Everything posted by subiemech85
About how long does an axle change take?
3 hours off, 30 days + to replace, 3 hours on
Why a soob?
I started with dad's 83 ea81 4wd dr 4spd sloppy shifter knocking lifter clacking cv axles, with california emissions, and now have my 85 ea82 5spd dr 4x4 de-emissioned trashwagon 7, that I take everywhere I want to go the way I drive in "questionable terrain" is run it in fwd, when you see trouble, STOP, reverse, and 4lo, saves your rump roast
Will broken timing belt damage EA82 valves?
no if the left breaks, it won't run, drives dist if right breaks, it will still run change them after they break even on the side of the road
tach has mind of its own
this is not your typical jumpy tach bump for the day crew
Head Count for May 29 Subaru Alliance Meet
I have to graduate that day, might make a jy run
west coast v. east coast
And I wasn't on the list? Subiemech85 uniquet2? eyesore? milesfox, zannydook?
it suffers the symptoms when the lights or blower is on, otherwise it is fine :banghead
weird clacking noise
I'm guessing manual trans gremlins are asking for more oil, or a bearing is going
need a disty, ea82
yes, it does belong in the marketplace, as long as it is for sale or want to buy subaru if not subaru, then it goes in the off topic the jy around here doesn't have one, I checked for myself
What the heck is this thing???
1. find a chilton's manual 2. read the section on how to disable
Whats this? "posi" marks from RXs????
no actually I was able to make it up over 1/2 way up, but got in an area where I was too close to the steep ditch to risk it and I drove in rwd for about 2 months
seat belt or air bag sensor, depending on years
what's goin on? should I put on the aftermarket universal tach? ea82 carb
tried to move in fwd, but NOTHING happened, just the little bare output shaft spun had to go up non plowed snow full driveway in forward, but couldn't, had to do it in reverse, no problem trying to go up mud road 6,000 rpm in 4lo, 1st gear, forward, finally found someone in a muddy truck to pull me up the road, thank you!
no it doesn't! rwd in mud and snow sucked, reverse was better than forward
adjusting adjustable struts question
you may also try gentle heat, such as from a soldering torch
Pressure drop when A/C Compressor Kicks On
pressure in a 134a system lo is 13, and hi is 180
? problem on auto
ea81 turbo, 4x, manual is NOT an option car has almost no go at all, max 25, floored!, it shifts, doesn't move unless you put it in go with engine at 3,000
LOUD Throw out bearing! Bandaids?
the bandaids go on your ears, and scrapes invest in an engine lift drive it until it blows if it's broke already, does it matter if it breaks more?
which one is best?
subiemech85 replied to subiemech85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXall of the "new gen", whatever that is, looking to "upgrade" for old gen, I would go with my 85 gl wagon dr, and power everything
which one is best?
what is the most durable model for pulling, offroad, and hauling capacity?
top is fro the clutch, bottom is for the hh what's wrong with your hood? mine flies open at 30, done it twice, once was not good enough for me, now I MAKE SURE it's shut
hoodscoop ?s
if it is carb, hook it up to the hot air intake, use flex pipe, and a coffee can, and your imagination
brat stripes
as there has been much controversy, I would like to know where the ski wagon decals and brat stripes were applied, such as in the pic of this brat:, the one I am considering buying
engine swap Q? easy
just another reason to buy a brat - such as the one I am considering, dad highly opposed the most non-stuck 4x fun is down at the river bottom, saw water, stopped, put it in 4lo, and backed out no problem, thank you fwd! also the magnet mount on the roof is the only way to go
