Everything posted by subiemech85
Unhappy Weber!!!
heat the surrounding area with a torch, use a stud extractor make sure you use GOOD VICE GRIPS NADE IN NEBRASKA
How to tell if the turbo is not working
you should become familiar with "turbo whine", even at idle
DIY EA81 Tranny Mounts
the link at the top does NOT work does the "super weatherstrip adhesive" work good? I bught 08008, black, 5oz. how many tubes are needed to do a mount? http://products3.3m.com/catalog/us/en001/government/innovative_solutions/node_GSN04SFBB0gs/root_GS3RBW6QFVgv/vroot_31S2JJ7584ge/bgel_GSYHNJB2MYbl/gvel_J80MWCFZCDgl/theme_us_innovativesolutions_3_0/command_AbcPageHandler/output_html
Would the half shaft...
I have an ea81 84 that you don't have to shift at all!! why not go with an ea82 5 spd dr?????
new GL owner with some Qs
replace t-belts and h-gaskets after they blow
Oil Cooler adapters,permanent avalibility!
sold!
Pictures from CV axle replacement work.
there is another way that I have used that takes 3 hours both ways, but that included stoking the stove every 30 minutes while the snow kept falling, and the wind kept howling, and I kept shivering there is also the easy way that includes pulling the engine, transmission, rim, and finally axle, but save that for later today the bolt marked "no touch" I had to!!!! enjoy :biggrin:
online fsm, 2004 sti :banana:
http://206.13.93.15/STi_Stuff/STi_Manual/ found when searching for the special grease for the steering online fsm, 2004 sti
AHHH Brat is making me mad *UPDATE!!*
you need to adjust the valves AFTER you rebuild the engine check the oil pressure sending unit with an ohmmeter, the tool that measures resistance install a mechanical oil pressure guage, and skip the step above^ install new 15W40 oil, and a new filter and drain plug gasket after breakin it is also good to make sure you have the correct NGK sparkplugs bpr6es-11
rear dif hanger swap?
what does it take to swap rear dif hanger from ea82 wagon to ea81 brat?
I believe this is what you are looking for: http://www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29dd8b7a4f46.89471656/&FileType=Image&File=New%20Image.JPG
EA82 parts swap into a EA81?
so does the spare tire support, and exhaust
EA82 CB mounting
I liked it when I put it on my "luggage seat" Miles used long bolts that stuck through the roof
I'm driving a Brat
that's Wi-Fi Hijacking
ea81 LOUSY gas mileage?
and I can't figure out WHY???? it used to get 24mpg
Ruh roh... broken intake manifold bolts... (ea71)
if you have any metal close, you could have the bolt TIG welded
1986 GL sedan alternator problem
run the car wirh the alt disconnected, it is probably the distributor bushings going bad, search "jumpy tach"
why does the 83 ea81 california emissions feedback carb wagon get only 16 mpg?
monster ea82 wagon update!
you've got that but ugly fwd selector, which started in 86, otherwise nice
Well makin some progres... next comes powersteering
buy one quart of John Deere Hy-Gard, low viscosity, and it should work good serious pump cavitation may be a problem with running the pump dry
Herby Derby?
I now go to combine demos, they are lots of fun it's alwaws a challenge
Brat t-top tinting ideas??
use stickers and wall art, be creative, kid's hand prints
Anti Theft ?
remove the rotor be wary of swap meets when a guy buys a distributor for YOUR car!! true story!!
My Car Tried To Kill Me!!!!
replace cap, and thermostat remove the black o-ring from the green overflow bottle cap check hoses
El Junkyardo
the jy in WAUKEE, WRENCH AND SAVE, yeah rite, thinks their 86 xt in an 86 gl, and wants $150 for the mpfi, and $100 for the fwd, and seat covers are $15, and shift knobs are $5, and I dickered them once 50%, bought the distributor splash shield for $5, told them that's all I have
