Everything posted by JonOfScio
it is possible... to turbo a carb.
I'll hopefully use an EA82 turbo or a Chevy Sprint turbo.
Nothing fancy needed, you just have to make sure that the air blowing through the carb isn't more CFM than the carburetor is rated for. I've read articles online, of people who had V6 cars with carbs and a turbo. (stock) So it CAN be done. Thus, I will continue with my dream, of a Turbo'd Weber 32/36 on an EA81. (calculations show my engine at 7PSI would need 220CFM of air, the carburetor is capable of 350+CFM.) People who say "you need low compression pistons!" don't remember that in the turbo/super charger world, under 9.0:1 is considered good... and those people must remember that someone has already done an EA82-T that has 9.5:1 pistons. (Dr. RX) this'll be fun. PS: Russ, Andrew will nail your foot to the floor if you don't get my sh1t to his house and start work on my car. PSS: I'm not as anxious to get my car running as he is.
Too cool man (long)
I replaced mine with a 180, and it ran great. When the radiator fan kicked on (sometimes it didn't!) it ran well and never had any problems being too cold or too hot. I suggest the 180.
Death to emissions! MWAHAHAH!
now, I hope your talking about an NA car. Turbo cars don't want any backpressure, because the turbo makes it's own, and anything after that doesn't let it flow as well. But for NA cars, some cars are designed for maximum performance with good exhausts, and the cat is part of the backpressure for the engine... but for our subies, as long as you don't run HUGE exhaust without cats, it should be alright that you don't have the second one. Taking the second one out should give you a bit more performance. Not a whole lot, from what I hear, but I haven't played around with that yet.
I've got two PCV breathers with 5/8" outlets (inside it's got a foam material, and a screen mesh... catches the oil) passenger side will have another breather on it (for air) and the driver's side will go right to the PCV valve.
blown turbo help
dude, there's a JY with a perfectly good turbo in my town (Scio, OR) and he'd let it go pretty cheap.
I've got nothing left on this beast that amounts to anything emissions except for the cats. The air injection system is completely taken off the heads. the heads are both driver's side heads, so the passenger one doesn't even have the spot for the EGR tube, then it's plugged on the manifold and the diaphraghm is closed and not active. disty has one line to the manifold, and my brake booster too. new clutch stuff... pad, pressure plate, TO bearing, ect. fuel system is still set up with send and return... oil pressure and temp sensor are the only things from my dash hooked up. (NO ECU!) can't wait until this Weberized de-emissionsified engine is back in and tearing up the neighborhood.
blown turbo help
you could do the legacy turbo. or buy the turbo out of the turbo XT in the town I live in. (scio) he'd sell it for like, $50 or $75
Is this '83 worth it?
if the body is straight, then $300 is good. You could either transplant a new engine or fix this one up real nice... and then the interior you could replace. put a couple hundred bucks into it and make it really nice, then sell it for just a bit more. Or fix it up and drive it like hell!
ATTN: caboobaroo
hey man, I still need my heads. I'm probably going to call about 9:00. Jon
great new engine paint
hehe yeah, it's alot cooler looking in real life. When I get my heads back all cleaned up I might do semi-gloss black or continue with the red. (valve covers are black)
ea81 axel questions
EA71 transmissions and axels are completely different EA81 and EA82 FWD transmissions are exactly the same EA81 and EA82 front axles are different, but left and rights among designation are the same EA81 rear axles are different from front axles, and are swappable between left and right. same with EA82.
weber on ea71 or dual ea82 hitachi??
if someone wanted to really go all out, on an EA81, they could get the dual carb manifold, and put on two 38 DGEV carburetors. along with a beefy cam, with higher lift (torque cam preferred) new hydraluic lifters new evenly weighing pushrods (exact weight is preferred) new evenly weighed lightweight forged aluminum 10:1 CR pistons ($400) new/used 1600 pistons rods (handle more than the EA81s do) new hi-po valve springs, new valves... (replace all valve train basically) I'm sure if someone out there in this world did all of that with a good port and polish and sweet exhaust, they could have an evil carbureted monster. Don't forget a nice 4wd Centerforce clutch. (dual friction race clutch, lifetime warranty, kit is only about $250)
I found some really sweet new engine paint. It's not advertised as such, but says that it's good for up to 500 degrees fehrenheit. I painted my manifold and some of my PCV system components with it. Later on, my block/heads will be clear coated after being cleaned, and my valve covers will be black. I'll go take a good picture of the colors goin on.
whatever funkmeister, you are drooling over Andrew's dual EA71 manifold (with non-feedback carbs)
you can't put EA82 hitachis onto an EA71 because of the bolt pattern... you'd need an adapter. EA81 and EA71 bolt patterns for the carbs are the same though... need a EA81 hitachi in good condition?
YAY! My lift is in! - UPDATE - Installed the Tires today!
ah, I was just going off of what I heard from others.
Muffler Upgrade Suggestions??
my muffler fits just fine in place of the stock muffler. Dynatech Raptor II turbo muffler, $20 on sale from KNechts
actually, drilling the hubs is ALOT more work than people tend to think. There's more to it than aligning it and drilling... there's a lip than needs to be sanded off, and that is alot of work in itself.
I use a 2" Raptor II muffler, which is a great muffler at about $20... It's still a muffler, but makes the low end a little bit more audible and doesn't sound like a raspy glasspack. There are glasspacks out there that are pretty good on our subes, some would be: Thrush muffler Flowmaster Purple Hornies Cherry bomb See what other people have, and decide from there. Or try and catch some sound clips on the net of an interesting muffler.
saving up - new exhaust
of course, when I get the car running. 1 5/8" ID, 1 3/4" OD mandrel bent tube, 10 inches down, 10 inches long, 180 degree bend. going to 1 7/8" OD tubing going to a cherry bomb In 2" ID, Out 2" ID. (each side) No H- pipes, but might be able to fit in some a T on each side and a tube running between them. opinions, questions, ect. PS: Cost: $101 for flanges, tubing, mufflers, bent pieces, shipping (not including hangers) plus time welding.
looks like i'm gonna be afoot here very soon
hm you might be able to sell it whole, but parting it out is always an option.
FT4WD tranny trouble...noise!!
yeah check all your front end parts basically.
