Everything posted by subiemech85
when will it feel safe?
never is the answer I drove my car for at least 4 months in "all" kinds of driving, then on my way to the midwest meet, the trans acted up, go figure
Midwest 2 Status/Recovery updated:(and how to send $)
did the club ever recieve a bill? I washed my car 2 days ago, still haven't done anything to the car where's my mudflap? and prybar?
ea81 turbo removal ?s
1. how does the pipe from the filter adapt to the plenum? 2. where does the oil supply come from the engeine? 3. where does the oil supply return to the engine? 4. is there coolant passages? 5. what does the 2 wire senson on the heat shield do?, will it affect performance when disconnected? 83 ea81 turbowagon
Speed Bleeders for old Subarus? (part numbers and pics added!)
fronts MTM Front Bleeder Screw 1 per car. # 12706 Card of 2 $11.89 2 CARD w/BUILT-IN CHECK VALVE 1 YEAR LIMITED WARRANTY motormite haven't seen anthing for the rear
High Oil Pressure in an EA81??
install a real guage, then don't worry drive happy
Brat Heaven!!!!!!!
I know about the camel in the truck experience, dad served desert shield and desert storm as a truck driver in Saudi
Engine Time, Part 2!! Help....*ITS ALIVE!!*
1. leave the door open, I know of a house bought cheap due to death by running engine in closed door garage. 2.line everything up on the dis 3. vac advance to manifold
oil filters
and for what it's worth a GENUINE HONDA is a CANADIAN made FRAM does someone have a list of filters that will "fit"? wether it be larger, smaller, or same size?
25.5 tires on 86 nonlifted hatch?(works)
hey, didn't I see those just a few days ago in the back of a bleu brat? yes, they are nice
oil filters
I currently use the walmart supertech 3600 and run 15w40 year round, and about 1000 miles before I change the oil, I stick on the big magnet to the oil pan, and add mmo :argue:
Has anyone been wanting to see inside one of these?
and I also want to do a rebuild of my trans, hoping to fix the second gear non synchro shift issue, and find out why I had that wierd noise run it til it blows!!
can anyone id this hitachi?
it's definitely NOT EA82 or a CARTER/WEBER, the giveaway is the anti-dieseling solonoid on the front, and looks too simple to be a feedback, and I just got done fixing a carter/weber on a 84 sedan with a stuck float and full of varnish
CR-V vs. SUBARU AWD
I consider the honda a rounded box on wheels, with a phrase that belongs on 4wd subarus, at least that's how I use my 4x4, and in mud, snow, etc., 2 wheels spin, and the best gadget I wish my car had is the folding table! BTW SUV means Subaru Utility Vehicle, which mine definitely is, and with the roof rack, I put the wheelbarrow on and go to the jy or landscaping project
Any tire dismounting tips?
so, how do you know? I have a set of 4 to do, and don't care about the tires, they don't hold air anyway, just want to save the 14" steel pugs http://www.tires.com I have used for snow tires, and it was free shipping
Any plow info please
that is when someone brings up a topic that has fallen off the radar
and in a few months time, I search to find myself, and bump for the long term.
Need a "4wd" decal from the back of an EA82
I could go for orange!
Rear axle U-joint replacement ?s
they were fixed, don't need to worry anymore
long term bump, may be useful
help cutting tire....
or go down the road and find a blown out tire, where it self destructed
ea82 intake maniflold gasket ?
that figures, they sold me the wrong ones
I have carb and don't know which gasket to use, do I have the wrong ones, is there a coolant passage? set came with the one in my pic and the one for your bottom pic which one is for ea81 carb/others?
what is the gasket for with the 3 holes vs.the 2 holes the 3 holes have 2 cemicurcle o o o and the 2 hole ones have 2 holes, purfect circles o o is it an issue of injected vs.carb?
Installed a Toyota inclinometer today, also some useful trigonometry
I pulled one and the cover for it from a tercel, 83, mcbrat also has one
is there a gasket for the asv
it matters because I need to replace the asv with a block off plate, and want to stop the leaks would permatex gold work?
