Everything posted by subiemech85
mouse made nest and died in the fan, need help getting it out
and I had a vibration problem, pulled the air box and duct work out, the division caught a huge mound, and the fan was full, but it still worked, now setting 1 was setting 4, glad I cleaned it
cig lighter wiring
or impact wrench, light, radio, vacum,or chainsaw!! I love my power supply
Drain Plug Tool or Just Ratchet?
just use an extension and impact wrench, pops them out!!
stop leak for diff's?
which scientificaly tested product are you refering to?
Hello to all Subie maniacs . . .
found them http://www.speedywheels.com.au/images/zoom/desert-rat.htm check out the usmb "wheels" page
experiment for keeping out mice
no, it's the tonite show!! this topic has been discussed, search
Is anyone running synthetic fluids in their subies?
so then, any difference with royal purple purple ice and redline water wetter?
Anyone else with holes in their heads??
IF the holes were not there in the gasket, but "nature" put them there, then make them for the replacement a blue roloc will do wonders on aluminum brown for brakes, flywheels and pp green "sandpaper" for grinding rust it's a matter of tools
82 subaru...towed home...runs...rallied (video)
my guess just by looking at the video, it's an 82 dl, orange dash gave it away if only... it wasn't so far away! atleast I have my snowmobile trails :tongue:
SQUISH 78k mile ru meets untimely end.
a CHEVY like yours is "squirly" in 4x4, and you can't max out low, stupid auto's
reminds me of the slick 50 commercials!
Subie Half Doors, Anybody run them...
subaru does not use window frames, as does not gm older snaps, velcro, magnets, duck tape for us!
could you be more specific as to which trans you have? if it's a justy, run the thinnest you can find I have synthetic turn signal fluid, now it sounds good! :cool:
mounting reverse lights, ideas
brat has metal bumpers, and wanted to know if it would be good to cut a window out to mount the lights in the bumpers, can't go below, as they would be ripped off - already used the license plate to plow grass, can't go above the bumper because of the tailgate, don't want to go on the ends as they may be ripped off! looking for a better idea or approval
rear 4x4 noise
why would the u-joint start making noise after the transplant when it worked fine in the wagon?
rear 4x4 noise
it's an 84 brat with 85 wagon clutch, driveshaft, and transcarrier bearing is good, no mounting problems oil was full makes similar noise when hitting bumps, running on rebound stoppers it's definately there when driving in 4x4 and not there when driving in fwd, when driving in same path
rear 4x4 noise
nope, noise was there before and after I did the brakes, all looked good
Ok For All You Mechanics Out Here....????
I'm saying it's something to do with the crank, pistons, main bearings, or rods, as the FRONT has low compression
rear 4x4 noise
sounds like woody woodpecker when driving in 4x4 from the rear tires and tire pressure same on all 4 the driveshaft did not make any noise in the previous car
just pop off as many of the clips you can reach, and pry the box open so you can go through the side opposite the firewall
EGR Removal
http://www.ultimatesubaru.org/forum/showthread.php?t=14727 http://www.ultimatesubaru.org/forum/showthread.php?t=15126
? Justy 5 spd 4x4 good in snow?
thanks, looking for more opinions, do they have a good heater?
is it? do they have "issues" with rust? $ 1300 seems a little steep, but new clutch kit and battery, claimed no rust florida car 90k miles
O.K. I'm Impressed!
it is NOT AWD, JUST 4WD D/R RUN IT IN FWD UNTIL YOU HAVE TROUBLE!!
Bon Ami on Windows ?
subiemech85 replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUse Bon-ami For Glass And Paint, Cleans Good Read Instructions I've Done It With Good Results
