Everything posted by subiemech85
Light bar/push bar photos: Can I see some?
http://www.alphalink.com.au/~mwpwjw/RooBarsWWW/index.htm take a good look, many ideas
my new console set-up with the 5 speed...
do you need help welding? have access to mig, ac, and dc, and an auto darkening helmet!!, and the usual tools
I *HATE* T-belt covers...
something like "jeep" hood latches, possibly the stretchy rubber type found on new holland spreader shields
I think I Can! I think I Can!!
I "collected" a trailer wiring harness connector from a 89 dl that still has the hitch
Problems up the ying yang
easy way to tell if you have a vac leak is to see if the engine shakes badly when idling around 700 rpm
t-belt cover what if..... continues
I have cope, drag, and parting sand, and have thought of doing something out of sheat metal I just want it to last
Back Home in Misery
just remember a transmission can give up at any time for no apparent reason
how2? remove xt shifter
what is the trick to remove? trying to put on my gl
long long long time bump! lay off the alcohol, and whoop those books!
Where does the Justy owner fit in on this site?
I found a suzuki samuri at a jy, what parts are swappable into a soob? sorry about the jack, just seemed to go here
Off-road Justys?
sorry, but you're wrong, the toyota tercel has an inline 4, not transverse, and offers 4wd and super low for first only, so you might as well not bother I found a 88 justy, complete in the jy, looked to be carbed, tried to buy it, but "we don't sell those cars" you might have luck with one of the imported for plymouth, imported for dodge, imported for chrysler colt vista econobox., which is a mitsubishi
Why'd they do that?
Is Miles' tail tucked between his legs on the mystery of a trans? this'll perk up his ears: as soon as I build me a trans stand, I'll be tearing apart a trans from Mc's red brat, a 82 dr, and will have pictures!!!! and if I can fix it, I'll tear into my 85 dr, and swap the 82 for the 85 I like to call it revesrse engineering
? about trans service stand
I buy tools when I have a need, and now is the time have you had any luck?
BRAT shifter kart under way
how about using a fuji product for the powerplant : polaris snowmobile engine, airplane engine, or a robin engine? that would be cool
To tide you over, an awesome photo from "Catch This Fox"
As I have personally experienced, small rotary tool with cut off wheel, and a drill, problem solved Yes, my car is trashwagon 7 no, I did not play on that sand, but I did find a suitable hole to mess up my rear bumper
Oil and Air Filter ???
Walmart 3600 Fits Nicely!!!!!
does anyone have one or used one, or made one? I am going to make one do you have an engine service stand?
Chef Tim went and did it!!!!
DON'T feed the bears!! good you bought something you could afford
What is this exhaust thing on my EA-81??
the ea82 has a port on the head for the asv, block off with a plate removal boosted power
has anyone had the Guts to try this?
what do you want to talk about? see post in off topic
Where does one get paint for these old school cars?
no, it comes out of walmart spray cans, gloss black is a purfetc match!
Electric Fan Issue
there is a fuse for fan on ea82, also if ac, disconnect one wire from the switch on the small ac line closest to the rad if ea81, the rad must be grounded
Clutch going? Valves floating? OR just old Loyale?
it may be justification to buy a decent thermometer: http://www.raytek-northamerica.com/cat.html?cat_id=2.3.3.3&PubSessID=4a292283958caa92e9cb688e03484a8f&PHPSESSID=publicRaytekNorthAmerica has very good instruction manual to diagnose many problems http://www.extech.com/instrument/products/400_450/42530.html is the one I want to buy, $80
Starter issue????
for "testing" purposes only how to hotwire an ea81: key off hotwire to coil + from battery separate hotwire from single male spade terminal on starter to batery presto! it runs doesn not work on ea82
Has anyone ever put a EA motor on a Motorcycle?
why bother when there is a honda goldwing, with a redline of 8!
