Everything posted by subiemech85
Replacement Driver Seat Foam ???
beaded mat, walmart $5 chair seat cushioons walmart $5 seat cover walmart $5
Anyone know where this goes?
ebay
Starter Compatability
you must watch out, as the "as origionally equipped" makes a difference, there may have been at least 4 "flavors", california, auto, manual, trubo, but they "should" work, may need spacers
Anyone need a carfax??
sending you a pm VIN: JF1AM43B7DB431156 Year/Make/Model: 1983 SUBARU GL ????mystery????
81 EA81 Wagon questions
you just opened up a new can of worms, start shaking and looking, good luck
No idle with less restrictive intake?
I could only think of choke
1. it is NORMAL to feel significant resistance while turning the wheel if you are stopped or moving slowly, it is MANUAL steering the noise may be the clutch cable hitting the steering shaft, very likely and common your WIFE needs to exercise her mite, or try a different technique 2. the problem is YOU DO NOT DRIVE ON HARD SURFACES WHILE IN 4WD IF you find it nearly impossible to shift out of 4WD, try driving up on a slight hill, set the parking brake, shift into reverse, and work the lever
?? does a FORD PINTO carb replace... :brow:
no, it is more than just clearing the dist you have to extend various wires, coolant temp, oil pressure, etc. swap throttle cable bracket remove and plug the bypass line that goes to the t-stat housing, reroute bypass lines remove the tab by said bypass line remove metal on alt bracket mix n' match emissions lines use ea82 upper rad hose, air box and other tidbits trust me, I've done it I did NOT do anything to the dist. quit HIJACKING this thread
Another one bites the dust.
looks to me like the turbo puked the wastegate, what else would explain the location of oil?
QuikSteel use on exhaust....
and while I was driving, I thought why not cut a can to fit, spraypaint?
just run open ports what happened to the other spacer?
"New" Off-Road Lights
strip off the plastic to reveal the thin metal and drill the correct size holes, it works
will a ea81 radiator mount into a 87 wagon?
please DO NOT DROP, insert gently I could visit after 4 today
Census on Hiclone... Tornado... Air Swirler thingo
you might as well spend the $160 on pinwheels gulible about as effective as flushing money down the toilet, whatever way it swirls I'm going to mount pinwheels
'87 Wagon Tilt Steering
the jump up is the button you push in on the left the tilt is the lever that is above your knee
Air filters? Stock Box/Cone/Snorkel
I'm not sure what the tray is, but when I had to drive in serious rain, I ran the hot air intake pipe from the warm air intake port of the air box to behind the carb, and set the vac line so it did not take in fresh air, ea82
an ea81 carb?? I'll see about that, they both have hitachi chokes, appear to have the same bolt pattern, and are made in JAPAN Only major preliminary differences is the float level window is 10x larger on the ford, and it uses a round air cleaner
I prefer purolator .
Alcohol injection?
moonshine? everclear? fermented RICE? if using "RUBBING", it is 30% water, 100% is available what about ethyl, methyl, and others? propane injection is for diesel, works like nos for gas
anybody have decent scans of 87 FSM wiring diagrams
choke is a blue w/white stripe, and another wire, as on ea81 climate control goes from intake manifold to canister, must have, to driver side entry, to junction by heater lines, as in ea81, up to the push buttons
heater controll question
the round ball thing is a reservoir, holds vac to run accessories when you have no engine vac, that is your program
Online factory service manual (FSM)
check your fuses, fuel filter, sparkplugs
how do I get the
unscrew the back walmart sells a replacement, $5
Exaust Fumes!!!
exhaust gaskets, joints, rust is it so bad you must either A. keep the windows up, or B. avoid idling in place ??
Immediate Opinions Needed!
yes, do it ALL yourself, or with VERY GOOD help, that way YOU blame YOURSELF, and LAUGH at yourself
