Everything posted by subiemech85
Vacuum Lines (12/1985 EA-82)
subiemech85 replied to hilux_1990's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't recall anything that looks like the pic is it NON US model? did it go by the strut tower or engine? is there a small long line? i'll have to check my bucket of parts and the fsm -
your attempt at a"BUMP" should be more than a few hours apart try the usrm or the photo gallerly
one last snow fun run for the turbo brat.....
subiemech85 replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Madrid is reported as having 14" of SNOW:brow: I'll have to go to school tomorrow EARLY to visit the "donut shop" -
I see they have the new HAK4, still looking for a good mud/snow traction tire, I would also like some road noise , but that is optional http://brickboard.com/ARCHIVES/1997DEC/5797.shtml http://www.gosstire.com/Nokian.htm http://www.nokiantires.com/newsite/tires.cfm http://www.nokiantyres.com/index_en.html
!!BUMP!! Hitachi alt. wont come apart
subiemech85 replied to MaroonDuneDoom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
just replace it -
Webster City has only a very light dusting snow fun 3x SUCKS in the snow , couldn't go up driveway forward after I did the snowblowing decided not to risk it at a "donut shop" took 2 hours to do the driveway, shed entrance, parking by house, sidewalk, and path to chicken house before I moved the snow I took the sub. powered polaris, "MOM'S" down the road, through the field, and around the yard :banana: :banana: :banana: __________________ I'VE GOT SNOW HAPPY BIRTHDAY EYESORE:clap: and there's no sign of stopping:grin: -
lubejob, beat on the threads with the nut
Suday off-roading trip - damage pictures!
subiemech85 replied to GeneralDisorder's topic in Off Road
just an idea, may be expen$ive make one out of small I beam, and tubular steel to reinforce, sandwich the dif bar between plate steel and slip some tubular steel around the round parts -
Plug firing order on 83 brat
subiemech85 replied to vodoobrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
2o mpg. rwd:madder:
Another reason why not to use aftermarket manuals
subiemech85 replied to Dr. RX's topic in Old Gen.: 80's GL/DL/XT/Loyales...
is the other scale;) http://www.arvc.com/Torque_Wrench.htm http://www.mountztorque.com/ Menards $10 Taiwan special is an interesting unit with dual head and scale:D I prefer deflection beam type, cheap and versatile, no settings required -
85 gl station wagon-no pick power
subiemech85 replied to plantladi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1. shift at 4,000+rpm 2. IF you ned to accelerate quickly, drive it in LO, then at 55-60mph, shift to fwd, works better because of the "closer" ratios and 4th and 5th do NOT act as over drive remove emissions controls, I have posted my how2, search for egr remove 3. good tune-up including proper spec ohm plug wires, ngk plugs, .045-.05 gap, accel 8140C coil, cap, rotor, filters, change oil, mmo down carb 4. 8* timing advance with vac. line disconnected and plugged EDIT: connect dist advance directly to intake manifold 2" exhaust with glasspack at end, more searching, good luck -
I only had ONE partial can of WESLEYS rubberized undercoating, great stuf, had to finish with stuf not so great, 3m, solderseal and other brands didn't have the color/texture/coverage as WESLEYS
hitachi rebuild kit
subiemech85 replied to subestyle18's topic in Old Gen.: 80's GL/DL/XT/Loyales...
carb good, manifold to carb gasket bad solution: rebuild kit, incluses gaskets, seats, NOT THE FLOAT the GASKET is available separate http://www.oreillyauto.com/B2C/conditionselect.ecatalog?x_0=Y&submit=Continue&vehicle=vehicle0&category=9&group=13&keyword=+&description=+ Add Qty Description Part No. Unit of Meas. Unit Price Core Price Status BORG-WARNER BWD Float 1 per car. CF502B Card $7.29 N/A HITACHI EQPD BRASS 1 YEAR LIMITED WARRANTY * WALKER (WLK) Float 1 per car. 100-138 Card $6.99 N/A 1 YEAR LIMITED WARRANTY BWD Float 1 per car. CF502B Card $7.29 N/A HITACHI EQPD BRASS 1 YEAR LIMITED WARRANTY * WALKER (WLK) Float 1 per car. 100-138 Card $6.99 N/A 1 YEAR LIMITED WARRANTY WALKER PRODUCTS WLK Air Accelerator Pump 1 per car. 764F WLK Needle & Seat 1 per car. 31-651 CHECK CARB # WLK Needle & Seat 1 per car. 31-657 CHECK CARB # WLK Carburetor Base Gasket 1 per car. 1054F CHECK CARB # WLK Carburetor Base Gasket 1 per car. 909F CHECK CARB # WLK Carburetor Kit 1 per car. 151051 Each $18.99 CHECK CARB # 1 YEAR LIMITED WARRANTY WLK Carburetor Kit 1 per car. 15853A Each $23.99 CHECK CARB # 1 YEAR LIMITED WARRANTY -
That's why there is NEWTON METERS, saves the confusion:banghead: :wave: -
I have always wanted to ask what this is?
subiemech85 replied to mickytrus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
a pic would help which route is it in, supply, return, vapor? may be a damper -
I had to decide to either fix the seville or the subaru, and I went with the best option, the seville is too nice of a car to drive it during winter in IOWA SALT and snow, hardly any dings or rust the subaru is rusty, and suffered a slight interference with a power pole, and is fun in the snow, and cost about $100 to fix:banana: I have found many pages of good info on the cadero sites for help with the 4.9, including power and rebuild, will post links later
nothin but car/ truck issues this week(long)
subiemech85 replied to Mykeys Toy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it may be a leaking gasket pressurizing the system and blowing out the weakest point, possibly a plug, hose, gasket, or the overflow remove t-stat and boil it -
do you by chance want to change that fiero to a cadero? http://autos.groups.yahoo.com/group/CaderoOwnersForum/ I have a 91 sev with the 4.9, that has compression in 7 cylinders,didn't know whin I bought it, because I was used to the 4.1 in my 82 eldo, was working on fixing it, but haven't done anything for several months, weather/money
