Everything posted by subiemech85
Worst color?
white is a major rust indicator color I don't have any plain white cars, the rx in stock paint is blah, the stripes make it bareable, the rust gives it character, and the mud belongs there the ski wagon, it's decorated
Any Ideas? 89 Subaru GL Has an Owie
MilesFox has done the conversion on a ea81 wagon IIRC it can be done and is worth the trouble IMHO if a subaru isn't leaking, it's out of oil! go to church and make the donation
the only question now is what trans do you want you can have 4wd, 4wd d/r or fwd
What does this thing do?
the box is a relay the switch is probably hooked to the "signal" terminal and 12v+ you'll have to find out where the wires run, a fox 'n hound is helpful
Fuel guage sending unit connector location?
in the trunk you should find a cover plate held down by screws on the right middle rear someone conveniently went through the trouble to remove the tank and put it in the back seat
Swapping windows??
it's easy remove door pull, window winder handle, etc., door panel, and then the small bolts, there's 4 in the rear of a wagon
Best way to warm up a turbo Soob.
to let it warm up, put in neutral, depress clutch, turn key to on, let fuel pump shut off, start, let engine "wake up" - give it ?30sec. to smooth out a bit and build oil pressure, release clutch, go in house to warm yourself up, after about ?10-15 min. it should be idling slow and the temp gauge should be in "normal" range, if ecs light is on, do a quick power cycle, and off you go for shutdown, after you reach your destination, let it idle about ?5 min, or about ?30sec after the pyrometer has reached the point at where it idles at warm up, ?1100*f to really pull down the temps, go for a nice long engine braking distance, 50 to 20 mph works nice, can reach ?800*f
MELTED t-belt cover !!!!!
that's right it melted real good I had already removed the outside front covers just turn your head to the left and take a look
What other car rimms will fit a Gl?
IIRC, hondas fit justys
More problems with the '86... need help/advice
you should have said SPI! truoble codes 16 crank angle sensor 35 air flow meter 62 egr control sys you may have to set the timing at "base timing" which may involve connecting a connector to make the computer stop adjusting timing the difference in rpm is acceptable, you did put a load on the engine, as would running the cooling fan, blower motor and ac compressor all at the same time the egr solenoid is supposed to control the egr valve, but "can" be disconnected the distributor wear that is the problem is if the rotor can move up and down, and may eventually grind away at the componets, backlash is necessary - only a problem if excessive you may also have to re-set the throttle position sensor
you need better oil! go to the farm store and buy a gallon of mystic 15w50 and a purolator oil filter or go to advance auto and buy a gallon of castrol tection 15w40 and "purolator" oil filter or the AA3600, it's a purolator in disguise with red texture, a quakerstate is the same in white paint
I have an factory equalizer, can I use diffrent speakers?
try to match resistance values
EA82 Engine Knock at Low RPM
TOD hydraulic lifters with the higher engine "idle" speed, the oil pump kept the lifters quiet and full chech your oil quantity and quality
overspray after bumper repair!
subiemech85 replied to frohbego's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXACETONE I removed a lot of red rust-oleum from glass, and white paint on my rx from the po's stripe job :-\ make sure you keep the paper towel from collecting too much overspray by turning frequently otherwise you get streaks of overspray
Do automatics have hill holder?
NO
I thought it was a joke this whole time.
"dodgy, not original" as in dodge omni? :-p
dead fan clutch quick fix (look out for pix)
or just take off the engine dirven fan, and don't put anything on, just like no ac setup my purfectly fine fan is happily sitting on the shelf where it will stay, unless $old
Move over Swampers, here's something meatier!
the titan looks just like the OLD firestone town and country, which were also available studded
Will EA81 engine go into EA82 car?
like I said, it's similar to swapping a trans you can keep the ea81 flywheel, mix n match componets as needed the exhaust should transfer over unless you have a wierd spacer issue the coil will need to be moved, or change the length of wires McBrat replaced an ea82 engine with an ea81 engine in a red wagon that came from cheftim that engine worked for a while, but developed a major problem :bnaghead:
yes basically like swapping trans and radiator
'89 rx electrical oddity, volt gauge turn signal
it finally happened the volt gauge goes up and down when I turn on the left turn signal any ideas WHY besides the obvious, fuses, grounds, connections, bulbs
thumbs to the OUTSIDE of the steering wheel...
Re: thumbs to the OUTSIDE of the steering wheel... that was my first offroad lesson I remember ?'70 1ton dodge dumptruck? with huge steering wheel
checking the grounds AND other electrical tips
with a dvm set on 20v, connect one lead to center terminal and one lead to outer terminal and note reading ~12 = good then connect one lead to center terminal and one lead to good ground and note reading ~12 = good then connect one lead to outer terminal and one lead to good ground and note reading ~0 = good then stick one lead in engine coolant and one lead to good ground and note reading ~0 = good clean both battery terminals and connections the cables should be at least 6ga 18" one goes to the starter monting bolt one goes to the starter solenoid "FOR TESTING PRUPOSES ONLY" to hotwire a ea81 series subaru, + wire from coil + to bat. + and + wire from starter battery cable + to starter small male spade terminal does not work for ea82 if your volt gauge goes up and down with the turn signal on, welcome to the club!
dash lights inop, no tail lights, left headlight dim 1991 loyale
I just gotta do this! check the grounds! with a dvm set on 20v, connect one lead to center terminal and one lead to outer terminal and note reading ~12 = good then connect one lead to center terminal and one lead to good ground and note reading ~12 = good then connect one lead to outer terminal and one lead to good ground and note reading ~0 = good then stick one lead in engine coolant and one lead to good ground and note reading ~0 = good
what is "dimulator" in auto 3 loyale gear?
accumulator = pressure reservoir
