based in russia
Haynes and Chilton's for Loyale
they both SUCK! ONLY WAY TO GO IS D-CHECK REFERENCE BOOKLETS I have complete set from 1983-1990
top speed of rx ?
after fixing the exhaust leaks, I decided to take it out to see what it can do max speed 90 @4.5k '89 rx ft4wd d/r dif unlocked high range no wind ambient temp 45* unifilter intake 89 octane 10% ethanol otherwise stock shouldn't it go faster??? my '81 vw rabbit pickup diesel with ?50 hp goes 90, speedometer stops at 85
New stainless turbo header
easy way to remove crossover pipe is to hammer in the mounting tabs, raise front of car, remove whatever is still holding, let left side fall down, rotate, twist, slide, duck mine fell off one time for me
headgasket diffrences
stone
No Accel Coils, No schucks
mine is on it's third vehicle I must have gotten lucky, 8140c, had it about 3 years '85 wagon '84 brat '89 rx
EA71 Intake manifolds
so: what are the results ?? I have ideas clouding my mind
Making your own gauge sending unit adaptor...
the way to remove the plug is with the snapon special socket 6mm square, pmp406a, also fits brake adjusting screws, and lash adjusters
EA71 to D/R 4wd 5sp
does this involve a bellhousing from a d/r brat with fat case ea71? I'm interested in recipe NOW!
oh, sure go ahead and do it the wrong way! there is a plug you are supposed to remove to instal correctly ea81 = 1/8 NPT ea82 = 1/8 bspt this topic has been discussed quite well
EA81 paint jobs
do the "wd40 test" spray some wd40 onto a white paper towel, high quality like "rags in a box" then rub the paint and see if it shines up works like a charm!
thinking of re-painting rx
this time with INDUSTRIAL ENAMEL the rust keeps spreading, stripes were rust-oleum, paint looks kinda crappy, cracking will probably keep the color scheme with gloss white body, aluminum for the gray bits, and MF red for the stripes, and a gloss black hood current paint http://www.ultimatesubaru.org/forum/showthread.php?t=44427 paint supplier http://vansicklepaint.com/mntvsinden.html about $20 a gallon at the farm store any idea how much paint would be needed? coverage is approximately 400-450 sq. ft. per gallon
My new 87 RX
looks like someone overdid it with the black I say it needs some stripes and lettering as I am looking at the VanSickle color palate for industrial enamel
What would you pay for this?
I bought my '85 wagon with h alloys for $50, similar condition http://www.cardomain.com/ride/471729/1
carbon fiber hood RX
the scoop http://www.ultimatesubaru.org/forum/showthread.php?t=33749
hood came from SOA, still has part # tag no clue where the cf scoop came from, but it works it's a cf scoop, you nit wit and the rx is mine, happily leaking oil, coolant, exhaust, hibernating until the snow
?? confused as to where it goes, 11/79
Historic Subaru Forum (3 Viewing) Any topic discussing Subaru models older than 1979 (1981 for Brat), or vehicle restoration techiques for any model or year Subaru. Older Generation of Subarus (16 Viewing) If your Subaru was built after 1980 but before 1990 or is a Loyale, Justy, XT or XT6 please post here. since the build is 11/79 doesn't it belong in old gen? it's an ea71 maybe there should be a category of TRANSITIONAL eras :-p
secondary air cleaner ?
is the filter in the secondary air cleaner replacable?
