Everything posted by subiemech85
Brake Lock Light
check your brake fluid it's not that hard, and you can disconnect the wire at the mc to make the light go away
Hello and help me
not sure what you are missing, but it may be the pipe from the y-pipe to the right side of the "snorkel" that points to the rear, from the underside, or it may be something in the flapper control also to make a snorkel quickly, hook up flapper vac line to manifold, so it is open to hot air intake and put hot air intake under spair tire
can someone take a pic for me.
sure! it's a crunched right side off a 85 gl pic tomorrow
Grinding Question
it can break down, collect water and rust
Grinding Question
front dif was thirsty time to change fluid
Wish me luck!!! Offroading an OBS
tj = that's junk gl = grand luxury, go lightly, get loaded dl = devoid of luxury I drove a "borrowed" jeep chreokee once, that thing has too many 4x? choices
Advice on knocking noise 87 GL Wagon
add mmo or sea foam tighten oil pump bolts there is also a factory service manual procedure, also might be in owner's manual
and clutches just give up in the gumbo!
So how long can your car run without coolant?
a bent nose hemostat is the solution for vac caps on the carb and that pesky line
Ticking Moter? heres the trick..
and in a nissan, mom's, thin oil makes the tick go away and I hardly drive a nissan, they are annoyingly uncomfortable for the short guy
need some help with no start 86 and 2 87 GL-10's
what body style and engine do you have? could you be more specific as to the problems, and damage
subaru madness
that's nothing compared to a trashwagon rescue or any trip with MilesFox
what is the optimum quantity of r-134a?
read up buddy : http://www.delanet.com/~pparish/gen-rp.htm#oil
Back from a weekend of Camping/Wheeling... (long)
sounds like you had fun showing jeeps what a subaru can do it's good the clutches are the weak point, think of it as a pressure relief valve! and I had some fun today.
Fusible link
they are a composite of glass, rubber, and metal, with amp ratings of 100-180 at the jy the only way to test is with an ohmmeter, check for an open jy is also a good place for oem fuses
Cam snaped in 1/2
how did it break is the question, it's a matter of failure analysis
My wife don't like the horn on our new Legacy
subiemech85 replied to sam888's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI looked to my 82 Cadillac for the "D" note horn, ran new wire, switch, and mounted horn under the spare, using existing ground bolt , because the factory system was totally junk will add horn from 1971 GM truck
Sputtering Badly Whats wrong??? Help Stranded!!
welcome to the club! is there a source for bushings?
Head Gasket Failure or what? Can anyone explain this? *update - fixed*
try the fel-pro perma torque gaskets clean up mess really good
Driveline noise Opinions, please.
that's when you return the old one, with the reciept. don't say I told you to
come by for a graduation and party
1461 Zook Spur RD Madrid IA 50156-7487 food beer pop fireworks parts soobs, mud! graduation celebration, and whatever else may 28-31, mostly on saturday
distributor stuck in block
use a STRAP WRENCH
1987 Subaru Wagon GL 4WD
1. remove all vac lines and plug holes, add stuff AFTER it runs 2. drian tank, there is a drain plug 3. change filters 4. if it was mpfi and you stick a carb on it won't work unless you changed the heads 5. once you have done the above, ask if you still have problems
tach has mind of its own
finally I admit I agree with you
Gauging interest in making a Subaru Flag w'old school logo
definately shop around rip stop nylon is somewhat harder to sew, and about $10 a yard?
