Everything posted by subiemech85
Why won't these things fit?!
the reason is that they came from a HATCH you would need ea82 style wagon wheels there is enough of a difference look at wheels page
Subaru shopping cart
IMHO it's funner to push shopping carts with subarus
Carbureted woes
check your exhaust if there's nothing, open ports, you loose torque
how much slap is to much slap. noisy baja
subiemech85 replied to Gl-boost's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbuy something made in japan adjust valves change oil move to old gen , that's what we do
4WD doesnt work.
or get rid of all that crap and install a lever
by crapachi hello weber
what? the weber on ea71 makes it WORK!!!!! maintained 70 uphill easily ea82 intake+carb on ea81 in brat won't do that
twitchy tach
have alt. checked, may be bad diodes
What is a good repair manual for a 78 Brat?
FSM haynes red book haynes blue book chilton white book clymer USRM
Brake pedal pulsates?
some info: http://www.eradispeed.com/warranty.shtm
Flutter under boost
pull line off wastegate and see what happens should be 10+ should start pulling "hard" after 5 how's the fuel? 10 gallons of E85 and 2 gallons of "regular" 87 ron+mon\2 gives good results with uncontrolled boost
they can be re-turned, but not machined
hmm, now what do i do? gas fuel door
subiemech85 replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyour options are: take door off, duck tape, use brat type latch
warped rotors
Rust In Iowa
front white/yellow spot bar (I'm keeping this. it's a Steely Del prototype bar. only one made like it) already tried to get it there was more paint until it left a deposit at the car wash
twin 4x4 stick/lever setup...
just put in a ft4wd I want to put in a manual center lock lever when there's enough boost under certain conditions, it dis-engages the lock
Rust In Iowa
looked better covered in snow! that's why I wash every chance I get! then I get it muddy again
Its Aliiiiiiiiiive!!
the idle at 3k when cold is "NORMAL", your ASV is doing its job the computer can figure out what timing it needs, it's smart enough to compensate enigne will run with maf wire disconnected, but will not wind up as high rpm engine will die if maf tube is disconnected
Radiator Flush?
chemicals are not the answer the flush gun has removed lots of crud was the radiator crimped or soldered?
Radiator Flush?
at the radiator shop, I use a power washer to clean the outside, it's amazing how much crud accumulates, and a "flush gun" which is garden hose water with compressed air with a trigger, and that will make the gunk flow out if it's really cruddy, it gets the boil tank of caustic soda and water, followed by more flushing use a low pressure power washer, 1000 psi is about right, car wash might do those "flush kits" are evil
DIE vacuum hoses!
the SEARCH is your friend! http://www.ultimatesubaru.org/forum/showthread.php?t=12404&highlight=emissions
Are EA81 & EA82 Firing Orders the same?
NOT the JUSTY
Addicted to bright (die dial up)
you skipped the third eye, my favorite and most satisfying paint the hood black, it really helps
What would you do?
sell the rims, put on clear plastic, "collision wrap" comes to mind, have fun
another airplane page covering ea71! +
http://www.dvsubaru.inc.ru/ this one has ea71, ea82 and ej series!!!!!! complete with power charts
EA82t in a EA81 car, what needs to be done?
fuel pump, radiator
