subiemech85
Everything posted by subiemech85
  1. I have used this charger many times, never any problems
  2. need better explanation of how to position bar top or bottom, left or right for remove
  3. http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=9250 This is what I referred to as "jacking of the SOA battery" It seemed like jacking to me.
  4. HOW IS THIS AN EMERGENCY? I bought 4 pugs steel 504 2 tires hold air, 2 don't, 7 lug nuts, $25
  5. I have created this post due to the jacking of the SOA battery. I have a battery charger that is one amp. That's all it puts out, but it charges well. I assume 2 volts for each cell or service port. 6 ports X 2 volts = 12 volts
  6. Tennis balls, stuff them inside the spring center, this wasn't my idea, but car came this way pic to come later
  7. That's why I specified 3/4" drive ratchet, I have a nice Sears I am not afraid of returning! And you wonder why I return Sears and Break China so much :jollylaugh:
  8. http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=7890&highlight=cover "since I know a lot of people on the board have EA82s, and since we all know that the timing covers SUCK, what if someone (like myself) started to make them out of aluminum? If I did, who would buy them? Just tryin to figure out if it would be worth it " Caboobaroo
  9. 14+ volts makes them fly 10- volts makes them slow
  10. I'm going to contact the company about what they can do, and about that Aus locker.
  11. Remove the pin! Rust penetrant, 3/4" drive ratchet, long pipe, jump!
  12. check the options http://www.tractech.com/Products.htm
  13. did you remove the plastic boot, then lube? check voltage, connections
  14. need to know part# for seal kit What's mickey mouse got pic? ea82
  15. once found an O'reilly guy that his dad worked on subaru 20 years ago, well, I had him look for a timing belt for an EA81 :laugh:
  16. picture page brat column brown bar blocks words the "FIX" opera, toggle between user and author mode, and F11 otherwise, great
  17. used to keep spare oil in the rim with the tire u-way, ea81 removed tire to check timing, and pcv valve
  18. is it possible, what's required? My idea for it is you put it in 4LO for the occasional "Whoops", not driving, that's what 4 HI is for
  19. or click to go one away, then click to go back, but THIS PROBLEM NEEDS TO BE FIXED
