Everything posted by JonOfScio
what years had round lights
yeah, the early 80s had round headlights... my '88 hatch has dual squares.
Pick N Pull 1/2 Price Weekends for the month of October!
see, oregon does suck.
the EA82 manifold and hitachi swap (onto EA81 block)
carb base gasket, and manifold gaskets planned.
so... people say EA82 manifolds work on eA81 cars. and the mounting area for the carb is slightly larger... so of course if I was to put on a weber, I would want the EA82 manifold just because it's a little bigger. but until then, I plan on using the 2bbl hitachi on the manifold ($30 from JY) which I am going to pull tomorrow about 9:00AM. I've heard there may be some issues with the carb switching over for the ECU (yes, my '88 hatch has a 2bbl ECU controlled feedback carb) but I'll know the exact details of: 1. If it will work at all 2. How much work it will take to swap 3. How much better the EA82 2bbl hitachi is this is all fun to me, may not be to someone else, but I think it's sounding more fun by the moment. *plus* I'm going to clean the manifold and paint it rally blue. cool.
Engine Rebuild
cabooboo: sounds sweet to me, to actually say "hey, that badass car, I got to work on it's engine." sweet.
Engine Rebuild
I'm about (in a little bit) to undertake that myself on an EA81. Got a spare engine I'm goin to build up and then swap in. I'll need: ring compressor, valve compressor, have a torque wrench, anything else as far as tools?
emisions and fuel delivery
I have my AIS disconnected and my whole emissions setup replumbed for better performance.
yeah buddy, score!
the weber swap is planned. the new carb is only because mine is slowly slowly dying.
yeah buddy, score!
I'm gettin myself a new intake and carb for my hatch (EA81) for $30! The local JY in my town said, "$30 for the EA82 intake and carb." I think the cool thing is that it's... an EA82 manifold, which is better period, and an EA82 2bbl hitachi, which i understand is also just better. And my car is with a ECU, so it should swap over. sweet.
New hatch owner, have a couple questions......
do a search for "PK Davis" and one for "BYB lift" As far as chevy rims, you need to knock out two opposing studs diagonally, and then drill four new ones to work with 6 lug. Or redrill the 6 lug if it's not going to be a looker, redrill it with a new 4x140mm pattern.
Performance clutches
check out centerforce clutches, there's a dual friction race clutch they have that has a lifetime warranty. Burn it out, send it in, get a new one. About $210 without TO bearing.
ea82 carb/manifold, on a ea81?
I've got an '88 hatch with a 2Bbl hitachi that is a feedback hitachi. It looks identical (of what I've seen) to EA82 hitachis. Can't wait for the day when It has a weber and no O2 sensor. (three way cat with no 02 sensor bung)
Clacking Engine
could be a bad bearing too (main bearing)
the adventures of axle land.
Ahhh... at first if you don't succeed, ask everyone on the boards. So, finally having gotten the axles off, the problem one of course was the driver's side, where it had no boot on the DOJ side and the CV ripped in half. Needless to say, all of the grease was under the car around various parts, and *not* lubricating the joint. So hopefully I can manage to slow/stop the progession of "degression of the joint" and get more use out of it. Brake cleaned the inside of the CV joint, not taking it apart. Got all the gunk out. Cleaned all the parts and bearings and pieces of both DOJ joints of the axles. Got the boots to stay on really tight (though methods hard to describe, some using hose clamps... hehe!) Anyhow, point is, spent most of the day covered in axle grease, and I'm not even done yet. got them finished, looking good, moving smoothly, completely not worried about the boots coming off, and I need to put them back in and bolt various other parts of the car together, then I should be driveable. I'm sure tonight I'll have some sort of a weird dream about axle grease and the wonders of my car.
subarus breed more subarus
I'm still on my first hatch, I had the opprotunity to buy an XT from andrew not too long ago, but I was afraid of getting laid off from HP, and well... let's just say I'm not selling Cell Phones for Sprint because I want to. Anyhow... my girlfriend said the other day... "I'll always remember your first car." I said "First? Who says it has to be my first? First implies next, and I don't care for that." She's like "OMG, you don't actually expect to keep this the rest of your life do you?" "yeah, it can only get better!"
Weber update
I didn't even pay attention to the '82, I saw he said OHC (overhead cam) and the only engine with that is the EA82, but if his car actually is an '82 with an '82 engine... then yeah, it's an EA81 pushrod.
Weber update
pretty much, just that it's an EA82. The only thing that changes between engine models is the adapter I think.
White smoke after cloverleaf
by grabbing some parts of an EA82 car, I have the hose (from throttle body to air box hose) and used all of my existing connections and rearranged them (some longer tubes needed) so now my carb has an spfi hose on it with a 4" deep dish chrome air cleaner + filter and has all of the old PCV hoses hooked up to it. nice.
Rotated the tires... now the car shakes!
I think your camber needs to be adjusted.
main bearing question, plus rods question
reading back in old posts, EA81 stock is 8.7:1, EA71 in an EA81 block is about 9.0:1 and SPFI EA81 pistons are 9.5:1. Because the similarity of the EA81 and EA82 pistons and rods, it's possible I could just use the EA82 pistons and/or rods, whichever it is that is bigger in size that results in the increase in CR.
the reason for new bearings is because the EA81 1800 NA carbed engine I'm going to get has bad main bearings, thus, the need to replace them. and if I can just get 1600 rods and not have to worry about the whole kit and kaboodle of the rods and pistons, then hey, I'd be set. That plus the gasket set for the engine.
I can get .25mm over main bearings for the same price as regular ($32 at shucks) Isn't .25mm over going to be better because it's just bigger? Will it fit guaranteed on my EA81? These were parts listed for EA81s anyway. And aren't the reason why 1600 pistons get higher CR in an EA81 because of the rods... couldn't I use EA81 pistons and use the EA71 rods and get the same thing? Thanks. (you guessed it... rebuild time... mwahahahah!)
boneyard hunt, maybe 9/29?
I might just have to go that route if i couldn't find any of them (straight grills) in the area around here. Reason wanting new grill and light bracket stuff: I painted mine a silver color and now it's coming off and it looks dumb. want to go back to black. (back in black!)
No ECM?
my '88 hatch, is kinda an odd one. Early 1988 hatch. You think... hmm.. probably good for an EA82 in there. Nope, it has an EA81. And it has quad head lights. Like that from an 84. All the parts on my car are EA81, and if I ever order parts, I HAVE to order '84 hatch parts. So, I've got the hitachi, 02 sensor, and the ECU in my car.
Hitachi to Nippondenso Disty conversion.
I've got a hitachi carb but a nippondenso rotor... accell coil... yep.
