Everything posted by subiemech85
engine swap Q? easy
1. will an ea81 from a 83 brat fit to the ea82 4wd dr trans in a wagon? 2. will an ea82 from a 85 wagon fit to the ea81 4wd dr trans in a brat? 3. without swaping trans?
Heresy! Replaced NGK Platinum w/Champion Copper Plugs
subiemech85 replied to Chip Hedrick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXchampions were used because they were american, not canadian japan or some other reason due to % of import in an american car champion is bad due to the poor quality of metal used to make the parts that matter ngk is the way to go
1986 D/R carb,EGR LIGHT???????
it is just a light that comes on every 60,000 miles! what you do with it is up to you as far as how much service, check your "maintenance schedule"
NGK washer locked onto thread of spark plug=bad running engine...
make sure the washer is good and where it belongs, and check the wires and control module
Horns on EA-81 vs EA-82
and on the early ones, it's by the master cylinder what's the city celector?
or one on each side by the fender, behind the bumper
Electric Supercharger Kit
subiemech85 replied to KDUB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbooooooooo ooo ooogussssssss sss!! did they mean throttle body? it is easier to flush money down the toilet
insides of a square AC compressor (pics)
WTF DID YOU DO WITH THE OIL? DIDN'T YOU READ "5.1 oz" OIL IS REQUIRED! evacuate to remove the AIR, it has moisture, impurities, and is VERY hard on the system IF it is carb, you have a vac. line, controller, and the compensator, look by the pas. side of carb and for what I marked in red
it's not rotary, just 3 vane, like a hydraulic motor or pump oil to spec, then add a can of conditoner, then freon did you evacuate after rebuild? is EVERYTHING hooked up right? my carb usually idles at 1000, turn on the air and it goes to 600, no idle compensator -- I removed it
Should I keep the car bra on or not? (link to pics inside)
a bra does not belong on something that has nuts!
ngk bpr6es 11?
try the john deere dealer, also uses them in the snowmobile.....
Need Carb help ASAP!!!
from most I have seen, "turn the dingus on the side" for me it works, so I don't mess
Why you should use OEM parts for some stuff...
I've tried the book and it said "see counter" no luck there
thanks for the info about failsafe does anyone use 160*? got jiggle pin?
Subaru Brat?
and how about a "new" brat complete shipped here? that would be so awesome
ea82 intake maniflold gasket ?
what is the smaller hole for? water or air? the set I bought fits 73-94
What are they worth..EA82 heads?
how dare they use the same pic for all 3 applications the top is NOT for carb or SPFI
1980 FSM going begging on EBay
sorry! I didn't know it was you :drool:
I quit bidding at 12.84 $ on my end is the i$$ue
Noisy 4WD button on 85 Wagon
just remove the knob, and remove the 4x switch, then put the knob back on
don't worry about it now, he's just going to put on a rebuilt when he can
call me asap 515-771-1239
hey, remember me? I left a message sunday! I'll call you today found a carb kit, can have it to YOU tomorrow! $20
think of it as your check and inspect t-belt reminder warning light for those of us that did away with the egr what 87 said above^
another accel dead
My 8140C was a "ture" bolt in in the ea82, and the ea81 I had to cut the bolt and drill out the hole to put a "real" bolt in, because the old "factory" bolt wouldn't budge under the influence of vice grips! there was no issue of it not fitting.
