Everything posted by Loyale 2.7 Turbo
Yes, you Should. Otherwise you'll never be Sure if timing is set properly. Yes, re-check all vacuum lines. The EA82 writeup I did, applies in a 90% to the EA81, the main differences are regarding the Adaptor Plate and some minor stuff that you'll find once you do it, maybe you're loosing the patience / lacking the time to do all the things it requires to be properly set; in such case, you might ask the help from another USMB member nearby your Area... But Check the Timing and Vacuum hoses are a Must... Kind Regards.
Have you Double-Checked the Timing?
Kia Sephia Sporty
Here's another view of the Windmills, on the Roadside:
Loyale Parking Brake Adjustment o_O
Somehow, this thread is getting Funny! If he is spinning the Rears... ► then the user is the issue: The parking brake goes to the Front on these EA82's If he is spinning the Fronts... ► then I bet that the Parking Brake Mechanism is worn and needs a rebuild. Usually the small steel "Triangle" worns out and fails to Push the Bolt that pushes the Piston... I got rid of such mechanism and erased the front parking brake from the Calipers, long years ago, because they get worn out beyond any safe repair, so my "BumbleBeast" features a Custom Rear parking brake, which holds stronger the Subie on our mountainous Honduran streets, plenty of steep hills... Kind Regards.
How To Keep Engine Cooler? Any Ideas?
Exactly!
93 loyale 4x100 conversion?
There are some members making Adapter plates to allow the use of Alternative Wheels, Here is an Example: ~► http://www.ultimatesubaru.org/forum/topic/138796-4x140-to-5x100-bolt-pattern-adapters/?do=findComment&comment=1168312 In my case, I prefer to Redrill the Hubs; I did a 4X114.3 redrill since 1996, and I have been driving my Subie like that since then without issues. Kind Regards.
You missed to mention the Symptoms. So, is the Parking Brake, weak? Non functional at all?
Double Row Radiators has a Beefier core than Single Row Radiators. Look at them sideways... Yes, you're Confused, this time because you did Not read that thread completely. No, the Prius twin fans was Never used, it was there for measurement and Comparison purposes only; I used an Aftermarket slim fan, please re-check said thread for complete information regarding the Fans and also the Lower temp Thermoswitch, but this time, take your time for Reading Completely, because there I also explained the Fan Clutch: ~► http://www.ultimatesubaru.org/forum/topic/125754-easy-guide-on-five-steps-to-twin-electric-fans-swap/ That is where the Auxiliary Electric fan, must Kick on, in the EA82's that came with a Mechanical Fan / Electric Fan Arrangement... If that Subaru were mine, I would be Sure that there is no Headgasket issue, then I would thrown the Mechanical Fan and place a Good slim Aftermarket electric Fan there, and change the Single row Radiator with a Dual row one, plus change the Thermoswitch with the one pointed on the above linked Writeup; all that fixed the Temperature problems on my Subie, since many years ago. Kind Regards.
rear disc brake swap.
You're Welcome! Kind Regards.
FreeSSM BEWARE
Loyale 2.7 Turbo replied to somick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh man, that's Awful... I bet it should have something to do with the Website that offers the Software, Sometimes they gets the right to Distribute softwares, but they bundle their own malwares and spywares inside the installers. Also, I bet that this thread will get moved to the Offtopic forums... Kind Regards.
Links to EA81 posts
You're welcome. Don't forget to retrofit the EA82's Proportioning valve, in case you do a Rear Disc Brakes' Swap on your EA81: ~► http://www.ultimatesubaru.org/forum/topic/56957-rear-disc-brake-swap/page-2?do=findComment&comment=1289350 Kind Regards.
Links to EA81 posts
Well, our Junk Yards have almost everything disassembled and classified, here you can see several Photos: ~► http://www.ultimatesubaru.org/forum/topic/87725-an-open-request-to-loyale-27-turbo/page-5?do=findComment&comment=1044253 But, it is very hard to find a Subaru on our Junk Yards... Kind Regards.
Yes, I know this is a... ...but regarding this: That is the Proportioning Valve, the EA82's has it hiding on the Rear undercarriage: Kind Regards.
Low budget 15" wheels ~ what do you think of these?
What do you think about Covering the lug nuts with empty Plastic bullets? No, I will Not do that, it was another idea from my Friend... I dislike to have things that could fall off easily from my Cars. Kind Regards.
Links to EA81 posts
Yes, here it is: ~► http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/ But it is regarding the Third Gen Leone / EA82 only, Not for the Second Gen / EA81. ... ... Here you Go: ~► http://www.ultimatesubaru.org/forum/topic/47583-rear-disc-conversion-on-ea81-ea82s/ Kind Regards.
I painted their outer lip in Yellow, to match the "Radioactive Yellow" finish on my "BumbleBeast" but, since this is an industrial grade, chip resistant Paint, that Yellow painted over the Black paint, looks darker than the Subie, somehow. Then, my friend talked to me about this "Rim Pro-Tec" Wheel Bands, see: ~► http://www.carid.com/rimpro-tec/rimpro-tec-wheel-bands-16610587.html However, I preffer Paint, rather than anything that could fall off or be stolen.
It was a Rainy weekend... so instead of borrowing the Air Compressor and the rest of the Hardware, I went to Paint 'em at my Friend's shop, I let 'em dry there and bring 'em home today's early morning, then I went to mount the Tyres; so the wheels are little Dirty in that photo. The tyres are still 205 / 60 R 15" (measures 25" overall diameter) like the previous ones, but these were gifted to me, after some Restore / Remodel jobs I did during the past months on a House, I hope they'll perform well on my Mixed onroad / offroad drivings...
So, this weekend these Wheels changed from this: To This:
Thanks, have you Voted in the Poll? Those Rims does Not fit the Stock Hubs, because you know, Subaru used 4X140 lug pattern on these Models, and the Rims I posted here, are 4X114.3 ... You can use an adapter, there are some made by other USMB members. In my Case, I redrilled the Hubs almost two decades ago, see: All your answers are in previous posts of this Thread. Kind Regards.
Documented: The 1970 FF-1 Project car...
AWESOME! ... ... CONGRATULATIONS!!!
My new turd, Lifted 90 Turbo 4WD
The wheels are looking good in Black! For some reason, your Photos... ...are Gone, I bet you moved your whole Album on Photobucket. Kind Regards.
Yes, I agree that the engine needs a proper diagnosis, However, the EA82 engine's cooling system usually is very Weak, So this solution have worked good, if there is No problems with headgaskets, Waterpump or other items: Kind Regards.
FreeSSM BEWARE
Loyale 2.7 Turbo replied to somick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, but only if you Decline. However, you can choose if the installer of the software you wanted, will also install the parasite Software bundled on the Original install, or Not. Kind Regards.
Beside the good advices posted above by Uberoo, You must be aware that there are Two types of Radiators for the EA82: The Single-Row ones, and the Double Row Ones. You can change the Single Row for a Double Row Radiator, And you can use a Lower Temp ThermoSwitch that I found, here: ~► http://www.ultimatesubaru.org/forum/topic/125754-easy-guide-on-five-steps-to-twin-electric-fans-swap/ Kind Regards.
Tribeca Replacement?
Subaru Gives A List Of Names For Its Tribeca Replacement: ~► http://www.subienews.com/2015/06/whats-in-a-name-subaru-give-a-list-of-names-for-its-tribeca-replacement-we-pick-a-winner/ Somehow I'm one of those persons that like to see Cars' Names that continue Living, despite that the model Changes a Lot with ages; Names such like Corolla, Mustang, Skyline, etc... has been for decades among us, Subaru used to have a "Legendary" name with the Leone and it was a shame that they Discontinued its Use; now seems that the same will happen with the Tribeca, according to the information given on the link above... What do you think about that? ... Kind Regards.
