Everything posted by subiemech85
nice what's the wing from? / mounting? I started arc welding today, just making beads and starting arcs, will also learn gas and mig shortly
What does this hose do?
subiemech85 replied to hilux_1990's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it goes nowhere, except your bucket of parts, remove it the drain is a hole in the front of the air box which pic could you not open? iirc, you can remove the componets marked with red -
trashwagon 7 read about it here: http://www.ultimatesubaru.org/forum/showthread.php?t=12732&highlight=trashwagon it's for real
you could disconnect the line how you would do a a bleeder valve IIRC drum brakes $10 for the hydraulic part
topics include amc eagle, propane conversion, and subaru leone page is russian http://www.autoreview.ru/new_site/year2002/n22/4wd/1.htm
from what I know, roadranger "solo" clutch kit is the way to go if they make one for the car, no idea because most are for the big otr trucks Usually remanufactured is NOT worth the trouble you want a ceramic disc with dampening springs xl is usually NOT worth the extra money you spend for the FEW cents you save in grease ez pedal was designed to reduce the effort to accommodate the women drivers, and the weak ones by messing with the spring rates and angles a solo clutch can "break" by not self adjusting, but can be easily fixed with wd40 and the special tool
Vac Line Running into Filter
subiemech85 replied to BobBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm always here, but I haven't been out to figure out the system due to the rain all day, hope the weather holds out long enough tomorrow -
stupid rain gutter design
subiemech85 replied to subaru_styles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1. don't drive while raining 2. roll up window while raining 3. remove gutter trim 4. water resistant tweeters 5. remove tweeters 6. lifetime warranty tweeters 7. cheap tweeters 8. reposition tweeters 9. duck tape over tweeters -
i don't want to break them
subiemech85 replied to oddcomp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
search for window removal there are two ways to attach and remove the windwo according to the mounting method peel away the metal trim and knife the glue "hammer" -
Why Harbor Freight is SO cool
subiemech85 replied to Adam N.D.J.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.towerhobbies.com/products/fuji/fjig0064.html I saw this critter, and was amazed and the lineup http://www2.towerhobbies.com/cgi-bin/WTI0097p?MANUFACTURER=FJI -
there's also an engine for model planes post 600, good nite, pics later -
carb on my project car needs HELP!!!
subiemech85 replied to N8NQU's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the idle adj screw is on the front, by the ps pump on the left -
turbo hg is made of asbestos, others are not, according to the fsm
is there a way to wire up the ac elctric fan so that it has automatic control and manual with a flip of a switch?
12 inch lift pics, daylight pics of the new paintjob *Updated pics*
subiemech85 replied to subarubrat's topic in Off Road
what gives? are 91k images necessary? what browser do you use? I tried 1x, opera, netscape, and ie, no luck same issue with your website -
I have noticed that your pics do not download completely after over 13 minutes of downloading with broadband test speed of 467kbps and it's annoying nice color -
new t-case possibility *UPDATE*
subiemech85 replied to bushbasher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and it has option for pto:D -
for the support I felt like using the legal limits of flames and argues instead of making a mess elsewhere
I don't use any things that you speak of, I just "tweak" cars and computers I know what I talk about, and have a hi degree of respect and knowledge on the board, and in real life there's 4 subarus on this road where I live, and one is mine no smoke, drink, whatever :madder: :argue: :madder: :argue: :madder: :argue: :madder: :argue: :madder: :argue: I started this post after archemitis, and finished after bushbasher, not seeing that bushbasher had posted I'd like to see a pulley clutch system lol Hes not on crack he's just creative. I dont get the adding ceramic disc part though I'm creative combining necessity, opportunity, and experinence ceramic disc is something I have thought of a long time http://www.roadranger.com/products/clutch/clutch_solo_md.htm shows 3 pad ceramic solo http://www.roadranger.com/products/clutch/clutch_ep2000_epplus.htm is the ez pedal http://www.roadranger.com/products/clutch/clutch_solo_hd.htm shows solo 6 pad ceramic http://www.roadranger.com/products/clutch/clutch_solo_xl1552.htm shows the xl with many good pics
to lighten the pedal weight, drill holes in it to reduce the force, you "could" 1. add a pulley system for mechanical advantage, or 2. use a different clutch setup that changes the configuration of springs involving angles and rates to lighten the rotating mass of the clutch, you "could" use a ceramic 3 or 4 pad disc
before I read and looked at the rest, accelerator pump linkage, anti-dieseling solenoid, and air box didn't seem "right"
Emissions by the year
subiemech85 replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
depending on where the car was "intended" to be sold california 84 had feedback and 4x4
