Everything posted by subiemech85
Midwest Subaru Meet-April 24th and 25th starts 24th at 11AM
leaving shortly ...
I Hate Mice!!!! HELP!
I still keep pulling the insulation fuzz out that they made for me from the vents use OUST and JOHN DEERE MALODOR REMOVER, they work you can also use new car or courage little trees and don't forget the fresh shrubberies when they are in bloom, wow!
Road Trip II: TrashWagon's RETURN
turbo runs, they are here for the nite, heading out in the morning
WOW AZ. AZ Brat 5500 on ebay.. CRAZZZZY Bidder must be on crack LOL
it's even got the overflow bottle! instant jaw dropper!!!!!!
I am at eyesore's waiting for him to arrive
MilesFox, what's the progress? could drop off a car at my place if needed see you at the meet,, loaded with tools
Midwest 2 Weather Forecast
IT'S RAINING HERE, AND IN A HUGE RAIN BELT
Midwest Meet: Special Offer: Custom Decals
I'll order later when I decide and have REAL money, also will be an excuse to stop by your place!
Rejuvinating rubber seals
subiemech85 replied to dmplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsilicone spray lube, CARQUEST BRAND , works very good, good results, keeps seals from freezing too!
cv castle nut loosening
you never said anything about the big cotter pin that keeps the nut in place
fastest/cheapest way to gain ground clearance
tire pressure over inflate to raise deflate to lower works every time and is free
finally got paid today, have $198.81 to spend as needed!! can help work on whatever sunday, where's the car?
Is my weber a diesel?
glow plugs are a starting aid for diesels that do not use flame throwers, ether injection, etc. hitachi had anti dieseling solenoid for that purpose mmo works for cleaning, use it
Midwest Get-Together Near Omaha, Nebraska - April 26
is this post still active? praparation canyon state park, IA
Storage of a Wagon
sta-bil the gas and FILL the tank drain the fuel system, carb, lines disconnect battery, charge as needed use fogging oil, or sea foam to fog the engine oil all chrome and metal prone to rusting inflate tires to proper pressure place on jackstands and keep suspension in normal supported position silicone lube spray all weatherstripping lube chasis, thouroughly clean car and wax paint make sure doors are not locked good luck just have the car impounded, j/k!!
EA82 firing order
http://www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29dd8b7a4f46.89471656/&FileType=Image&File=New%20Image.JPG
ea81 brake experts? couple of q's.
bleed the mc, hh, then the brake lines
Midwest Subaru Meet Parts swaps?
MilesFox: remember deebo on the right front 85 wagon ea82 fender, and splash shield if you have it for my car ShawnW: dash cover, $10 for anyone: emissions control system is available from my 85 wagon carb
15.9 gal fuel tank yea right 86 turbo wagon 4wd
sure 16.2 to FULL completely ran out abot 500 feet from station, coasted in and filled up
distributor swapping
what you need to do is get ahold of every year fsm that has the dist advance tables and find one that you like, 85 had more than 10 tables!!!
Bypass EGR system? best way?
go all out and rempove the egr system and block it off, use a new gasket as the template, make the bolt holes accurate! you can also remove the asv system
Squeaking with a heavy load
I guess that when your car is similarily loaded in a month, you will discover that it was that wheel bearing, and you should have taken care of it a long time ago consider everything that rotates at wheel speed: dif, axles, brakes, bearings
Replacing the 4WD light switch
see if you can have access when you remove the gear shift boot? my lo and or park brake used to be on whenever it wanted to !
Check out this subaru site - lots of info
wow thanks!
what would be even better is gps cord's for the spot, and a link to geocaches in the area, and topo maps and aerial photos
