Everything posted by subiemech85
feedback carbi or not
see if there is a computer under the steering column area, and unplug it!
Holy S*#@!t...............
(would take me a year and don't like buying the 1st years of new models) I myself enjoy buying "first year" cars, ex. 82 cad eldo with the notorious 4.1, 91 cad sev with the "upgraded" 4.1 that is a 4.9!, and my current sub gl 4x dr 85, I have also found that reading the first years manuals are very interesting
Questions About Lifts
where have those last two pictures been hiding? what is the best way to gain ground clearance with a lift?
carter carb
no, but I have one from an 84 here, probably the same
wish me luck!
it's 13"4" A, not "5" how about headliners, head gaskets, timing belts, rust repair, trunk monkey? discount for ca$h work on all older models, leone, 360, brumpy, ff1, and others
I Hate Mice!!!! HELP!
rust holes! crawled up tire, rust hole in rear, to duct under seat to chew a hole in a middle vent!
also check out of sitght, out of mind areas, such as the rear wheelwels, and things "left" in the car, found one in one of my shoes!
is ea-82 a good engine???
atleast it is all aluminum, unlike the cadillac 4.1-4.9 engine series with cast iron heads and aluminum block
heavy clutch problem, leone gl-5 fwd
2wd has 2:1 ratio, 4wd has 3:1 ratio, to reduce peddal effort
Goin Nuts HELP!
check for correct application, alignment, and a tight fitting joint
POLL: Where do you shift
I shift at 5
DL vs GL?
and I think of the power windows and mirrors a "necessity"
alebit that my car does better in mud at redline, it craps out shortly above that
Replacement clutch?
http://www.specclutch.com/specMain.html is also good, wide selection http://www.clutchexpress.com/performance.htm sells clutch kits, free shipping, pleasant! http://www.daikin-clutch.com/index.shtml major OEM supplier, partnered with eaton years ago to make new line of hd otr clutches, good videos!!
how tough is your tranny ?
how about to the back of my wagon? I have a "project" for it
MC, where did the 5 come from, and where is the 4 going?
DL vs GL?
also an obscure fact is the dl , devoid of luxury, does not have the rear heat passages enabled, they just hold the carpet in place
mounting gauges on A-pillar
put a clock in the second one! is there a 3 hole that works?, or 4, or more???
D/R and S/R Tranny Q's
you can convert manual pushbutton to lever selector, and keep it sr
just bought new starter and was wondering....
I thought they were fuji or hitachi the 84 olds with 5.7 diesel has a mitsu starter, and no problems in cranking
Another Dead Accell
you are getting SCREWD if you pay more that $5 extra!
Weak Link
try a daikan "exedy" clutch the clutch is the weakest link go with ea82 5spd dr
can someone take a pic for me.
need ea82 asv gasket
yes, there is one, but where do I buy one?
help me ID engine & tranny
and they may be swapped in older products, ex. ea81 trans and ea82 engine go together
