Everything posted by subiemech85
1. will an ea81 from a 83 brat fit to the ea82 4wd dr trans in a wagon? 2. will an ea82 from a 85 wagon fit to the ea81 4wd dr trans in a brat? 3. without swaping trans?
1986 D/R carb,EGR LIGHT???????
subiemech85 replied to N8NQU's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it is just a light that comes on every 60,000 miles! what you do with it is up to you as far as how much service, check your "maintenance schedule" -
Horns on EA-81 vs EA-82
subiemech85 replied to dbenzmaine's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and on the early ones, it's by the master cylinder what's the city celector? -
or one on each side by the fender, behind the bumper -
insides of a square AC compressor (pics)
subiemech85 replied to nutt7's topic in Old Gen.: 80's GL/DL/XT/Loyales...
WTF DID YOU DO WITH THE OIL? DIDN'T YOU READ "5.1 oz" OIL IS REQUIRED! evacuate to remove the AIR, it has moisture, impurities, and is VERY hard on the system IF it is carb, you have a vac. line, controller, and the compensator, look by the pas. side of carb and for what I marked in red -
it's not rotary, just 3 vane, like a hydraulic motor or pump oil to spec, then add a can of conditoner, then freon did you evacuate after rebuild? is EVERYTHING hooked up right? my carb usually idles at 1000, turn on the air and it goes to 600, no idle compensator -- I removed it -
try the john deere dealer, also uses them in the snowmobile.....
from most I have seen, "turn the dingus on the side" for me it works, so I don't mess
and how about a "new" brat complete shipped here? that would be so awesome
ea82 intake maniflold gasket ?
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what is the smaller hole for? water or air? the set I bought fits 73-94 -
What are they worth..EA82 heads?
subiemech85 replied to n7zum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
how dare they use the same pic for all 3 applications the top is NOT for carb or SPFI -
1980 FSM going begging on EBay
subiemech85 replied to Partsman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sorry! I didn't know it was you :drool: -
I quit bidding at 12.84 $ on my end is the i$$ue -
Noisy 4WD button on 85 Wagon
subiemech85 replied to lavo96's topic in Old Gen.: 80's GL/DL/XT/Loyales...
just remove the knob, and remove the 4x switch, then put the knob back on -
don't worry about it now, he's just going to put on a rebuilt when he can
call me asap 515-771-1239
hey, remember me? I left a message sunday! I'll call you today found a carb kit, can have it to YOU tomorrow! $20
think of it as your check and inspect t-belt reminder warning light for those of us that did away with the egr what 87 said above^ -
My 8140C was a "ture" bolt in in the ea82, and the ea81 I had to cut the bolt and drill out the hole to put a "real" bolt in, because the old "factory" bolt wouldn't budge under the influence of vice grips! there was no issue of it not fitting.
