3
Everything posted by Leeroy
This adapter works the other way, it allows the use of an EJ engine on a EA gearbox.
No better colour than Sprite Green! Looking forward to updates.
Will 2nd Gen BRZ Ever Happen?
Leeroy replied to MR_Loyale's topic in BRZ and its Sister the Scion FRS/Toyota GT86
Ahh... Frameless windows! It WAS what made a Subaru a Subaru. Miss them, wish they would come back. -
Nitpicking SnatchedHatch... You say that overall Subarus sales figures are low? Where exactly? You're right on the small ute idea though, check out the Hyundai Santa Cruz. I find all this conjecture on the BRZ fascinating but Subaru never wanted to build it in the first place. Only 1 in 10 built are BRZs anyway, if it has a future it is because Toyota wants it to have one not Subaru. on another note, with Subaru selling 500,000 of their current models in the USA I doubt they will take many risks in new product. Think, 'if it ain't broke..." Such a shame too, chasing the USA market has meant Subaru has lost a lot of their uniqueness and IMHO, character. -
Weber carb installation problem
Leeroy replied to mojoinacoma's topic in Historic Subaru Forum: 50's thru 70's
If the studs are not actually stuck the simplest way to remove them is by treading two nuts onto the stud, tighten the nuts together so they are 'locked' and then with a wrench use the locked together nuts to unscrew the stud. -
This one for Gen 1 Subarus: https://niceproducts.com.au/product/nid1601-ignition-barrel-doors/
This one if you want door looks too: https://niceproducts.com.au/product/nid1600-ignition-barrel-doors/
Search for Nice Products: https://niceproducts.com.au https://niceproducts.com.au/product/nic1600-lock-switch/
Just got a 78 Brat. Alabama
Leeroy replied to monkbonk's topic in Historic Subaru Forum: 50's thru 70's
Looks to be PO creativity to me. It does not match the genuine 'short' stripe which starts behind the door and a genuine 'long' stripe would end near the mirror not continue to the front guard. -
Heater fogging up windscreen
Leeroy replied to rxleone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If it is equipped with A/C you should turn this on too. A/C acts as a dehumidifier which means the windscreen will clear in no time. -
Factory Air Filter/Weber Mod
Leeroy replied to tundrabrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There are a few threads on this but the following is a good start (page 2 in particular): http://www.ultimatesubaru.org/forum/topic/119865-weber-air-cleaner-alternative/ -
what if i crash? which vehicle am i safer in?
Leeroy replied to Subasaurus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I disagree about the frameless doors being an issue in terms of safety. Most Subarus after 2000 where '5 star' in crash testing and were still fitted with frameless doors. Subaru changed to framed doors to allow for much bigger door openings and to make sure the doors shut with a 'thunk' sound... Much harder to make a car sound like it is 'quality' with frameless glass 'flapping' about... As an example, the boron steel used in the B pillars of Impreza models from late 2000 was so strong that the 'jaws of life' equipment used by emergency personnel (in Australia) needed to be re-designed to cope. -
EA71 Fat Case with FWD Dual Range 5speed Gearbox.
Leeroy replied to 1000 Pistes's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes very tall! Especially considering no FWD dual range transmission exists! To the OP, the only Subaru transmissions that are dual range are either 4WD or AWD. While anything is possible, running a 4WD/AWD transmission permanently in FWD would mean you have to plug the transmission output shaft (basically so the oil stays in the transmission!) and while it has been done by people as a 'stop gap', not sure it would work long term. -
Just First Generation Subaru Photos!
Leeroy replied to Pooparu's topic in Historic Subaru Forum: 50's thru 70's
Come on Willy, did you deliberately time the photo to catch Liberty or Outback in the background? -
The Impreza has high tensile steel, which unlike earlier models, means the body is lighter and stronger. As others have already stated, if you do have a major crash you would have a better chance of survival in an Impreza over earlier models and that is just regarding secondary safety in a crash. The Impreza will also have better primary safety in terms of braking and handling performance, making it easier to avoid a crash in the first place. -
Nice collection Gopher! Please let us see your 4wd wagon too. Better pictures would be good too! If you join an image hosting site like Photobucket or something similar you can put up much better pics.
Help with wheels for my 78 Brat
Leeroy replied to Grisezd's topic in Historic Subaru Forum: 50's thru 70's
Yes 505, just make sure they're the 15 inch versions and not the TRX 390mm metric. -
1979 Brat clutch pedal hinge worn out
Leeroy replied to ME123Insanity's topic in Historic Subaru Forum: 50's thru 70's
This seems to not be such an issue on RHD models, at least none of mine have this issue. Clutch cables snapping at unexpected moments, yes(!) but not cracking in the pedal box. Of course our RHD models have much shorter clutch cables and no cable hanger, this must place more stress on the pedal box. -
Offset I am not sure about but I ran 15×6 Peugeot rims on my 1978 wagon without issue. With the correct size tyres they fit within the guards too. 15×7 would need carefull measuring to get the offset right but should be possible.
